      12-31-2015, 03:35 PM   #1
///Mpower///
Sergeant
///Mpower///'s Avatar
Drives: Spiritedly
Question "Engine temp -- Drive Moderately" What the...
Driving a 2013 M5 with 15K miles on it. Never saw this warning before. Was driving very mellow for about 25-30 miles. Parked the car for about 30 mins, then when I started her back up, this message popped up. Obviously, something's up with the coolant system.
Anyone ever seen this message? ...when driving mellow and NOT beating on it?
Called my SA and taking it in on Monday.
Concerned.
_______________
///M
'16 535i Xdrive Msport
'13 M5 - Singapore Gray, Black Ext. Napa, Dinan FF Exhaust, much more to follow.
'12 X5 M - Carbon blk, Cinnamon interior <retired>
      01-01-2016, 12:24 AM   #2
NightM
NightM's Avatar
450
Drives: Bmw
Check coolant level. If its full could be waterpump or thermostat
      01-01-2016, 07:27 AM   #3
TrevorM3
Drives: 6.3 AMG
warranty, or no?
      01-01-2016, 10:37 AM   #4
mr_djurgarden
mr_djurgarden's Avatar
Sweden
173
Drives: 2018 M5 F90
I have got the message "Drive Train" please drive moderately
It was the fuel. I mixed different fuel qualities when driving in different countries
2018 M5 F90
2015 M5 F10 Competition Package
2012 M5 F10
      01-02-2016, 08:49 AM   #5
///Mpower///
Sergeant
Drives: Spiritedly
Originally Posted by TrevorM3
warranty, or no?
Yes. Warranty good to 2019 or 100k miles.
_______________
///M
      01-02-2016, 11:03 AM   #6
phil_
Drives: Panamera Turbo S
I got the same message a month or so back. I drove for about 10 minutes stopped for an errand and when I started the car back up the message came up. It was -5C outside and oil temp was below normal.
Error went away when I re-started the car and hasn't come up since. I didn't bother with a service appointment.
      01-03-2016, 02:49 PM   #7
///Mpower///
Sergeant
Drives: Spiritedly
I just got the "drivetrain malfunction - drive moderately" message today. Last week was the "engine temp" message. Taking to SA tomorrow. Hoping it's just crappy fuel. Just got this car and issues issues issues. Not good.
_______________
///M
      01-04-2016, 06:04 PM   #8
///Mpower///
Sergeant
Drives: Spiritedly
Car is with the SA at the moment. Will update once I find out.
_______________
///M
      01-04-2016, 09:33 PM   #9
josec70
josec70's Avatar
Concerned.
I had the same message on my previous M5 which was a 2013. Although the message went away I clearly remember the car being at the dealer for several days. One of many issues I had with my 2013; good luck man.
Now in a 15; no issues at 2k miles.
      01-09-2016, 10:02 PM   #10
///Mpower///
Sergeant
Drives: Spiritedly
Concerned.
Car back from SA. Their finding was that the coolant level was low but I'm not 100% convinced. Isn't there a "low coolant" alert?
_______________
///M
      01-09-2016, 10:55 PM   #11
nynd
Drives: X7 M8 Convert
Other question would be why low? Was there a leak?
      01-10-2016, 06:14 AM   #12
DCT OFF
DCT OFF's Avatar
62
Drives: 2014 435i M sports,2013 F10 M5
2013 F10 M5  [0.00]
Yes there is a coolant alert that's warn you when it's low.
      01-10-2016, 12:35 PM   #13
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
By chance was the ambient temperature low? I've seen this message twice and both times were when I was in a cold environment and driven just enough to begin to warm up the fluids before shutting it off. Upon return, message appeared. Last time was a few days ago, so popped the hood and felt around. Everything that's usually hot was ice cold except for the metal coolant lines.
I think it's just a reminder that the car has cooled well below normal operating temps.
      01-10-2016, 07:23 PM   #14
///Mpower///
Sergeant
Drives: Spiritedly
Yep. That was the exact temp scenario...and same thing with the start and stop. SA reset everything, added coolant and haven't seen the messages since.
_______________
///M
      01-11-2016, 03:48 PM   #15
PatrickC23
PatrickC23's Avatar
2013 BMW ///M5  [0.00]
I've gotten the coolant alert, if I'm not mistaken coolant shrinks when it's very cold out. If that's the reason it should correct itself.
      01-11-2016, 05:09 PM   #16
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
This isn't really about the coolant level being low or not. For those who had E39, E46, E60, or E9x ///M cars (and those who didn't for that matter) should remember the variable redline limiter that adjusted based on fluid temperatures. Apparently several lawsuits were filed and the feature no longer available or implemented. This "warning" is just what is put in place of instead. For whatever reason it only appears when the ambient temp is low and the oil filter bypass valves have closed and are then again opened within 30mins approx.
      01-11-2016, 07:57 PM   #17
///Mpower///
Sergeant
Drives: Spiritedly
So you don't see this warning in the summer?
_______________
///M
      01-11-2016, 08:48 PM   #18
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
Home is Miami where all we have is 360 days of summer and 5 days of not as hot. It's only when I've driven to cold climates in winter that I've seen it appear and only after a drive long enough to make the oil temp move a tiny bit, shut down, then return quickly and restart.
S63 has oil filter bypass valves that activate when the oil temp/ambient temp is below a certain point to ensure proper lubrication of critical components.
