11-06-2012, 11:15 AM | #1 |
Rep 21,240
H&R Project BMW F30 335i on Just Released H&R Coilover Suspension (Specs and Gallery)
BIMMERPOST NEWS H&R Project BMW F30 335i on Just Released H&R Coilover Suspension (Specs and Gallery) A new coilover option [see full F30 coilover list] is now available for the F30 3 Series, from H&R. The H&R Coil Over Street Performance Suspension (Part number: 28895-1) for the F30 328i and 335i has the following height adjustment range: Front: -1.5-2.6" Rear: -1.3-2.3" MSRP price: $1,680.00 Part number: 28895-1 The H&R Street Performance Coil Over kit takes the traditional shock/spring package one step further. H&R combines their progressive-rate springs with specially valved shocks and adds height adjusters that let you set the ride height to your own personal tastes. These coil overs are designed for street use with progressive rate springs that start out soft and stiffen as they are compressed. This helps to keep the ride compliant while still giving better handling and balance. H&R designs each suspension to work as a coil over. This means that the correct amount of travel has been built into each shock. And the shocks are valved specifically for the spring rates to give a tight and controlled ride without being harsh or ultra-stiff. Each H&R coil over is TUV tested and approved and meets ISO quality standards. These are used with the stock strut and shock mounts for a quick and easy install. Some photos and specs of H&R coilovers installed on F30 sedan (with BMW M Performance Parts): Specs: Base Vehicle: 2012 BMW 335i sedan 3.0L TwinPower Turbo 6-cyl 6-speed manual transmission Mineral Grey Metallic BMW M Performance Parts (front spoiler lip [requires M Sport kit], sideskirts, black kidney grilles, rear diffuser) Chassis: H&R Street Performance Coil Over H&R Trak+ Wheel Spacers BMW M Performance Brake System 370mm front, 345mm rear Wheels & Tires: O.Z. Ultraleggera HLT white wheels, size 20x8.5” Michelin Pilot Super Sport tires, size 235/35ZR20 front, 245/35ZR20 rear H&R Coilover system: |
11-06-2012, 11:17 AM | #2 |
Rep 1,716
god damn i love that MG car. just for perspective, are those 20" wheels there and at what level is the car lowered?
thanks! ...oh, and price?
Formerly addicted to e46fanatics
Formerly addicted to e90post |
11-06-2012, 11:25 AM | #3 | |
Rep 21,240
The H&R F30 project car specs are now listed in the first post.
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
11-06-2012, 12:59 PM | #4 |
BMW 4 Life...
148
Rep 3,360
I guess I found my next coilover set!
I already have the H&R Sport Springs and very happy with it. Now the coilovers will make it even better! Great job H&R!
MODS: *** / M Sport + Performance / Meisterschaft / Challenge / MORR / more to come! ***
11-06-2012, 02:59 PM | #7 |
Rep 2,638
Absolutely perfect stance!
M240i Coupe (6MT) (2021: 6/2021 build )
Accord Coupe (6MT) (2017) 335i Coupe (6MT) (2007: 9/06 build SOLD 8/2016) Prelude (5MT) (1995) |
11-06-2012, 03:19 PM | #9 |
Rep 4,659
Man, every time I see a M-Sport F30, I smile more. While it grew in size, it looks much more lighter and more agile than the E90. I think the F30 perfectly reflects what the car is about and it's segment.
11-06-2012, 03:21 PM | #10 |
5 Star General
120
Rep 2,631
11-06-2012, 03:31 PM | #12 |
Rep 21,240
As the specs in the first post says: BMW M Performance
11-06-2012, 04:34 PM | #17 | |
Rep 1,180
That front apron is another detraction.
on order: 2024 i4 eDrive40 M Sport, Tanzanite metallic with all options
11-06-2012, 04:56 PM | #18 |
Rep 2,928
Drives: 328i, 335i, M3, 535i, X5, 36M
Garage List 2014 Ford Raptor [0.00]
2012 328i E92 [10.00] 2013 X5 [0.00] 2013 335i F30 [8.00] 1990 Toyota Previa [0.00] 1997 E36 M3 [10.00] 2011 E92 M3 [0.00] 2011 535i [0.00] |
Probably put the white wheel to match their logo
11-06-2012, 05:11 PM | #19 |
Supreme Allied Commander
3842
Rep 54,352
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
Looks like H&R supplied the incorrect product photo as the rear dampers should be pin to eye and not pin to pin(E8x and E9x only). The front struts should be identical for the LH and RH side as BMW cut excessive cost in their production and produce only one strut and use different anti roll bar end links instead.
