      06-14-2016, 02:23 AM   #1
Lucrecio84
Lucrecio84's Avatar
Drives: TTE92 m3/ F10 CP M5
Loud clicking noise from wheel well!
So I just bought a 2016 M5 competition package two months ago. Had to take it in now for the second time due to a loud ticking noise coming from the divers side wheel well. Only clicks when the wheel is turned all the way, not if driving straight or slightly turned. Anyone have or have had a similar issue?
GINTANI TWIN TURBO E92/F10 M5
      06-14-2016, 08:27 AM   #2
drbru
Drives: f10 m5
good be wheel bearings but first check all your nuts are tight (as mine were not!lol)
      06-14-2016, 08:42 AM   #3
Poleposition
Poleposition's Avatar
Drives: very well
Ive had this issue before and it was as simple as a rock stuck in the metal shield behind the brake disc. You have to get underneath the car and move it around. It's very flexible. Mine was in the rear.
2022 Individual M5 Comp
Venetian Violet
2021 X6M Comp
2024 i4 M50 on order
IG @purpleM5Comp_NY
      06-14-2016, 10:36 AM   #4
avi8tir
avi8tir's Avatar
397
Drives: ///M
same issue on my M6GC.... tiny pebble... took me weeks and weeks to figure it out!
      06-15-2016, 05:01 AM   #5
HappyMan
Drives: 2015 M5
Apparently almost all new M's have this issue. Clicking noise when turning the wheel to the right (in my case). Bmw Germany send all of us who have M's here this thing in the picture. This is a add on not a change. And this solves the problem.
This is add on not a change.
Sorry for the bad pic, my iPhone camera lens is broken.
      06-15-2016, 10:20 AM   #6
Lucrecio84
Lucrecio84's Avatar
Much appreciated, my service advisor called me this morning and said they are changing the wheel bearing. If that doesn't fix it then I'll bring this up to them. What is that piece?
      06-15-2016, 10:21 AM   #7
Lucrecio84
Lucrecio84's Avatar
They are changing the wheel bearing at the dealer so hopefully that's the solution
      06-15-2016, 04:06 PM   #8
HappyMan
Drives: 2015 M5
I don't know what it is but it's a solution. No need to change wheel bearing I think
      06-15-2016, 05:36 PM   #9
///PDDS
///PDDS's Avatar
Drives: 2016 M5 Comp
Hmm, I've heard this too when turning. I'll take it in. Squealing brakes, now this, UGH. Buuuuut.... this car is amazing!
2016 M5 Singapore Grey ZCP| Dinan Stage 2 | RPi GTM | STiR+ALP | OEM CF Diffuser | BlackVue 1CH | Coded Tricks
      06-15-2016, 05:57 PM   #10
Lucrecio84
Lucrecio84's Avatar
I also have problems with squeeling brakes, but whatever, as long as they get the clicking noise fixed I can live with it
      06-16-2016, 10:02 AM   #11
darrko
darrko's Avatar
Drives: 2016 M5 Comp. Ed.
2016 BMW M5  [0.00]
I had this issue recently but in the rear right tyre assembly. I tried to drive normally for a few weeks but then it just got too unbearable. It wasn't just clicking but click + creaking and would happen at all speeds, more noticeable when pulling away. This happened suddenly after about 6 months of perfect behavior.
Got an appointment and took it in. They kept it for a week and during the time I got impression they weren't really able to pin it down. Finally fixed it: loose strut.
Drives like a dream now. Again.
Current:
2012 520d
2016 M5 Comp. Ed.
2020 Porsche 911 Carrera S (retired)
2023 X5 xDrive45e
      06-17-2016, 11:41 AM   #12
Lucrecio84
Lucrecio84's Avatar
Yea my service advisor just called me and said the tech noticed it coming from both the passenger and driver side wheels. Ive only had the car a little more than 2 months. Oh and also they were able to identify the brakes squeaking from the rear. A little disappointed.
      07-08-2016, 01:31 AM   #13
Lucrecio84
Lucrecio84's Avatar
Thanks I appreciate the help. I'm about to take the car back for the 3rd time concerning the issue. This last time they said it was the wheel ybearings and replaced both of the front ones. Got the car back and it was ok for about a week then the noise came back. I'm going to show my service advisor these pictures. Hopefully this helps. Kind of ridiculous when you know more than the service advisor does
      07-08-2016, 01:50 PM   #14
net7
Drives: M5 2013
I too had this issue after an 800 mile trip. Every time I turned to the right I could hear a clicking noise.
The first dealer I went to said it was the strut bearing. I drove back home and went to a local dealer who said it was the wheel bearings.
Prior to bringing car to dealer for the issue, I washed the rims and it reduced the noise a lot (almost unnoticeable). They just replaced my wheel bearings, and there's no clicking noise at all now.
      07-09-2016, 04:54 PM   #15
Lucrecio84
Lucrecio84's Avatar
They just replaced mine and the noise is still there
      07-09-2016, 05:07 PM   #16
gmd2003
gmd2003's Avatar
352
It's not the bearings , it's the whole bearing hub assembly . The bearing literally has play in how it sits in the hub assembly . Just replacing the bearing won't fix it .
      02-17-2017, 08:38 AM   #17
rambino
M Master
rambino's Avatar
Drives: M6 / X6M
My M6 did this on both sides when cruising thru the canyons. Nothing to worry about, doesnt affect anything. The car is heavy, and under suspension load things stress. The noise never gets louder and again it affects nothing and goes away after things cool down.. its quite common, so just drive harder and forget about it Cheers
M History: E46 M3, E92 M3, E63 M6, F13 M6 Comp Pkg, E71 X6M
      02-17-2017, 01:17 PM   #18
belarus27
Drives: E550
Hard to forget something that is making an annoying sound , which shouldnt be there in the first place , no matter if its a civic or M5 , it still would drive me nuts.
      02-18-2017, 10:35 AM   #19
Lucrecio84
Lucrecio84's Avatar
My thoughts exactly which is why BMW bought the car back. I'll try again with the one that comes out at the end of the year
      02-18-2017, 12:14 PM   #20
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
There is a service bulletin on this. They need to remove the bearing , lubricate and reinstall it.
      02-18-2017, 12:31 PM   #21
Lucrecio84
Lucrecio84's Avatar
With mine, not only did they remove and reinstall the bearings. But replaced them completely. Still didn't fix it. Then they even changed the complete wheel hub and it still didn't work. Noise would go away for a couple days then come back louder and louder day by day.
      02-22-2017, 10:17 AM   #22
TopEnd
Drives: 2014 BMW M6 Gran Coupe
They bought the whole car back because of the noise?
