04-02-2021, 11:08 PM | #1 |
Rep 11
Drives: F10 M5, E34 530iT
Bad lifter or Exhaust leak?
Car started making a ticking noise about two weeks ago, haven't driven it much since. Replaced the rod bearings last weekend (weren't bad) and the noise is still there after about 100 miles, no change in performance just a constant tick that goes with the RPM of the motor. Sounds like it's in the top end but can't pinpoint it. 14' CP Catless Downpipes
https://www.youtube.com/watch?v=bfdKhoHgseU |
04-02-2021, 11:37 PM | #2 | |
Rep 538
04-02-2021, 11:38 PM | #3 |
Rep 193
Sounds like a rod knock. You did the bearings in hope that the noise would go away? If you have a scan tool you could try to disable one cylinder at a time to narrow down which one is causing the noise.
04-02-2021, 11:45 PM | #4 |
Rep 11
Already had the bearings, just never got around to doing them. Assuming that's a special scanner I would need for that?
04-02-2021, 11:46 PM | #5 |
Rep 11
04-03-2021, 12:18 AM | #6 |
Rep 538
I have an old suburban too that we use for camping. Unfortunately I think your problem is pretty serious. Have you checked the oil level? What oil viscosity are you using?
04-03-2021, 12:32 AM | #7 | |
Rep 11
Oil is full, Changed every 5k with liquimolly 5w40, the video makes the sound seem much louder than it really is |
04-03-2021, 12:48 AM | #8 | ||
Rep 538
M5Rick60091.50 |
04-03-2021, 11:26 AM | #10 | |
Rep 915
Drives: 2017 540i Bluestone Metallic
Instgram @burninja
04-06-2021, 06:38 AM | #11 | |
Rep 606
How many miles on the engine, injectors, coils and spark plugs? Any codes? |
04-07-2021, 07:25 PM | #12 | |
Rep 11
71k on motor, plugs and coils changed at 50k, also have another new set of plugs and wires to throw in, Have not done injectors yet, not sure if previous owner did them either. No codes besides cats and no loss in power either, car drives perfectly fine besides the ticking. My next plan was to pop the valve covers and check lifters when I get some free time |
04-08-2021, 05:39 AM | #13 |
Rep 606
I forgot to ask. Does the noise change with rpm change? Definitely sounds like upper engine.
I wouldn't rule out injectors, but if it's running good, it's not likely the source. |
04-08-2021, 09:01 PM | #14 |
Rep 11
It does gets faster with the rpms, not sure if louder just faster. Can't really hear it when in the higher revs do to the downpipes. Sounds louder on the passenger side up by the turbo's. Trying to rule out every possible cause before I drop the cash on new rods.
04-08-2021, 09:11 PM | #15 | |
Rep 538
04-08-2021, 11:17 PM | #16 |
Rep 11
Planned on doing forged rods, Just not this soon into owning the vehicle. I'm not familiar with any shops around me that specialize in these types of motors to give me a proper diagnosis, I expect most of them to say it's something catastrophic without properly digging into it like I am. I have access to a shop so I have no issue doing the work myself.
04-09-2021, 12:11 AM | #17 | |
Rep 538
04-09-2021, 05:44 AM | #18 |
Rep 606
It can to tough to diagnose sounds over the internet. Wish I could be more help. Good luck and keep us posted with what you find. Hopefully it's something more simple than a bent rod!
04-09-2021, 04:47 PM | #19 | |
Rep 11
I'm in Mesa, Arizona. It's about 2k for forged Carrillo rods, I haven't priced out Pistons if I were to do those aswell. It'd be nice to have one of those engines but that's only if this one is toast, I didn't find any metal in the oil when I did the bearings so I don't think that's the case |
04-09-2021, 04:49 PM | #20 | |
Rep 11
Yeah I completely understand that, I haven't been able to find any other posts about noises besides bent rods, injectors or bad exhaust gaskets. Planning on checking the lifters this weekend so will post anything I find/don't find |
04-26-2021, 06:34 PM | #21 |
Cole
321
Rep 498
That doesnt sound like injectors to me. If the noise speeds uo as rpm increase, unfortunately, i would say it is rod knock. Best take it over to one of the bmw shops at this point.
04-27-2021, 01:27 AM | #22 |
Rep 115
Did the noise start after aggressive driving? What’s your power level? I would definitely do that cylinder drop test to narrow it down. Then a comp test would likely show if you had a bent rod.
