      10-16-2015, 05:18 PM   #1
mnep
Track question!!
Going to silverstone with my M5 and wondering weather to put on the wider 9.5j and 10.5j 601m competition wheels from the M6, my thinking is that they will give a lot more grip but are heavier!!!
Or
Standard 343m wheels which at 0.5inch narrower but lighter!!
Very confused, a lot of people say that even the tires sit better on the wider M6 rims but the extra weight is also a factor... What would be the best thing to do for a quicker car around track!!
      10-16-2015, 05:23 PM   #2
AGS
AGS's Avatar
501
Drives: 2022 M5 Competition
Honestly, unless you're a serious track rat with hundreds of hours of seat time I don't think it'll make a difference. I'd think at best you're talking tenths of a second differences in your lap times.
      10-17-2015, 10:07 AM   #3
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
If your concern is just wider rims but not heavier than your current one, go for M6 343M rims. They are 9.5" (front) and 10.5" (rear).
Also M6 wheels have different offsets so basically with M6 wheels you are increasing the track width of your car. It looks more aggressive and a bit better traction but make more under-steer and less agile car.
      10-17-2015, 10:42 AM   #4
Charlie Brown
Charlie Brown's Avatar
Drives: F10 M5 Azurite Black
Anyone tried this? Pics? How far will the M6 wheels poke out?
      10-17-2015, 11:00 AM   #5
v3n0m
Drives: 2013 MCB M5
M6 wheels will not fit. Offsets are completely off.
      10-17-2015, 12:24 PM   #6
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
Yeah many people...
Here is one of them. He has installed 433M wheels (M6GC) with the same width and offset of M6 343M and M6 601M
      10-17-2015, 12:29 PM   #7
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
32 vs 31 (front) and 34 vs 19 (rear).
The front offsets are almost the same; however M6 wheels stand 15 mm out on M5.
      10-22-2015, 09:40 AM   #8
v3n0m
Drives: 2013 MCB M5
Also since its wider it will push the rear even further out than just 15mm.
      10-27-2015, 04:13 AM   #9
funbobbyrob
Drives: 2014 M5 CP
Technically the m6 wheel will fit and using the BMW spec Michelin PSS 295/30 20 the tire shoulder will rub slightly on the felt wheel well liner on easy driving. I tried it on my comp package just around town. If u r racing or pushing hard it will for sure tear up the wheel well using the BMW Michelin PSS as they are slightly wider than other 295/30 20 tires. The wheels will fit but not with that tire.
Not sure if the front m6 on an m5 will rub anywhere on max travel.
The super sports are awesome road tire for track duty imo just make sure to air down and watch temps on a hot day those tires get hot with the heavy car.
      10-27-2015, 09:59 AM   #10
v3n0m
Drives: 2013 MCB M5
I was given the impression that the op wanted wider wheels to fit wider tires, in which case it would definitely rub.
