05-02-2017, 05:44 AM | #1 |
Rep 1,857
Oil drain plug washer
Questions guys, I just had oil changed today, and when I walked by to check on the car, I noticed there was a small washer and small o-ring left on the tool cart. I asked the mechanic why weren't they used, he said for F10 M5, they weren't needed, they were for the E60 M5 because it has two drain plugs.
So only the big o-ring and big washer was used on the F10, is this true? |
05-02-2017, 06:37 AM | #2 |
Rep 1,857
Searching around the net and looked under the car, I am pretty sure there is only one drain plug. So it's probably true the small washer and o-ring is not needed.
08-04-2019, 05:05 PM | #3 |
Rep 623
Just curious, anyone have issues with the washer that comes with the Mahle filter to be too big for the oil drain plug?
2013 M5 Space Gray, Piano Black|Night Vision|Every option|6MT|RW Carbon front Lip|Vorsteiner Rear Diffuser|
2019 x7 50i White, Loaded | chrome delete | black grill | Previous: 2015 X5 Graphite, |All options| - 2014 435i Xdrive Msport, |Fully Loaded|6MT|FBO|JB4|Front,side,rear lips/spoilers|- 2015 320i Xdrive, |Wife's beater| - 2008 535i Xdrive |
08-07-2019, 10:09 PM | #5 |
Rep 623
Thanks!
03-07-2020, 01:02 PM | #6 |
Rep 11,891
The small copper washer is the correct one to use for the drain plug. When you buy a change kit with the filter, it comes with all 4 rings. I only use the smaller copper and large rubber. Not sure what the other two are for
05-20-2020, 09:10 AM | #7 |
Rep 47
2015 M5 CP - Alpine White - My joy ride
2013 LS 460 - Pearl White - Wife's 2007 M5 - Black Sapphire - sold |
Flying Ace4984.50 |
05-03-2023, 01:42 AM | #8 | |
Rep 1
Some cars, particularly those with multiple drain plugs, may require smaller washers and o-rings to ensure a proper seal. Other cars may only require a larger washer and o-ring. It's possible that the mechanic was correct in stating that the smaller washer and o-ring were not needed for your F10 M5, but it's always a good idea to double-check with the manufacturer's specifications or a trusted mechanic to ensure that the correct parts are being used during maintenance on your vehicle. |
05-03-2023, 09:07 AM | #9 |
Rep 19,572
Don't go by the oil filter kit confusing o rings, best to buy assorted copper crush washers and choose one that fits snugly around the drain plug thread and don't over-tighten.
05-04-2023, 03:56 AM | #10 |
Rep 19,572
The drain plug itself is a real pain to get to, right at the back of the sump and behind, this is on a car not far from two tons so I now take car to dealer who does oil change and filter from the practicality of a ramp.
