      02-26-2020, 07:59 PM   #1
Monteblueem5
Drives: 13 m5
I wanna know how a bad hpfp feels
I have a 2014 m6gc with downpipes and custom tune from Jordan
Recently I when I am in 3 gear on the highway if I rev it out all the way
Towards the top of the rpm it will start to break up
Like it’s cutting fuel off I logged it and he told me that my hpfp is crashing
So where do I start do I change the low pressure pump and then the hpfp
No codes except I saw a code Lean mix
      02-27-2020, 12:53 AM   #2
RG604
Drives: f10 m5
can you share the log on here ?
IG: RacingGreed
      02-27-2020, 06:12 AM   #3
Monteblueem5
Drives: 13 m5
http://www.bootmod3.net/log?id=5e506197d10b4377fa6258b0
      02-27-2020, 11:03 PM   #4
RG604
Drives: f10 m5
dude .. your car is over boosting ...look at your 3rd gear section not the entire log. your boost targets are 20psi and the pre throttle psi is 32.8. at 5200 rpm. your HPFP is dropping yes but nothing crucial imo. no knock detected but high 12 AFR,13s at some point which isn't good. cars leaning out maybe a bit too much but that's tuning and jordan probably feels ok with that..
IG: RacingGreed
      02-28-2020, 06:33 AM   #5
Monteblueem5
Drives: 13 m5
Why is it overboosting
      02-28-2020, 05:10 PM   #6
RG604
Drives: f10 m5
not sure could be mechanical ,maybe flash the car back to stock and do a log and post it (3rd gear) sport plus stuff on . watch the boost on dashboard if you can or get someone else to. if you see anything over 24 when you're on the throttle . just let off
IG: RacingGreed
      02-29-2020, 05:37 PM   #7
Monteblueem5
Drives: 13 m5
http://www.bootmod3.net/log?id=5e5ae45cd10b43119366ab7c
      03-01-2020, 12:15 AM   #8
RG604
Drives: f10 m5
maybe have a local shop do a boost leak test or the dealer . check couplers visually and even the turbo inlets. def still overboosting that was a stage 1 tune not stock tune btw lol
IG: RacingGreed
      03-01-2020, 07:12 AM   #9
Monteblueem5
Drives: 13 m5
Yeah but didn’t break up felt good
      03-01-2020, 11:45 AM   #10
RG604
Drives: f10 m5
have you talked to the tuner about the overboost? see what he suggests . it didn't cut out cause its overboosting to about 25psi which still isn't good for a stock block with no meth spray
IG: RacingGreed
      03-03-2020, 11:38 AM   #11
technician117
1990 BMW M5  [0.00]
2000 BMW M5  [0.00]
2013 BMW M5  [0.00]
Not trolling, honest question: Why would a boost leak cause too much boost pressure? I would think boost leaks would cause a drop in overall pressure which is not recoverable. Even if the car tried to compensate, wouldn't it only compensate to the set limits? (ie 24 psi)
      06-05-2020, 08:06 AM   #12
x35250
OP - Did you ever get to the bottom of this?
      06-09-2020, 07:30 AM   #13
M6Roar
Drives: '14 M6GC
It happened to a friend of mine at some point, we gaped his spark plugs and the issue disappeared. Hope this helps.
look at his log almost identical to your situation.
https://datazap.me/u/mohamed-albahi/...12-13-14-15-17
      03-06-2021, 05:31 PM   #14
m5rosco
Drives: 2016 F10 M5
Did you get to the bottom of this? My car is misfiring slightly at high rpms, annoying thing is its only done 31k, but got new injectors, plugs, mats and lambdas in the last 1k anyway.
      05-14-2021, 12:05 PM   #15
turboslut
Drives: '14 M5, '18 GT3, '08 911 Turbo
Where is the best place to insert smoke into this car/engine to detect leaks etc?
      08-19-2022, 04:33 AM   #16
Danishp97
Drives: BMW F06 M6 GRAN COUPE
Hi, were you able to fix this? i have the same issue
      08-28-2022, 01:27 AM   #17
fstm5
fstm5's Avatar
146
I had the same exact issue w my Jordan tune on my previous 550i
      03-27-2023, 08:17 PM   #18
danielgmanm6
danielgmanm6's Avatar
Drives: 2013 BMW ///M6 F13
2013 Bmw M6  [0.00]
  [0.00]
  [0.00]
Make sure they put the correct injectors. There's 2, EU5 and EU6. They can't be interchanged. Apparently, this an issue. Just my 2 cents.
