03-01-2015, 01:23 PM | #1 |
Rep 317
Clutch Temperature (overheating)
hey
it happens when i turn off the DSC completely , D3 mode ,Sport + throttle response , wet road and full acceleration from stand still ( no Launch Control) and then i got this warning message . anybody had this issue or know why ? |
03-01-2015, 08:56 PM | #2 |
Rep 365
Strikes me as odd to have this come up following a single hard acceleration, wet road or not. I would imagine that in the absence of ceramics, your brakes should be the first thing to give you a problem at the track w/ all nannies off. Would never expect to see this following a spirited run...I would have it checked out.
2015 ///X5M
2014 ///M6 (traded) 2014 ///M5 (traded) 2011 550i (traded) |
03-01-2015, 09:29 PM | #3 |
Rep 6,067
Whether it's LC or not, as long as you turn DSC OFF and floor the gas (at first gear from dead stop), you are putting maximum stress on clutch and transferring maximum torque to the wheels with no power cut off. How many miles you have on the clock?
03-02-2015, 04:27 AM | #4 | |
Rep 317
so the current dct gearbox that is installed is brand new ( it has 2875 miles on it) is there any software update or something for f10 m5 dct gearboxes? or maybe the dealer forgot something when they installed the new gearbox? |
03-02-2015, 06:30 AM | #6 |
Rep 388
transmission
If I may throw something in the mix here.
I do not believe that there is anything that has to do with temps, unless the car took a serious beating ( did it ??? ) In my opinion it is going to be a gremlin in the wire works ( software ). If the transmission works flawlessly, and there is nothing abnormal in the gear changes, sounds ( noises or such ). It will take some time to decipher but it is going to be something idiotic ( simple ). Hope that helps. |
03-02-2015, 06:30 AM | #7 |
Rep 317
well i drove like i said almost 3000 miles with it since the dealership installed it, the gearbox shifts flawlessly and its not jerky at all. like you feel its normal but only when i want to full acelerate from standstill with dsc off i get the warning.
03-02-2015, 06:33 AM | #8 | |
Rep 317
so no hard driving before. the gearbox doesnt feel strange when it shifts neither it produces noise, sometimes the car will bump when i put it in R coming from D. is this normal? |
03-02-2015, 08:30 AM | #9 | |
Rep 6,067
03-02-2015, 09:06 AM | #10 | |
Rep 317
03-02-2015, 06:05 PM | #11 |
Rep 603
When I see those ring taxis flying around, I can't see how the M5 would suffer from that unless there is more to this than meets the eye, ie. some mechanical issue that resulted during the DCT replacement.
03-02-2015, 09:25 PM | #12 |
Rep 365
I employed a hard break in on my M5 as have many others. Once my engine oil was to operating temperature, I let it fly...from mile 1. Never saw this error.
I agree, a checkup is called for here.
2015 ///X5M
01-15-2018, 03:04 AM | #13 | |
Rep 222
How the hell you put gearbox position P when engine running??????? M5 f10 |
01-15-2018, 09:51 AM | #14 | |
Rep 21
Then you re-ignite the engine, and it will start up and remain in P... until you touch the shifter. Short of that... I agree we have to use Neutral with the electronic parking brake engaged...(which is probably the equivalent of what is really going on when you shutoff and restart). |
01-15-2018, 03:20 PM | #15 | |
Rep 222
10-17-2018, 10:57 PM | #16 |
Rep 1
hello I have a f10 m5 and it gave me a warning saying that the transmission has high temperature since it is the second time that happens to me and I would like to know what could be causing that
10-18-2018, 09:03 AM | #17 |
Rep 294
I got this when my oem and Dodson clutch was slipping/burnt....I have the BBMR clutch now all is good.
Gone:2013 F10 M5-DCT-Montecarlo Pearl Blue-BBMR 800 Stage 1 system 700whp+(93oct) 2004 Lamborghini Gallardo-Manual-Giallo Midas Pearl Yellow-Modified 2018 Range Rover Velar S-White Last edited by steeve13m; 10-18-2018 at 12:34 PM.. |
