08-11-2017, 05:23 PM | #3 |
Rep 633
08-11-2017, 09:18 PM | #4 |
3387
Rep 7,541
I would have replaced all plugs and the coil on then misfiring cylinder if the plugs had 60k on them. It's also a good preventative measure to do the other coils as well - but not necessary. I've seen a lot of issues with primarily the 13 and early 14 coils.
08-11-2017, 11:37 PM | #5 |
Rep 633
Alrighty
08-12-2017, 10:40 AM | #6 |
Rep 5,231
09-01-2017, 11:13 PM | #7 |
Rep 2,062
Where's a good place to buy them? Bosch coils are around $22 each on eBay, seeing if there's other options.
09-02-2017, 06:15 AM | #8 |
Perennial PFC
336
Rep 1,274
09-02-2017, 01:12 PM | #9 |
Rep 2,062
Thread title is coil replacement, so that's who them are. I've found Bosch coils for as low as $20.29 on FCPEuro. I bought my NGK two steps colder plugs from BMS' website but I don't recall what they cost.
09-02-2017, 02:52 PM | #10 |
Perennial PFC
336
Rep 1,274
Okay. Since the only two pertinent comments concerned both plugs and coils, I tried to be helpful and covered both. Great that FCPEuro is even lower than around $22 for the coils.
09-25-2017, 01:55 AM | #12 |
3387
Rep 7,541
Could be coil, plug, or injector. If not any of those, it's a more serious issue.
09-25-2017, 09:02 AM | #13 | |||
Rep 228
09-25-2017, 12:17 PM | #14 | ||||
3387
Rep 7,541
Could also be a bad DME if all of the hardware checks out.
10-05-2017, 03:53 PM | #16 |
Rep 228
11-12-2017, 09:39 AM | #17 |
Rep 228
11-26-2017, 05:47 AM | #18 |
Rep 881
Ugh...looks like I popped a coil tonight doing a few freeway runs. Is everyone using oem coils for replacements? Has anyone tried these "high performance" coils? I may change out my plugs too as I'm coming up on 10k miles with current set.
https://www.bavauto.com/5005-8?find=bmw-2014-m5-4516057 https://www.bavauto.com/5005-8?find=bmw-2014-m5-4516057 Edit: spoke with Bavauto and they were cool and told me this coil set wont provide any benefit over OEM Bosch coils for the M models. So, going with NGK 97506 plugs and Bosch 0221504470 coils. Last edited by apexlocator; 11-27-2017 at 03:27 PM.. |
TheHouseWon644.00 |
11-27-2017, 08:50 PM | #20 |
Rep 966
You don't have to replace the ignition coils on a maintenance interval like spark plugs.
There have been "product brand revisions" and BMW is notorious for this going back to the E36 days. BMW finds a vendor and sure enough that same chassis all a sudden has a TSB "Technical Service Bulletin" and all the ignition coils are being replaced by another brand. I would only recommend using the factory OEM brand. Cheap parts are cheap for a reason. |
11-27-2017, 09:58 PM | #21 |
Rep 2,062
I'm just over 100k and while I can't claim any coil issues, I replaced them anyways. I got them from FCP and will replace them at another 100k via their lifetime warranty...assuming I've still got the vehicle then.
11-28-2017, 02:04 AM | #22 |
Curve Thrasher
623
Rep 3,773
James when I had a misfire I had replaced my plugs and injectors. It was time to anyway. Problem solved. But now it's time to go to a colder plug. My mileage is 115k now.
Country run |
