      06-29-2013, 05:34 PM   #1
Protious
Drives: 2013 BMW M5
Drivetrain Malfunction
Happened twice yesterday and persisted till this morning on the way to the dealership.
Took it to dealer this morning, and it seemed like it registered a Electronic Damper Control (EDC) Fault. The warning is gone for now, so they let me take the car back and the warning hasn't come up again yet.
First time this has happened to me. They're going to do a full diagnosis on Tuesday (they ran a "short test" today). We'll see what happens!
      06-29-2013, 06:44 PM   #2
Drives: Black M5
Yeah any number of things can cause a Drivetrain Malfunction. There are a ton of sensors in and around the engine and one of them could be setting off the Drivetrain Malfunction message. If it keeps persisting then there's either something legitimately wrong or it's a faulty sensor.
      07-03-2013, 03:53 AM   #3
Neil McRae
BMW Motorsport
Neil McRae's Avatar
Drives: BMW ///M4 F82 / BMW ///M5 F10
2020 BMW M5 CP  [0.00]
2015 BMW M4  [10.00]
i had this and it was solved by a software update.
Neil J. //McRae -- Alive and Kicking -- neil at DOMINO.ORG --///M ARMY
M5 CP Alpine White -- M2 LBB -- M4 DCT CP Alpine White
      07-03-2013, 08:03 AM   #4
boots
Curve Thrasher
boots's Avatar
623
Yes the software update will fix this. Strange how many things trigger this fault.
      07-03-2013, 08:55 PM   #5
Rob///M5
Rob///M5's Avatar
77
Drives: 2013 M5 SSII
2013 BMW M5  [10.00]
What update do you ask for? My car was recently in for service, they didn't fix the drivetrain error and never offered or completed a software update.
      07-03-2013, 09:05 PM   #6
Bibendum
Drives: 2013 M5
I got the same thing today. Was at the dealership as it turns out. Car started rough, then sputtered, then shut down. Tried it twice and it just kept dying. Shut it down, locked it, and when the SA came out it started with no issues. Was fine rest of day. Car more like a computer anyway so figure it just rebooted...
      07-06-2013, 04:30 AM   #7
Protious
Drives: 2013 BMW M5
Turns out mine was a one-time EDC fault, "full test" resulted in no faults additional faults / weird results. Guess we'll see how this runs the next few months, I have another two parts on order - a wheel hub (drivers side) and a new high pressure steering hose.
      07-06-2013, 01:59 PM   #8
utmiken
Fuel looks low. Mine did that with 77 miles left on the range. Wouldn't fire up until I added another gallon of gas. Hasn't happened again as I never let it get past half now out of paranoia
      07-06-2013, 03:34 PM   #9
boots
Curve Thrasher
boots's Avatar
623
Rob they prob didn't plug in to the port. Go back and tell them you need the latest Sw update
      07-13-2013, 08:57 PM   #10
Protious
Drives: 2013 BMW M5
Here we go again.. While driving normal speeds, waiting for oil temperature to hit...
Another drivetrain warning, seems like it's going to be a hard code this time. Car is in valet mode, can absolutely feel no turbo boost at all. Drivetrain warning has stayed on all day.
      07-16-2013, 02:39 AM   #11
Protious
Drives: 2013 BMW M5
They are currently re-programming my car.. When they plugged it in, it gave a boost controller fault, boost blockage fault, on top of the EDC fault. The BMW computer immediately told the tech to recode the car..
Hopefully the new programming fixes it up, otherwise.. Makes me wonder what I blew up.
      07-17-2013, 08:03 PM   #12
Protious
Drives: 2013 BMW M5
After re-programming, everything is back to normal for now. My car didn't throw any additional drivetrain malfunctions, it has been around 150 miles since I picked it up.
Xtabi1701.50
      07-17-2013, 08:14 PM   #13
wisesoul
Savoir Faire
wisesoul's Avatar
Philippines
74
Drives: 2013 BMW M5
The M5 will have a hard time being a classic car, so many electronics that can fail down the road. Yikes. Glad everything is working now
Sold:Imola Yellow RS4-KW V3|MTM 10mm spacers|Hotchkis rear sway bar|APR Stage 1|Milltek Catless|RNS-E|Euro RS4 Flat bottom Steering Wheel
Sold:E46 323i
      07-18-2013, 01:58 PM   #14
DanW
Drives: 2013 BMW M5 F10
Tell them to check the low pressure fuel pump. This same exact thing happened to me and after many tests they finally switched out the fuel pump and that fixed the issue...... so far.
      03-01-2018, 04:49 PM   #15
tigerinsc
Drives: BMW 528i
Question for the thread
Hello all. I have a 2012 528i with 98,000 miles. Have had the drivetrain light come on 4 separate times in the past 7 weeks. All 4 times, the car has lost power and I've pulled off the road. Turned off engine. Waited. Restarted and driven to dealership for service. Here are the work that has been completed and days in service.
1st: Software update: 1 day
2nd: Timing belt replacement: 9 days
3rd: Exhaust fan replacement: 2 days
4th: Turbochargers replacement: 10 days
My concern is that it is going to run out of the CPO warranty at 100,000 miles and the problem will persist.
Any insight is welcome
Thank you
      02-08-2021, 06:36 AM   #16
abates49ers
Drives: 2015 M5 Competition
so what happened!?!!
      02-08-2021, 11:53 AM   #17
Fast.F10
Extruding Elements
Fast.F10's Avatar
Drives: 2016 BMW M5 Comp
2016 BMW M5 F10  [0.00]
Last Activity: 02-27-2018 11:26 AM
2022 Yukon XL AT4
2016 BMW M5
2015 Ford F250 Super Duty
2006 BMW M5
      02-10-2021, 09:49 AM   #18
Looks like there were some ghost DTM's on the then new M5 which disappeared after re-program by technician .
