03-21-2017, 10:02 AM | #1 |
Royce Martin
56
Rep 572
Lowering
Interested in lowering, I'm in New York so I won't go extremely low but I do want to close that gap between the wheels and the fender/quater panel. I'm think 1"-1.5" would be good?
What springs would be good, what else would I need to change when changing the springs? |
03-21-2017, 11:03 PM | #4 |
Rep 5,233
KW HAS is great IMO. Fully adjustable and superior ride quality vs. H&R and other fixed height springs.
03-22-2017, 12:12 AM | #7 |
Rep 343
I also say go with KW HAS. I have them and love them
@TheHouseWon, I didn't install mine but I don't think it would be too difficult with the right tools and space. Getting the ride height where you want it seems like it would be a little bit of a PITA without a lift.
22 M850i gran coupe
03-22-2017, 12:23 AM | #8 |
Rep 2,039
Thanks. Is there a ratio used for dropping front and rear or is it 1:1. Example: if you drop .8" in the front, do you have to drop .8" in the back? Or should it be less in the rear?
03-22-2017, 08:34 AM | #9 |
Rep 210
Has anyone consider Dinan's suspension kit for the F10 M5?
It appears to be similar to KW HAS with similar adjustments, warranty, and priced about the same. |
03-22-2017, 08:41 AM | #10 |
Master Gunnery Sergeant
72
Rep 220
See my recent post regarding recent install on KW HAS. Highly recommend KW HAS with the adjustability. We get snow here in WA state and will be nice to raise when/if needed in winter months as she is my daily. Final pics at end a nd measurements my shop went with for desired stance. http://f10.m5post.com/forums/showthread.php?t=1360003
VF Engineering Hex Stage 1, RPI GTM Black edition, KW HAS, Dinan sway bars, Matt Schnell spacers, IND black chrome, M Performance rear spoiler, M Performance rear diffuser, Michelin Pilot Sport 4S's, ESS stainless steel brake lines, EBC Red Stuff ceramic pads, BMC air filters, charcoal filter delete, sprint booster, V1w/Blendmount, BIM coding all options, Pedal Haus pedals, Formula One Pinnacle Tint
03-22-2017, 12:28 PM | #12 | |
Royce Martin
56
Rep 572
03-22-2017, 02:17 PM | #15 |
Rep 1,107
After much research I'm also going KW HAS kit on mine w Dinan sway bars
03-22-2017, 03:19 PM | #16 |
72
Rep 220
I don't know what my initial measurements were, I'll ask. The rears dropped after a couple of weeks and I didn't like it that low. My final adjustments is from fender to top lip of OEM wheel on stock 20" tires, front 24 1/4" and rear 24 1/2". Shop that did install did re-adjustment and another alignment.
03-22-2017, 03:20 PM | #17 |
72
Rep 220
I have no idea. I tried to peek when they were re-adjusting but I couldn't tell you exactly what they were doing.
03-23-2017, 04:52 AM | #18 |
Rep 1,231
Lowering also increases the vulnerability of some pretty expensive components to debris lying the road
2 Oil coolers Engine sump and lower crankshaft housing DCT sump and housing Catalyzers Exhaust Differential housing Front and rear suspension Only takes half an inch too little clearance to do tens of thousands of $$$ worth of damage |
03-23-2017, 10:29 AM | #19 |
Rep 53
KW HAS all the way. I did the installation myself and wished I would have paid someone to do it for me. You can certainly do it yourself if you are handy, however it is a lot of work.
03-23-2017, 01:20 PM | #20 | |
Royce Martin
56
Rep 572
03-23-2017, 06:48 PM | #21 |
Rep 1,231
03-23-2017, 08:11 PM | #22 |
Rep 5,233
Every car I've owned has been lowered with no issues outside of some bushings I needed to replace on an Audi S6. Not disagreeing with SteveC about some dangers but you just need to be careful.
Not unlike being careful when you have nice wheels
