      07-31-2019, 12:44 PM   #1
spiff
The Dr
71
Drives: M20 Saloon, F800S
M5 at the Track - Pics and Experiences
My M5 is almost back in my hands after it's initial list of fixes that CarMax is taking care of and I'm jonesing to take it out to the track.
Have any of you tracked yours? Which tracks? How were your times? Any stock faults that could be corrected with aftermarket parts?
Im a big fan of using a quality tire and fresh brake fluid as the starting point (aside from experience being the main contributing factor).
I'd love to see some pics and video of the M5 brethren laying it down.
2013 M5 - Manual
"You gotta fix the nut behind the wheel before you fix the bolts on the car"
      08-01-2019, 07:06 AM   #2
technician117
1990 BMW M5  [0.00]
2000 BMW M5  [0.00]
2013 BMW M5  [0.00]
I have yet to take mine to the track, but this is what I plan to do beforehand based on experience driving other street cars on tracks and based on what I've read about this car:
-Good tires. Most of us run some form of Pirelli or Michelin. I just mounted Michelin PS4S's a few thousand miles ago. Those will be excellent for a basic track day.
-Brake fluid flush and high quality fluid. A typical pre-track day maintenance item. Doesn't need to be done before each trip unless you know you've overheated the fluid during a session
-Brake pads. I've seen in reviews of the car that the stock brakes are not the best on the track. I would attribute most of that feedback to running a stock compound. The car is built for the street as general use and as such, the compound needs to match that usage. I recommend finding a good race pad to swap out. I haven't looked yet for our cars, but I've had great results with the Hawk HT-10's on my E39 M5.
Some people might recommend additional things like suspension mods but I suggest waiting on that until you've used the car on the track to know how it handles for you and see what you might want to improve, if anything.
Good luck
1320racer136.00
94jedi830.00
      08-04-2019, 08:38 PM   #3
94jedi
Drives: 2009 e92 M3
Good luck
Good advice for sure. I'm in the same boat; haven't done a track day yet but I plan to in the fall. Also just mounted some ps4's ...I went 305's on the rear, hoping that doesn't cause issues (softer sidewall).
Might want to look into track insurance; I plan on squaring that away before touching the car.
Brake pads and fresh fluid are definitely a good starting point. Most tracks will also require proof of a tech inspection by a good shop. Personally, I plan to use BPC in Raleigh NC then head to VIR for some laps.
Obviously, I won't be setting any records; the goal will be to have fun and bring it home in one piece under its own power.
pcohen15379.50
