08-01-2013, 05:09 PM | #1 |
Rep 602
DCT power shifting: bad?
when upshifting I don't take my foot off the gas. with WOT this results in a very abrupt clunk when the gear slams into place, which scares passengers, which i like. does anyone know if this is detrimental to the clutch?
08-01-2013, 05:22 PM | #2 |
dentite
339
Rep 758
Drives: 718 GT4, M2C, JLU392, e92 M3
I don't think it is although it feels like its harsh for the transmission
08-01-2013, 05:47 PM | #4 |
Rep 1,489
BMW Performance Center instructors said keep the foot down while shifting. Put me in the "love the clunk" camp.
Current: '16 GT4
Past ///Ms: '13 F10 M5, Alpine Weiss III/Sakhir Orange Full '10 E60 M5, Space Gray/Black |
08-01-2013, 05:53 PM | #5 | |
Rep 1,027
In my experience, the passengers are more scared by the acceleration of the car than the clunk. If you don't have DTC on, the back end can get squirrelly in second and third gears. I was just doing this last night getting on to I -35 from a 50mph running start. I was in 3rd at the end of the entrance ramp and floored it from about 55-60. As I was shifting to fourth as described, the back end broke loose a bit. I cut across two lanes to the far left lane and I was at 100 when I got in. I was by myself though. |
08-02-2013, 12:39 AM | #8 |
Rep 370
The ENTIRE point of dct is to provide uninterrupted power through changes which means you need your foot down. it is not harsh at all on the tranny as it is meant for that. In the m3 on S5/6 it is absolutely violent and just insanely makes the car slam into gear. It is absolutely awesome!
08-02-2013, 12:59 AM | #9 |
Savoir Faire
74
Rep 1,772
S6 mode on the E60 M5 was far more violent. Felt like the diff was gonna fall off But don't lift, otherwise you lose the boost you just built up!
Sold:Imola Yellow RS4-KW V3|MTM 10mm spacers|Hotchkis rear sway bar|APR Stage 1|Milltek Catless|RNS-E|Euro RS4 Flat bottom Steering Wheel Sold:E46 323i |
08-02-2013, 04:19 AM | #10 |
Rep 1,319
What settings do you have on ?. I feel S2 is the sweet spot, if you dont like the thump on the gearchange. Sometimes i feel S3 unsettles the car a little, compared to S2.
08-02-2013, 10:04 AM | #11 |
Rep 2,245
Ive never lifted my foot off when shifting, I always assumed with DCT that was the point. The DCT is nothing compared to the violence of SMGII in my e46, totally miss that.
2016 991.1 911 Carrera GTS
08-02-2013, 11:07 AM | #12 |
Rep 222
Dual clutch for a reason... Hammer on it!
08-02-2013, 12:06 PM | #13 |
Rep 806
Why on earth would you lift between shifts? That would be defeating the whole concept of the DCT. Hammer down!
08-02-2013, 12:45 PM | #14 |
Rep 602
dudes, I don't lift off. I wasn't asking who lifts off or not, just if anyone had any technical info on clutch/tranny wear. thanks to those who answered my question. m power.
08-02-2013, 01:18 PM | #15 |
Rep 380
dont let off. it's an automated transmission. the faster the shift the longer the clutch will laster ironically.
slower shifts = more friction time which as a result causes heat which as a result burns clutches...
2008 M3 Sedan + catless + Tune 2012 CLS63 AMG 2014 M6 Coupe + catless + KW V3 2015 Porsche GT3 , 2015 M3, all stock, 1/1 Space Grey |
08-02-2013, 02:08 PM | #16 |
Rep 7,885
Do you guys think that downshifting a lot is bad for the clutch/DCT?
I usually like to drive in S2 or S3 a lot and I like to downshift the DCT whenever I'm decelerating to a stop or a red traffic light because I like to hear the exhaust crack on each downshift with the Straightpipes. Does anyone think this is bad? My DCT seems fine and shifts smoother than ever.
08-02-2013, 02:27 PM | #17 | |
Rep 1,489
Current: '16 GT4
08-02-2013, 02:47 PM | #18 | |
Rep 602
08-02-2013, 03:04 PM | #19 | |
Rep 602
08-02-2013, 03:19 PM | #20 |
Rep 1,489
Absolutely correct about wear based on shift speed. I got to thinking about this. Isn't shift speed dependent on the drivelogic setting, not torque being passed through the transmission? I.e., 1 being the smoothest shift (the longest engagement) vs. 3 being the quickest (shortest engagement). So less wear on the clutches when using 3, but more work for the DCT pump. Vice-versa for 1.
When you lift, it doesn't change the shift speed, right? It just changes the torque on the input shaft. While there may be a minute difference in engagement speed (due to the potential increase clutch slippage) I'd think it'd be too short to be relevant, and, the torque would be passed to the inner input shaft immediately. Either way...better to not lift. Another benefit is near constant power to the wheels which is what also a big plus for the DCT!
Current: '16 GT4
08-02-2013, 04:56 PM | #21 | |
Rep 602
08-02-2013, 06:53 PM | #22 |
Rep 4,106
Are you guys still holding the brake pedal down when stopped?
I remember in the e60 if you didnt press the brake pedal down when stopped the clutch disk would wear out.
