      10-12-2013, 10:36 AM   #1
RoboM5
RoboM5's Avatar
Drives: 2013 M5 - Space Gray
12mm or 10mm front spacer width pros and cons
I'm lowering the car with HR springs and spacers at EAS here in Orange County and wanted to know if I should go with 12mm or 10mm front spacers. It looks pretty clear to go with the 10mm on the rear.
The car has stock 20" wheels and I don't plan and upgrading the wheels at this point. Thanks.
      10-12-2013, 10:43 AM   #2
M5LA
Drives: 13 F10 M5 Alpine White - sold
I just had the H&R springs and spacers installed at EAS last week, 12 in front and 10 in the back. No problems at all.
If you go 10 in front, it may be too small that you will not even notice.
      10-12-2013, 12:19 PM   #3
BIG~BLUE~BMW
Drives: Nissan GTR,F10 M5
I did 12mm all the at all four corners.
      10-12-2013, 12:36 PM   #4
RoboM5
RoboM5's Avatar
Looks great Big Blue BMW. Thanks for sharing the photos.
      10-12-2013, 04:00 PM   #5
BIG~BLUE~BMW
No problem and believe me the rear end looks way better/fatter
      10-12-2013, 05:59 PM   #6
RoboM5
RoboM5's Avatar
Did either of you wait a few days for the suspension to settle before doing doing the alignment?
      10-12-2013, 06:35 PM   #7
pochesq
pochesq's Avatar
Drives: 2013 M5
After installing H&R springs I waited about 1 week or 200 miles before an alignment.
Current ///M: '13 F10 M5, Sapphire Black, Eisenmann Race Exhaust, CF Delete, H&R Sport Springs, iND Cosmetics, Escort 9500ix hardwired, 21" Vorsteiner VFF-103 w/Michelin PSS, RKP Front Lip, Challenge Rear Diffuser, M Illuminated Door Projectors, and LCI M Performance Black Grills
'15 i3 BEV
      10-29-2013, 07:49 PM   #8
RoboM5
RoboM5's Avatar
Follow-up: I used the 12mm front and 10mm with the HR springs and am very pleased. There is no difference in ride quality and the lower wider stance looks great. However, there was a slight shaking in the steering at 90+ MPH, which was later eliminated by have the tires balanced. I find it strange that a car with only 5k miles that had no shaking pre springs and spacer then needed to be rebalanced after the new springs and spacers.
