05-25-2018, 09:00 PM | #1 |
Rep 430
Gentlemen Function DIY
Gentlemen function is standard on 7 series and allows you to move the passenger seat while using the driver controls. Need to source a part and some simple coding via bimmercode. Special thanks to member HEROFMINE for the instructions on how to do..
1) Source Part Left Door Memory Switch Part 61319215758; I found on ebay for $53 2) Remove existing door switch from car using simple plastic prying tool - it pops out pretty easily and don't need to remove door panel. 3) Switch the plastic back plates on the two panels - new part came in white but it needs the blue back to function properly. It's held on by simple plastic pins. 4) Reinstall memory switch in car by simple plug connection 5) using Bimmercode, you must Activate Gentlemen function for BOTH passenger and driver seat. Menu looks like 3000 SM_Global>Gentlemen>Aktiv 6) All Done! now you can move passenger seat from your driver controls using L2 button. |
07-07-2018, 11:28 AM | #4 |
Rep 1,840
Amazing find.
07-10-2018, 12:50 PM | #5 |
Rep 25
Nice write up! Performed this mod yesterday. You don't realize how convenient this is until you have a guest passenger with their knees in the dash and stumbles around to adjust the seat. Super easy to do. Thank you!!
07-30-2018, 03:25 PM | #6 |
Rep 9
You can also use E-Sys for coding.
SM [6d] => 3000 SM_GLOBAL => Funktionen => GENTLEMAN => Ausgelesen => active SM [6e] => 3000 SM_GLOBAL => Funktionen => GENTLEMAN => Ausgelesen => active Some screenshots from E-Sys: https://app.box.com/s/z6um7wr0aj4tf98plc7vtk2fokg8v7mb https://app.box.com/s/3klwmqusydnwh02y1d5ydvmdv72evs1a https://app.box.com/s/ot36htpzufuad04ujpo5cds09o6ua20m https://app.box.com/s/3yccmtkjp2iy3xsae46hwa2z0jcxap6m |
07-30-2018, 04:26 PM | #7 |
Rep 385
Cool. Got mine in the mail, will code this up tonight.
Incidentally, we might want to call this something else besides "gentleman's function", because I think that describes something completely different... |
08-30-2018, 12:38 PM | #8 |
Rep 598
Looks like this part was superseded by 61319361190.
Do these controls allow the driver to move the passenger seat in all directions or just engage presets for the passenger? |
08-30-2018, 01:24 PM | #9 |
Big girls don't cry.
125
Rep 507
In my F02, you press the L2 button and then you're able to move the passenger seat in all directions via the controls on your driver's seat.
08-30-2018, 09:11 PM | #10 | |
Rep 385
09-05-2018, 09:37 PM | #11 |
Rep 598
10-11-2018, 09:37 AM | #14 |
Rep 7
Hi guys. I tryed this retrofit, but somethings feels like missing, I can only see Driver side modul and I don’t see any seat Passenger modul when I tryed to code gentlman function there. Feels strange that my car don’t have a module on passenger side.
My car is with standard M5 f10 seats, only Memory on driver side with 1 and 2 button. The passenger does not have any Memory at al, but it is electric seats. Someone can help me whats the fault? Regards |
12-06-2018, 10:58 PM | #15 | |
Rep 816
12-20-2018, 08:44 AM | #16 | |
Rep 107
In terms of your issue, I thought the passenger memory was standard and not part of the executive package. When I was programming via Bimmercode, I coded the passenger side module first and when I went back to the root menu in Bimmercode, the driver side module option disappeared. I just disconnected the app and restarted it and the driver side module option appeared again. Did you try restarting the app? Do you know if you have the executive package on your car? Heated and ventilated seats along with comfort access is part of that package but doesn't say anything about the memory passenger function. Having absence of that may be the mitigating factor in getting the gentlemen's function working. |
02-05-2019, 02:57 PM | #17 |
Rep 402
Drives: 2015 550i xDrive
Is this suppose to also allow us to turn on/off the massage function on the passenger seat as well? I installed and coded mine and it allows me to do all the functions on the passenger seat except turning on/off the massage function.
Instagram @_gr8dane
2015 550xi - current 2015 428xi - retired 2010 328xi LCI retired |
02-08-2019, 08:29 PM | #18 |
Rep 430
believe it just allows movement and not the massage function.
marmit2017107.00 |
02-22-2019, 08:07 PM | #20 |
Rep 430
04-11-2019, 11:21 AM | #21 |
Rep 951
This is a really cool and functional feature..Glad it was a quick retrofit..
(Sorta reminds me of those MB controls on rear passenger side seats in Chinese cars where the rear passenger can move the front passenger seat however they need to) |
04-11-2019, 11:22 AM | #22 |
Rep 951
