      01-12-2022, 12:05 AM   #1
x35250
Positive Crankcase Ventilation Hoses
Does anyone have a good DIY for changing the two PCV hoses?
Thanks in advance!
      01-13-2022, 10:09 PM   #2
x35250
TTT
      01-14-2022, 02:15 PM   #3
B1M3
Neon Garden
Drives: BMW X5M Comp
Similar DIY video:
screw torque 8 nm.
      01-17-2022, 01:11 PM   #4
AnotherM
Cole
Drives: 2016 m5 CP
Thanks in advance!
Its actually super easy. I believe two bolts and onr clip on each side.
      01-17-2022, 06:57 PM   #5
x35250
It looks easy enough as long as the bolts are reachable!
Thanks for the responses. I'm waiting for the weather to warm up any way. Snow and freezing temps are not the best conditions to work under in the garage!
      01-18-2022, 01:29 PM   #6
AnotherM
Cole
Drives: 2016 m5 CP
I took a look at mine and realized it takes a little more work than i remembered.
-Remove engine cover
-disconnect battery
Bank1
1. Remove coolant reservoir screw and pull aside
2. Pop DME off, no need to unplug anything
3. Remove both bolts behind DME bracket and pull aside
4. Remove two bolt holding PCV on
5. Unclup PCV from intake
6. Re assemble in reverse order
Bank2
Everything except skip step 1 above.
      01-18-2022, 09:34 PM   #7
x35250
Thanks a lot. I ordered new ones for both banks from FCP Euro. Lifetime replacement warranty to the original purchaser. Can't beat only paying for them once!
