      03-31-2016, 05:15 PM   #1
financenick
Drives: BMW M5 F10 - 2016
Cheap performance upgrades for M5 F10
Ive just purchased a new 2016 M5 F10 and im pretty unhappy to see basic tuning mods priced so expensive.
EXAMPLE:
-Air filter upgrades seen for circa £1,600
-Rear exhaust box (muffler) deletes seen from £1,100
-UK remaps for £2,500
-Ram air scoops £300
So ive done some digging, and a lot of homework and found that you can get exactly the same as above for much less if you just use your head a little more creatively..
*Air induction kit (RAMAIR) 2 x UNIVERSAL 150mm dry cones with 80mm alloy necks £70 delivered
*Fastlane Styling (London) Supply and fit 2 x stainless steel 3.5” duel tips deleting back boxes £250
*Turner Motorsport tuning module 90+ BHP increase with full boost/ignition/fuel increases £500
*Ram air scoops bought from screwfix £4
Ive attached some pics of the above being fitted, the air induction kit replicates the popular BMS kit, and has no issues with heat soak releasing the extra power AND noise as some other induction systems still keep the filters boxed in - thus drowning out the harmonious wastage flutters.
Also the exhaust is an awesome upgrade, but we refined the mod by fitting heavy gauge closed cell sound proofing to the boot floor and under rear seats to eliminate “drone” which is actually the metals vibrating (and the annoying ASD) not noise from the exhaust exit – works a treat and only cost £40
PS: upgraded the rear tyres to 305’s which helped wheel spinning, but feel i still need to take it further with a track tyre like the Pirelli Trofeo R’s to really do the job properly, it’s the only thing letting this amazing car down now.
So call me a cheapskate (I don’t care) but I won’t throw hard earnt cash down the drain, so bring on the nah sayers to shoot me down !!
M5Rick60091.50
      03-31-2016, 08:05 PM   #2
Rearview
great looking car, mate! Nice work & responsible use of financial resources!!
      03-31-2016, 09:38 PM   #3
TheHouseWon
TheHouseWon's Avatar
644
Drives: 2013 M5
Very nice. I'm all about DIY, too.
How does the Turner Tuning Module Compare to BMS JB4 w/BCM?
      04-01-2016, 03:15 AM   #4
financenick
Thanks, yes the Turner module is supposed to be much better than the BMS as its corrects fuel mixture accurately and timing. Im told the BMS system lets the ECU try and adjust on its own and only turns boost up 3 psi
      04-01-2016, 03:16 AM   #5
boots
Curve Thrasher
boots's Avatar
623
It's not being called a cheapskate. It's called making your car the way you want it to be. Nothing wrong with that bro.
      04-01-2016, 03:37 AM   #6
drbru
Drives: f10 m5
What scary for me is that you are based in London, your car looks pretty much the same as mine and I have exactly the same thoughts as you.....
The thing that has been stopping me making mods though is the effect on warranty...Currently fighting a battle with Mondial/Allianz to get clarity over what happens to the warranty when you modify certain bits and not having much luck so far...
      04-01-2016, 03:41 AM   #7
drbru
Drives: f10 m5
.........would love to hear your exhaust if you have any clips you could post up as well please
      04-01-2016, 03:42 AM   #8
boots
Curve Thrasher
boots's Avatar
623
Mstmng is also in London. You guys should hear his car also.
      04-01-2016, 05:11 AM   #9
drbru
Drives: f10 m5
Heard his...Its bloody mental!
      04-01-2016, 08:31 AM   #10
financenick
Yes i hear you, however it only affects the warranty if they can prove (without any doubt) that the mod was directly responsible for the failure / warranty claim, and exhaust and air filters shouldn't shop up on anyone's radar.
      04-01-2016, 09:07 AM   #11
drbru
Drives: f10 m5
What you describe above is how it should work and I believe this is the case with the original manufacturers warranty however its a different story with the extended BMW warranty which is essentially Mondial/Allianz..
They state in their terms and conditions that any modifications with non bmw parts will invalidate the entire warranty of the whole car! mental i know! but this is what I am currently fighting and ive used examples like "if I paint my wheels pink will that invalidate my entire warranty"
When I get to the bottom of it I will post on here for all UK owners to view as its a very different situation (apparently) compared to the rest of the wolrd
      04-01-2016, 11:07 AM   #12
financenick
Ahh man, i see your point, and wish you luck, insurance companies always try to wiggle out
      04-01-2016, 01:03 PM   #13
financenick
Will post the exhaust vid tomorrow
      04-02-2016, 03:46 AM   #14
boots
Curve Thrasher
boots's Avatar
623
Awesome. I was the one who inspired him to buy the same equipment that I use in my car. So now you know what mine sounds like then. . Only diff between our cars are the dp
      04-02-2016, 07:09 AM   #15
ketema
Drives: 2015 M235i
Would love to hear your car
2015 6M Black Sapphire Metallic | MPE w/Carbon Tips | Digital MP Steering Wheel | Carbon Interior | StopTech Slotted Rotors | Pagid RSL1 Race Pads | KW Clubsport Coilovers | DINAN Stage 2 and Carbon air intake | Clutch Masters Lightweight Performance Clutch and Flywheel | Hotchkis Anti-Roll Bars | Enkei RS05RR 18" Racing Wheels
      04-02-2016, 11:41 AM   #16
allmotor_2000
1087
Drives: 2018 RS3, 991 Turbo
Right thinking - although you could have got the same bang for less.
K&N drop-ins on stock airbox - $45
Forget about exhaust - does nothing
BMS JB4+BCM is $700 and you will be at 680+whp
      04-02-2016, 11:46 AM   #17
allmotor_2000
1087
How is it correcting fuel mixture and timing specifically? Looking at the harness it seems to have a RPM pickup but that's about it. BMS does that (and more) via CANBus.
Don't believe all the Kool aid guys.... not saying that module doesn't work; just need to be very clear how it works compared to everything else.
Even the flash tunes don't 'correct' timing and mixture. They have targets for load and a target for AFR/Timing and it will always try to achieve those under the various load conditions.
      04-03-2016, 09:56 AM   #18
financenick
      04-03-2016, 02:10 PM   #19
drbru
Drives: f10 m5
very nice! sounds just as good as systems that cost more than ten times the price!
      04-04-2016, 07:25 AM   #20
///Mpower///
Sergeant
///Mpower///'s Avatar
Drives: Spiritedly
looks and sounds phenomenal...well done.
_______________
///M
'16 535i Xdrive Msport
'13 M5 - Singapore Gray, Black Ext. Napa, Dinan FF Exhaust, much more to follow.
'12 X5 M - Carbon blk, Cinnamon interior <retired>
      04-04-2016, 07:42 PM   #21
Jay-K
Jay-K's Avatar
Indonesia
384
Drives: Slow
nice work!
      04-06-2016, 04:24 PM   #22
drbru
Drives: f10 m5
SNAP!
and in London.....
m5 f10 performance upgrades, m5 f10 tuning
