10-13-2018, 04:45 PM | #1 |
Rep 42
Check engine light - fuel grade change
Check engine/emission light came on yesterday. I always use 94 oct fuel (Petro Canada), but had to fill up yesterday with 91 octane (Esso), tank was empty (fuel reserve light, 50km to empty). Light came on after the second time I started the car after fueling up with 91 oct.
Could the change in fuel grade cause this light to come on? Two other potential issues causing this: Last week I had the add 1 litre of oil notification come up. I added 1 litre right away and warning went away. Changed the brake fluid in July, notification said was due in June. Dealer forgot to reset notification so it still says overdue even though the brake fluid has been changed. Need to get back to dealer for them to reset soon.. Don't think those two issues are causing the check engine light to come on but I'm just putting it out there.. Car is 2013 with 19,000 kms on it. Thanks. |
10-13-2018, 06:04 PM | #2 |
Rep 606
Rather than guess, you should get the codes read out. Then report back here with what they are. You may have a misfire that the low octane fuel is causing. Not the fuel itself, but potentially a bad spark plug showing itself now with different fuel. Just a thought.
M5_Gator14.50 |
10-13-2018, 06:18 PM | #3 | |
Rep 42
10-13-2018, 07:40 PM | #4 | |
Rep 101
I see that you are in Canada but in the U.S. all of our major parts stores will read OBD II codes free of charge without even purchasing anything. Not sure what your exact options are up there but I hope this helps.
2013 Black Sapphire Metallic, Sakhir Orange Interior, DCT
10-13-2018, 08:57 PM | #6 | ||
Rep 42
10-13-2018, 09:00 PM | #7 | |
Rep 42
I'll look for a reader either tomorrow if part stores are open or on Monday. |
10-14-2018, 07:02 AM | #8 | |
Rep 606
Report back once you've had a chance to scan it. Good luck |
M5_Gator14.50 |
10-14-2018, 09:22 AM | #9 | ||
Rep 42
Did some research last night on OBD2 scanners. Decided to go with one with good reviews and middle price point - the BlueDriver Bluetooth professional OBDII scan tool for iPhone.. Amazon Prime free one day shipping - should come in later today. Will post results once available. |
10-14-2018, 04:45 PM | #10 |
Rep 42
Code is P0161 - O2 sensor heater circuit bank 2 sensor 2.
Does anything need to be changed? I also ran mode 6, freeze frame, and full scan reports.. Found this thread regarding the sensor code.. maybe bad fuel when I filled up with 91oct? Not sure if I should change sensor or wait until I fill up with 94 oct again. Should I clear the code when I do fill up and see if it comes back? Add any fuel treatment?? Check Engine Light: Code P0141 https://f10.m5post.com/forums/showthread.php?t=1383729 Edit: more info added |
10-14-2018, 05:02 PM | #11 | |
Rep 812
Formally known as BMWM3NYC
M5_Gator14.50 |
10-14-2018, 05:07 PM | #12 | ||
Rep 42
10-14-2018, 05:11 PM | #13 | |
Rep 812
You can clear code right now. Then take your drive. It might come back on again depending how bad that gas was.
M5_Gator14.50 |
10-14-2018, 05:12 PM | #14 | |
Rep 42
So no need to clear the check engine light, it should go away by itself? |
10-14-2018, 05:16 PM | #15 |
Rep 812
When I did mine, I cleared it with code reader. Then after my drive I checked to see if code was still triggering before the light came back on (Usually 3 times makes light come on) But the code never came back.
M5_Gator14.50 |
10-14-2018, 05:19 PM | #16 | |
Rep 42
10-14-2018, 05:20 PM | #17 |
Rep 812
No problem.
10-15-2018, 09:47 AM | #18 |
Rep 19,556
Same happened to me, switched to Momentum 99 from Shell v p and light coming on for two short periods then went back to Shell and it went away permanently.Can only think that Momentum 99 (which is normal uld 95 with 5% methane added to bring it to 99) hasn't got the cleaning and lube properties of Shell v-power.
M5_Gator14.50 |
10-15-2018, 10:19 AM | #19 |
Rep 606
OP - sounds like it will work out just fine for you! You get to learn about the code diagnostic process and added to your abilities with the new scanner.
I agree with others that you should be fine to clear the code and replace the fuel. Should be good to go. |
M5_Gator14.50 |
