      09-09-2014, 04:18 AM   #1
Midasman13
Midasman13's Avatar
Wales
Drives: M5
Screeching brakes
Hi, 3 months into my ownership of SG time machine and loving nearly all aspects of it, apart from when I have to stop!!!
My brakes give out a teeth grinding screech. I've just done 2000 miles and the dealership tells me they are bedding in. They did look at them on 1200 mile service apparently. This is now wearing a bit thin!
Has anyone else got/had these issues, is it normal?
      09-09-2014, 11:10 AM   #2
PatrickC23
PatrickC23's Avatar
2013 BMW ///M5  [0.00]
Shout out to Clar, but this does work - I now spray it sparingly when I wash the car and I've not had it come back. My wife says thanks Clar, as do the people sitting at the light as I approach.
http://f10.m5post.com/forums/showthread.php?t=957348
2016 991.1 911 Carrera GTS
      09-09-2014, 11:25 AM   #3
JOHNBMWM5
JOHNBMWM5's Avatar
Originally Posted by Midasman13 View Post
Hi, 3 months into my ownership of MG time machine and loving nearly all aspects of it, apart from when I have to stop!!!
Not normal at all, mine have never made a noise ever in 11500 miles.
      09-09-2014, 01:03 PM   #4
smallgirl
Drives: Black Saphir Metallic F10 M5
Same here - Im told by dealership that there is no fix for this however it is a known issue by BMW NA.
Go figure !!
      09-10-2014, 03:38 AM   #5
Midasman13
Midasman13's Avatar
Wales
Drives: M5
Thanks Patrick, I will try out this weekend. Ill let you know if it works!!
      09-10-2014, 05:23 AM   #6
PatrickC23
PatrickC23's Avatar
Just to reiterate what Clar says, no clue if there are side effects. I for one did this about 3 months ago and have been squeak free with no issues. I figure wheel cleaner inevitably gets on the brakes anyways.
I sprayed a generous amount the first time inside the caliper to coat it, then rinsed off after a few minutes. After the first time the squeak did come back as I stated, but then disappeared. Now when I wash the M I just spray a little inside the caliper and all good.
I dont think its normal, it was just a bad oversight by BMW in testing as everyone seems to have the issue. I wanted to try this before I wasted a day at the dealer only to have them tell me its normal for high performance brakes. I guess you can try some bedding practices after you do this as well to clean them out.
Hoepfully you can find this cleaner where you are.
      09-10-2014, 09:03 AM   #7
shahano
I have had this same problem as well as my friends since they day I bought the car. Sometimes it squeals and sometimes it doesn't.
      09-10-2014, 10:12 AM   #8
M5essex
M5essex's Avatar
England
642
Drives: RR sport SVR, Vent S, 650s spi
same here... I got squeal for the first few thousand of miles but now nothing. and covered just over 4000 miles. it just seems to 'go away' after they have bed in...
Current - 2016 McLaren 650s Spider, Aurora Blue
Current - 2016 Range Rover Sport SVR- Black
Current- 2018 Aventador S. Nereid blue
Gone - 2016 F80 CP, 2015 991 Turbo S, 2016 LCI M135i. 2015 F10 CP M5. 2015 X5, 2012 E92 CP M3. 2009 E92 335i
      09-10-2014, 10:36 AM   #9
bodonx
Drives: 2014 F10 M5 CP
Mine gets worse after 5000 miles
      09-11-2014, 03:47 AM   #10
Midasman13
Midasman13's Avatar
Wales
Drives: M5
Its like that top American show......... Braking Bad!
      09-11-2014, 03:57 AM   #11
M5essex
M5essex's Avatar
England
642
      09-11-2014, 11:42 AM   #12
(H)
(H)'s Avatar
Drives: F80 M3 (after F10 M5 ;-)
Same issue here on the original brakes. Got disks and pads replaced two weeks ago after some intensive wear on the track. Absolutely screech and squeal fee ever since.
IG: hartmutkraft
FB: seventeenjewels
      09-11-2014, 11:46 AM   #13
mwlmd
mwlmd's Avatar
Drives: Porsche 991 TTS
Just had my brakes replaced yesterday. No squeaking now. We will see how long this lasts...
CURRENT:
His: Porsche 991 Turbo S
Carrera white/Black
Hers: BMW X3MC
BSM/Black
      09-16-2014, 03:46 AM   #14
Midasman13
Midasman13's Avatar
Wales
Drives: M5
Patrick, many thanks, I found the same make cleaner at Halfords UK. Applied as instructed on Saturday, had a few little screeches after but has but now disappeared! I hope it lasts.
      09-16-2014, 08:26 AM   #15
soooma
///MD
soooma's Avatar
Drives: M5 F90
Sometimes it does and sometimes it doesn't !
And that's after replacement once at 7000 miles make for squealing
      09-16-2014, 02:48 PM   #16
PatrickC23
PatrickC23's Avatar
Cool, thanks to Clar. I apply whenever i give it a wash, but I dont coat it with much, then spray off in a few minutes. Ive had no squeaks since.
      09-16-2014, 03:21 PM   #17
Propofoln
Speedster
50
Drives: 2023 BMW X7 M60i
my 2014 M5 has 6,000 miles on it and has squealed since day 1
2023 BMW X7 M60i
2020 Porsche Taycan Turbo
      09-16-2014, 03:48 PM   #18
a90
Netherlands
66
Drives: F10 M5, E88 125, E70 X5, R1150
My right rear brake pad disintegrated last week. The friction material was lose from the back-plate.
That was news for my garage, never seen that before.
The car has now 26.000 km's on it.
BMW E88 125 - 2008
BMW F10 M5 - 2016
BMW E70 X5 3.0d - 2007
BMW R1150r Rockster - 2003
Mercedes LP2223 - 1970 (http://www.lp2223.com)
      09-16-2014, 09:27 PM   #19
cassidysdad
clars trick worked for me too...
but it returns
unpredictable and frustrating
i have 6000 miles
the only irritating part about the car
figure with a 100k plus car bmw could fix it
      09-16-2014, 11:11 PM   #20
///SAL
///SAL's Avatar
Drives: 2014 ///M5 ZCP
When they make noise drive reverse slam the brakes, done! Youll be fine for a while.
