      02-15-2013, 10:36 AM   #1
Wrotwro7
Wrotwro7's Avatar
Drives: 2009 IB M3 / 2013 SG M5
Beep, beep beep, beep
My neighbors can always tell when I am washing the beast. As I gently run water or a wash mit over the door handles the car will lock, unlock and lock again. Beep! Beep, beep!
Other than putting the key fob far enough away, anyone come up with a "wash mode" or work around so it doesn't sound like disco in my driveway when it's time to get squeaky clean?
      02-15-2013, 10:47 AM   #2
bobblehead
bobblehead's Avatar
Drives: warp speed
If you leave the fob inside the car, it will not go off.
      02-15-2013, 10:49 AM   #3
Wrotwro7
Wrotwro7's Avatar
Good call, I'll give it a shot. Any worries about the doors locking with the fob inside?
      02-15-2013, 11:16 AM   #4
bobblehead
bobblehead's Avatar
Drives: warp speed
Better have your other fob on standby inside your house ... just in case.
As far as I know, it should work.
      02-15-2013, 12:06 PM   #5
PatrickC23
PatrickC23's Avatar
2013 BMW ///M5  [0.00]
So if you get in the car, with the key fob, and lock the doors, Im assuming it disables any unlocking from the door handles from outside correct?
2016 991.1 911 Carrera GTS
      02-15-2013, 12:22 PM   #6
bobblehead
bobblehead's Avatar
Drives: warp speed
If the fob is inside the car (ignition off) and you exited the car (without the fob) and you pressed the door handle trying to lock the car, it should NOT lock (beep) at all since the car detects the fob is still inside the car.
I have not tried it myself but my previous car (Lexus) prevented me from doing the above
Therefore, I suggested you should have the backup fob ... just in case.
      02-15-2013, 12:47 PM   #7
PrecisionP
PrecisionP's Avatar
Drives: ATPC's
Only if you lock using the button in the center column will it disable the door handles. This prevents someone from entering the vehicle if you got chased inside. As long as the battery on the fob doesn't die or fall into the backseat you should be fine if kept around the cupholder slot yall have.
      02-15-2013, 12:49 PM   #8
PatrickC23
PatrickC23's Avatar
Yeah this is what I was envisioning - being chased into my car and comfort access allowing them in! Fail!
What if you have auto locking feature programmed after the car starts rolling? Does this also disable the handles?
      02-15-2013, 12:59 PM   #9
nugent
nugent's Avatar
Drives: f10 m5
there is option in idrive to turn off beeping with locking/unlocking. i hate that beep.
      02-16-2013, 05:48 AM   #10
bradone1
BMW Extraordinaire
Drives: 2019 X7 M Sport, 2015 M4 Vert
Car won't lock from outside handles with key inside. Guaranteed.
That or leave key on 10 feet away while washing
      02-16-2013, 09:22 AM   #11
cdr1973
Drives: 2017 F80 M3
I've been leaving mine in my 535 since day one. Works like a charm, never had a problem
      02-16-2013, 11:28 AM   #12
SANguru
Drives: i8, X5 50,M550i,Tesla, MP4-12c
car won't lock with key inside. It would beep at you.
      02-17-2013, 08:34 AM   #13
ColdList
ColdList's Avatar
152
Drives: McLaren 675LT / C7 Z07
My E60 used to do this at the self serve car wash when I would rinse it with the spray wand. I have wash the F10 and keep the key in the garage several feet away. It has not beeped before but I didn't take chances. Interesting about leaving the key inside. I wondered the same thing about not being able to re-enter. I have enabled the setting that locks the doors automatically after a period of no motion. Wonder if that happens if it will allow me to unlock from the outside with key inside the car.
2016 McLaren 675LT - Chicane Grey
2016 Corvette Z07 - Artic White
2016 BMW F86 X6M - Black Sapphire Metallic
      02-19-2013, 12:37 PM   #14
PrecisionP
PrecisionP's Avatar
Drives: ATPC's
Hmmm not sure about that one, I will have to check that for future knowledge. I would say yes at first thought though.
      02-19-2013, 02:19 PM   #15
PatrickC23
PatrickC23's Avatar
I would think so too - if not anyone could just open your door as youre sitting at a stop light. Not cool.
      02-19-2013, 03:48 PM   #16
dhirm5
Drives: 2014 M5 ZCP, 2014 X5 35d
With BMW Assist and the corresponding iPhone app - not sure if they have Android - you can lock/unlock the car from anywhere as long as your car is in range of a cell tower and you have internet access.
This would save you in the event you lock something inside the car - like your keys..
Did this with my E60 M5 recently - forgot if I locked my car when I parked it at a hotel, after making the lengthy trek from the parking area into the lobby. Pulled up the app, locked it remotely. Like a boss...
