12-20-2014, 08:43 PM | #1 |
Rep 78
How long does your fan stay on after the car turns off?
Mines still on for 10-15 minutes after short rides. Something doesn't seem right.
Current: 2013 M5, 2012 Jeep Rubicon
Retired: 2008 M3 coupe, 2007 Z4 M Coupe, 2003 350Z |
12-20-2014, 09:18 PM | #3 |
6'0 / 250lb
137
Rep 1,797
I'd say somewhere between 7 and 12 min.
12-21-2014, 03:38 AM | #6 |
Rep 315
Drives: 13 AWSO M5,16 DGMR X5M
I think the time depends on the driving style.. If I drive it hard, probably up to 10 mins. However if i drive normal, sometimes the fan stop directly as i turned the engine off.
2012 Rosso Mars Lamborghini Gallardo STS LP570-4
2013 AW SO F10 M5 upgrades: RKP front spoiler, M performance carbon spoiler, 3D design rear carbon diffuser, KW HAS Sleeve Kit, Akrapovic Evolution Carbon tips, ind black LCI front and rear grills, GruppeM RAM intake, 20" HRE P104 satin charcoal with PSS tires) |
12-21-2014, 05:16 AM | #7 |
1989
Rep 9,498
Only 5 minutes max however driven.
12-21-2014, 06:07 AM | #8 |
Rep 375
12-21-2014, 07:00 AM | #9 |
Internet Crash Test Dummy
331
Rep 1,055
Normal behaviour ...
The conventional coolant pump is driven by a belt and cannot be used for cooling the exhaust turbocharger after the engine has shutdown. For this reason there is an electic coolant pump, which works at a power of 20W. This is done by a seperate cooling circuit. This circuit can also be activated during engine operation, the electric coolant pump can be switched on taking into account the following factors: - Coolant temperature at engine outlet - Engine oil temperature - Injected fuel quantity The heat input into the engine is calculated these values. The after-run of the electric coolant pump can last up to 30 minutes. To improve the cooling effect, the electric fan is activated and can for up to a max of 11 minutes. There are also two separate 50W cooling pumps for the DMEs (one for each bank)
15 F10 M5 Individual / Brilliant White / Extended/Full Cohiba Brown (Exec/Driver/B&O/20") / A few Euro add-ons / Stealth K40 / Upgraded B&O / ///M Performance Carbon Interior Trim / IND / Akrapovic Evolution Exhaust / HRE S107 |
12-21-2014, 08:47 AM | #10 | |
1989
Rep 9,498
