      04-29-2015, 11:44 AM   #1
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
M5 F10 LCI steering wheel
Quick question for M5 owners.
The V in the steering wheel trim, can you see through it.
Is the rear of the steering wheel covered or is there a gap to line up with the trim?
2014 M5
1990 E30 318i Touring
1999 E38 728i -sold
M235i - sold
Activehybrid 5 - sold
      04-29-2015, 11:45 AM   #2
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
Basically is the rear cover all one piece or does it have a cut out to match the front trim V section?
2014 M5
1999 E38 728i -sold
M235i - sold
      04-29-2015, 01:09 PM   #3
SteveC
Drives: M5
The V goes all the way through. i.e you can see the pedals when you look through the vee
      04-30-2015, 05:06 AM   #4
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
I'll need a M 5 rear cover then.
Current non M5 version is solid.
2014 M5
1999 E38 728i -sold
M235i - sold
      06-17-2015, 01:26 AM   #5
celicatoe46m3
Drives: E60 M5 & E46 M3
Is this wheel a simple swap? No coding needed for non LCI cars?
      06-17-2015, 03:53 AM   #6
Goranot
Drives: Bmw m5
Lol. Simple swap?
Will require new airbag
Rear cover 32307848270
Connecting line 32307848332
Set of switch panels 61317849410
Set of shift paddles 61317847210
And a new switch unit which will be required for performance wheel with display
61319354047
Several members on here are retrofit experts so will correct above info if have omitted any parts
      06-17-2015, 03:59 AM   #7
E90Fleet
South Africa
1312
No coding needed, but if you dont already have the round airbag steering wheel you will need a c ouiple extra things like a new airbag, lane departure warning vibration generator, multifunction buttons ect ect
      06-17-2015, 02:41 PM   #8
celicatoe46m3
What's the part # for the airbag? And at the end of the day, what's the total cost?
      06-17-2015, 02:51 PM   #9
E90Fleet
South Africa
1312
32307845796 for airbag
Airbag around $1,000 US and wheel also about $1,000 US
Then you need the buttons ect ect
      06-20-2015, 03:00 AM   #10
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
Got the rear cover sorted.
2014 M5
1999 E38 728i -sold
M235i - sold
      06-20-2015, 03:01 AM   #11
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
Can see the difference here between M5 and M sport.
2014 M5
1999 E38 728i -sold
M235i - sold
      06-20-2015, 04:54 PM   #12
E90Fleet
South Africa
1312
Thanks for the pics.
Exactly what the parts system shows
      06-20-2015, 05:06 PM   #13
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
I never picked up the difference from realoem.com website.
But seems obvious now.
2014 M5
1999 E38 728i -sold
M235i - sold
      06-21-2015, 08:14 AM   #14
E90Fleet
South Africa
1312
Yes, its easy to miss unless you look side by side
(M5 vs 550i)
      02-26-2016, 11:50 AM   #15
F10530dmsport
Drives: F10 530dmsport
Hi
I have a LCI F10 sport steering wheel with airbag which I want to retrofit to my 2010 F10msport. On the rear of my existing I have a yellow wire with a metal sleeve which connects to back of airbag - I don't have this on the round airbag and was wondering if it's needed. Pls advise
      02-26-2016, 03:39 PM   #16
beemarman
Drives: BMW M850ix Convetible
Originally Posted by F10530dmsport View Post
Hi
I believe you can use that plug on the round airbag.
      09-23-2021, 01:26 PM   #17
kelson teh
Drives: bmw f10 535i
im using a LCI m sport steering, i would like to have the front trim which have the V shape . anyone here could get me the part number? as i already have the rear from the post above....
      09-23-2021, 06:11 PM   #18
AlisterB
Part numbers should be as follows:
-32307846029: Front decorative trim cover piece for the front lower section of the steering wheel.
-32307848270: Rear cover to the back of the steering wheel
