      03-21-2020, 10:16 AM   #1
Passi-M5
Passi-M5's Avatar
Germany
59
Drives: M5 F10 Competition
Hi there. I'm Pascal.
I drive a lot of short distances. How often should I change the engine oil? And what type of oil?
My M5 was at the oil service yesterday (5W30 BMW TwinPower Turbo LL04).
Mileage of the vehicle: 35,000 km
Greetings
Pascal
      03-21-2020, 03:59 PM   #2
Passi-M5
Passi-M5's Avatar
Germany
59
OK thank you.
I will try to keep a short interval. Have you had experience with 5W40 oil?
      03-21-2020, 04:33 PM   #3
I only use what's recommended, don't use anything else.
      03-22-2020, 09:59 AM   #4
Ickdeep
Ickdeep's Avatar
2015 BMW X5  [10.00]
2013 BMW M5 [SOLD]  [10.00]
2013 BMW 535i [SOLD]  [10.00]
I change mine around 3-4k miles(4.8k to 6.4k km) . I'm using Liquid Moly 5W30.
      03-22-2020, 05:20 PM   #5
Blaxwil
Blaxwil's Avatar
627
Drives: 2015 M5
I'm using Liquid Moly 5W/40 @ 5K miles. No need to top off between intervals either.
      04-01-2020, 06:29 PM   #6
SuperF10
SuperF10's Avatar
42
Drives: 2013 BMW M5
Same here but @ 7k miles. 1qt top off between changes. Before using LiquiMoly I’d top off 2-3x easily. I use MolyGen and order it from ECS.
Would definitely recommend it.
M5Rick60091.50
      04-11-2020, 11:31 AM   #7
Fast.F10
Extruding Elements
Fast.F10's Avatar
Drives: 2016 BMW M5 Comp
2016 BMW M5 F10  [0.00]
Why 5W30 vs 0W30...your local weather temp (cold) conditions?
2022 Yukon XL AT4
2016 BMW M5
2015 Ford F250 Super Duty
2006 BMW M5
      04-25-2020, 12:36 PM   #8
vinsanem5
Drives: Lexus ISF/ '16 M5
my m5 is calling for oil about 1000-1500 miles currently using bmw 5w30. Im considering switching to an 0w40, what do you guys think? Live in Socal
      04-25-2020, 12:46 PM   #9
Passi-M5
Passi-M5's Avatar
Germany
59
I was also looking for a good oil and in mild / warm regions a 5W40 should be the better choice. For example from Ravenol VST 5W40 with LL01 approval
      04-27-2020, 11:59 PM   #10
calicolorado
calicolorado's Avatar
Drives: F10 M5 Comp 6-spd
2015 BMW M5   [0.00]
1972 BMW 200/  [0.00]
2020 BMW X7 40i  [0.00]
One thing I have learned since buying my car is: oil is a vast and sometimes challenging subject to research with thousands of opinions and ideas about what's best.
In the 2015 manual I have, it says to use 0w30 with 5w30 as an alternate. Castrol is recommended in the manual and my oil cap also has the Castrol logo on it.
Other years of the F10 M5 have additional viscosities listed in their manual which confuses the heck out of me. 2013 and 2014 list 0w30, 0w40 recommended with 5w30 and 5w40 as alternates. 2016 manuals list 0w40 and 0w30. Sometime in 2015, BMW switched from Castrol to Shell/Pennzoil as their recommended oil so that confuses things even further. Based on the reading and comparing I have done (probably obsessing a bit too much during this Covid19 stuff) any of those viscosities are probably fine if changed at a reasonable interval. For me that is about 5000mi/8000km. Additionally, if you use an oil with BMW LL-01 or LL-01 FE spec you can be confident that the oil is fine for your car. Since you're in Germany, I believe LL-04 is on spec for your application.
Here's what I've done with my car (located in So California):
5w30 Motul 6100 Technosynthese with BMW LL01 A3B4 API SL certs. Exactly what the manual for my car recommends aside from the brand.
Next oil change will be with this new product:
5w30 100% synthetic Motul Specific LL01 FE (BMW LL-01 spec & A5B5)
https://www.motul.com/us/en-US/produ...ll-01-fe-5w-30
Castrol EDGE 0w40 is very similar to the German 0w30 that everyone loved, and made in Belgium-this is readily available in the US in 5qt jugs. I may try it, but the BMW LL01 cert was recently removed from the label-maybe a marketing thing since BMW's switch to Shell. Lots of great info on Bob is the Oil Guy about this oil. If an oil meets Porsche A40 or Mercedes 229.5 spec, you can be sure it's good stuff.
Hope some of that is helpful to you, cheers!
2015 M5 Comp 6-spd manual
1972 2002
2003 Audi TT Coupe 225
2011 Highlander 4WD
      04-28-2020, 02:21 AM   #11
Passi-M5
Passi-M5's Avatar
Germany
59
https://www.motul.com/us/en-US/products/specific-ll-01-fe-5w-30
Oil is a controversial topic, that's right. I will try the 5W40. It won't be bad and fulfills the BMW requirements.
      04-28-2020, 12:36 PM   #12
vinsanem5
does your m5 burn oil between oil changes?
      04-30-2020, 10:39 AM   #13
calicolorado
2015 BMW M5   [0.00]
The current fill with the Motul 6100 has burned zero. Previous fill burned about 1/3rd quart in about 5500mi.
1972 2002
2011 Highlander 4WD
      05-14-2020, 10:38 PM   #14
Passi-M5
Passi-M5's Avatar
Germany
59
what oil did you drive before the Motul 6100?
      05-18-2020, 11:38 AM   #15
Bobby_Drake
Bobby_Drake's Avatar
390
Drives: '16 X5M
What's the difference between MolyGen and the Full synthethic Leichtlauf High tech?
      06-13-2020, 10:40 PM   #16
VADER332
Drives: F10 M5/Gen 6 Camaro SS
Oil Part Number
Good evening. Does anyone know what type of oil is this part number?
83-21-2-480-384
One website had it as a discontinued 0W-30 oil.
Thanks.
      01-10-2021, 08:49 PM   #17
SuperF10
SuperF10's Avatar
42
Drives: 2013 BMW M5
https://www.liqui-moly.com/en/us/products/molygen.html
Contains Tungsten Disulfide (WS2) and Molybdenum Disulfide (MoS2) which create a synergistic effect reducing friction and wear. It is also green and contains a chemical that glows from UV light making it easy to spot the source of an oil leak.
2013 Black Sapphire Metallic, Sakhir Orange Interior, DCT
      05-17-2021, 03:32 AM   #18
Passi-M5
Passi-M5's Avatar
Germany
59
Issue of resumption:
I have now made an oil change on my 2016 CP. Ravenol VST 5W40.
I am curious and will see if he uses up oil.
      05-17-2021, 07:12 AM   #19
Blaxwil
Blaxwil's Avatar
627
Drives: 2015 M5
I tried Ravenol VST 5W40 from Liquid Moly 5W40 and had to add several quarts of oil within 3k miles. Switched back to LM and haven't had any issues.
      05-17-2021, 02:11 PM   #20
Passi-M5
Passi-M5's Avatar
Germany
59
Interesting Info.
Which LM oil do you use? The Molygen?
      05-17-2021, 05:35 PM   #21
Blaxwil
Blaxwil's Avatar
627
Drives: 2015 M5
Yes. The green stuff
      05-17-2021, 10:19 PM   #22
Passi-M5
Passi-M5's Avatar
Germany
59
Do you have experience with „Leichtlauf High Tech"?
