      05-21-2013, 08:51 AM   #1
MSportDC
///MSport-DC
MSportDC's Avatar
Drives: 2013 F10 M5, 2012 X5 35d
2012 BMW X5 35d  [0.00]
BMW service dept. may have used the wrong oil for my break-in service
So this morning, I got the minimum oil level indication again and conveniently, my normal BMW dealership was near me. I stopped in to get a quart of oil for my "2013 M5" and the guy handed me 10w-60. (no surprise) I told him that my engine doesn't specify 10w-60 and that I need either 5w-30 or 5w-40 and the guy responds, "you put 5w-40 in your M5" with a skeptical look on his face.
Long story short, I get the 5w-40 and put it in and now I'm beginning to suspect that they may have used 10w-60 for the break-in service. I called and left a message with my service advisor to determine exactly what they had used per their records.
Why my suspicions?
I'm currently at 8700 miles on the odometer and I've topped off my oil about 6 times already because of minimum oil-level indications on the computer.
I'm getting an average of 19.5 mpg even though I drive 90% on highway to work every day.
Anybody have input on this? If it is the case that they had used the wrong oil, I will be extremely pissed. Until then, I shall remain calm or else all hell will break loose.
2012 BMW X5 35d (Alpine white/Black - Loaded) - Delivery: 2012/9/17
2013 BMW M5 (Azurite black/Black full merino/Piano trim/20"/Exec./Driver Assist. - Delivery: 2012/11/16 (GONE)
      05-21-2013, 09:12 AM   #2
mdosu
Drives: Double Vanos'd Civic-M3
smh, unfortunately, I've heard the same stories here. Which dealer is this?
Regardless whether this was part of the free maintanence service plan or you paid out of pocket, when you checked out they should have given you a spec sheet detailing the work performed and the parts used. Check that sheet for the part number for the oil, that'll tell you what bottle they used.
I've heard stories of dealers now putting the older TWS oil (which is required for all "E" M cars) into the new M5
      05-21-2013, 10:04 AM   #3
PatrickC23
PatrickC23's Avatar
2013 BMW ///M5  [0.00]
We need a Dealer Service sticky - so that we can stay away from clueless shops and go to the knowledgeable ones.
2016 991.1 911 Carrera GTS
      05-21-2013, 10:35 AM   #4
bobblehead
bobblehead's Avatar
Drives: warp speed
http://www.opieoils.co.uk/pdfs/tech-...10w-60-oil.pdf
      05-21-2013, 10:48 AM   #5
Knight Commander
Why my suspicions?
Do you have paperwork? My service paperwork definitely said 5W-30 on it when I completed the break-in service.
BTW One way to check is to have Blackstone Labs analyze the oil. I did this recently, and it confirmed that my post break-in oil is 5W-30. If they put 10W-60 the viscosity would be off. This is a good way to check - take a sample and send it in.
http://f10.m5post.com/forums/showthr...3#post13893343
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450
      05-21-2013, 11:19 AM   #6
MSportDC
///MSport-DC
MSportDC's Avatar
In the event that they had indeed used 10w-60, what are the ramifications of this? Can this cause permanent damage/irreversible negative side effects?
      05-21-2013, 11:21 AM   #7
MSportDC
///MSport-DC
MSportDC's Avatar
Originally Posted by bobblehead View Post
Wow, this excellent information. Very invaluable resource.
Thank you for this!
      05-21-2013, 12:00 PM   #8
bobblehead
bobblehead's Avatar
Drives: warp speed
If it's proven that they actually put in the wrong oil, have them drained it immediately and also have the dealer noted onto your file, for any future warranty liability purpose ... just in case.
Thank you for this!
      05-21-2013, 01:27 PM   #9
wrsbmw
wrsbmw's Avatar
108
Drives: 2018 Ferrari 488 Spider
Glad you made this post. I just had my 1200 mile service done and made sure to see what oil they put in and it was 5w-30.
I think the car is faster after this service, it certainly seemed more responsive to the gas even in efficient mode.
      05-21-2013, 01:35 PM   #10
greentrbo95gst
greentrbo95gst's Avatar
1231
Drives: 21 M5 Comp
How did you drive the car during break in?
      05-21-2013, 01:49 PM   #11
Pazzo009
Pazzo009's Avatar
1110
Drives: X5M,M3(46&36),812SF
All I can tell you is on highway I get 22+ and I have burned 1.5 quarts in 6500 miles.
      05-23-2013, 10:55 AM   #12
mdosu
so what did your invoice-receipt say?
      05-23-2013, 06:23 PM   #13
MSportDC
///MSport-DC
MSportDC's Avatar
Finally got a copy of it - they had used 5w-40. :relief:
      05-23-2013, 07:05 PM   #14
mdosu
happy motoring!
