      04-19-2014, 01:32 PM   #1
M5Rlz
Drives: R8, f10m59(Rip), m4, GTR
Caked in Brake dust
Can anyone recommend a way to get the caked in stuff off? I'm not opposed to sitting for hours scrubbing, but I definitely don't want to damage the finish by using like sand paper or something lol
      04-19-2014, 02:15 PM   #2
is300wrx
Drives: 2014 M5
Try Sonax Full Effect and scrub using wheel brush.
      04-19-2014, 02:27 PM   #3
M5Rlz
I read up on that and heard its good I just can't find it at any local shop and would have to order anything you know of I could pick up at like advanced auto parts?
      04-19-2014, 03:51 PM   #4
is300wrx
Drives: 2014 M5
Unfortunately, I don't believe AutoZone or Advance Auto Parts carry this item. I ordered a jug of this product from detailerdomain. Great stuff!
      04-19-2014, 03:53 PM   #5
is300wrx
Drives: 2014 M5
https://www.detailersdomain.com/mobile/home.asp#page-84
      04-19-2014, 06:03 PM   #6
skypx
Veteran U.S. Army
skypx's Avatar
Germany
60
Drives: ///M
If you have an AutoZone close by this stuff works well.
Hot Rims All Wheel Cleaner.
      04-19-2014, 07:24 PM   #7
Detailers Domain
Detailers Domain's Avatar
Drives: 20 M2C / 22 X3MC
get some good wheel cleaner - like Sonax Full Effect, make sure you get some good wheel brushes, since the brake dust appears to be caked on you may need to repeat.
      04-19-2014, 08:49 PM   #8
eleven11
eleven11's Avatar
Drives: -F85 X5M-
Sonax. Wheel Brush. Pressure washer. Repeat.
2017 X5M - Current
2017 F31 Wagon - Current
2014 M5 ZCP - Retired
2011 135i Coupe - Retired
2007 335i Sedan - Retired
      04-20-2014, 10:28 AM   #9
Mbdurham17
Mbdurham17's Avatar
159
Drives: 2016 M5 CP
Off topic but curious about the green valve stem caps. Were they OEM install?
      04-20-2014, 10:40 AM   #10
B-1Pilot
Yankee Air Pirate
B-1Pilot's Avatar
151
Drives: '14 M5 w/CP
Lots of BMW dealerships are doing this now and it means the tires are filled with pure nitrogen instead of regular air. It is believed by some nitrogen leaks slower out of the side of the tire than regular air does, and that the oxygen component actually breaks down the rubber faster. This may be good for a classic car on old original tires that just sits. However for new cars that are used more like daily drivers it's basically useless. Besides normal air is something like 78% nitrogen anyways-the cost associated to fill with nitrogen is not commensurate with any perceived or actual benefit. I made BMW take the green caps off my three series and didn't even put nitrogen in my M5 just because I didn't like the color of the caps
http://blog.gasbuddy.com/posts/Tire-...32662-482.aspx" rel="ugc" target="_blank">http://<a href="http://blog.gasbuddy...2-482.aspx</a>" rel="ugc" target="_blank">http://<a href="http://<a href="http...2.aspx</a></a>
2020 ///M5 || 2019 540XI || 2014 ///M5 w/CP || My Epic ED trip report|| || 2009 BMW R1200RT
      04-20-2014, 10:53 AM   #11
Palomequet
Drives: BMW F10 M5
Thank you
Mistery solved
      04-20-2014, 11:43 AM   #12
Mbdurham17
Mbdurham17's Avatar
159
Drives: 2016 M5 CP
Thanks I had never seen this before and had no idea.
      05-05-2014, 05:34 PM   #13
Bluehorseshoe
Bluehorseshoe's Avatar
305
Drives: M5 CS
If I had to do it over I think that I would go with Ceramic brakes just to avoid this shit from happening.
      05-05-2014, 05:45 PM   #14
eleven11
eleven11's Avatar
Drives: -F85 X5M-
I'm sure for $9000 a local detailer will keep those wheels nice and clean for you, year round.
2017 X5M - Current
      05-05-2014, 11:03 PM   #15
M5Rlz
Yeah it worked 1 round no brush got like 50% of it off 90% with second scrub and soft billow pad, and its like 97/98 on the third one... The sonax stuff definitely cleaned it up well!
      05-13-2014, 12:23 AM   #16
JLu
Drives: M5
I dont really get the logic by BMW. My first car was 328i. I had it for 1.5months. I literally never clean the wheels and the car, and that car made no noise at all. However, the brakes from M5 is bugging so much ,even if I clean the wheels thoroughly.
      05-13-2014, 12:24 AM   #17
JLu
Drives: M5
Well no doubt, those CB cost another 10gs. I'm too poor to buy them.
      05-15-2014, 11:00 AM   #18
m34SPD
Picture me rollin'
m34SPD's Avatar
Drives: e36 m3, e39 m5, f80 m3 CS
Try a claybar and Iron X.
      09-28-2014, 12:22 PM   #19
Valnic
BMW Fan
Drives: BMW M5
http://blog.gasbuddy.com/posts/Tire-...32662-482.aspx" rel="nofollow" target="_blank">http://<a href="http://blog.gasbuddy...2-482.aspx</a>" rel="nofollow" target="_blank">http://<a href="http://<a href="http...2.aspx</a></a>
Sorry to dig up an old post but is this even true? When I was in the Navy, we used nitrogen in the tires to prevent inflation issues due to the air temp at ground level opposed to low temperature while flying. I would guess that nitrogen in car tires helps keep the same temperature after the tires have warmed up from use and also helps losing pressure when you have cold mornings. So in general, there is benefit and it's not "useless" in cars.
