      10-07-2022, 01:15 AM   #1
danielt
Drives: 2016 F87 M2 / 2013 M5 LCI comp
Add 1 liter of engine oil
Hi, I had my oil service a few months ago on my F10 M5. I got a message saying " engine oil at minimum level, please add 1 liter of engine oil at your earliest convenience"
Prior to my oil service I started getting this message every 3 months or so.
There's no leaking oil on my garage floor. Is this a normal occurrence?
      10-07-2022, 02:49 AM   #2
BMWSauberF1
BMWSauberF1's Avatar
Drives: 2013 BMW M5
As with pretty much every other high performance car these cars burn oil so yes thats normal
M5Rick60091.50
      10-07-2022, 08:24 AM   #3
x35250
Rather than months, how many miles are you getting between adding oil?
If you are getting anything over 1,000 miles (roughly) between top-offs, I think BMW considers it within their tolerance. Less than that is borderline and may be a mechanical issue.
What oil and weight are you using?
I ask because I was topping off after every 750 miles on Motul X-Cess 5W-40. I switched to Liqui Moly Molygen and now see about 1,500 or more miles in between. That might've had nothing to do with the oil, such as something not being tightened properly during a previous oil change. But the change made me feel a lot better.
      10-08-2022, 09:30 AM   #4
m5bbq
Drives: M5's
I'm using 0w30. I put 4k+ miles since oil change. Still at max level.
      10-08-2022, 09:55 AM   #5
M5_Raz
M5_Raz's Avatar
514
Drives: BMW M5
Very normal, add oil and forget about it.
Also, when you do an oil change, depending on how much you put in, it might've not been at max from the start.
M5Rick60091.50
      01-21-2023, 01:50 PM   #6
MarcF10
MarcF10's Avatar
2018 BMW X5  [0.00]
happened to me today - got the message to add 1 litre of oil as the level was low
i had to stop at a service station and added the best i could find, then i carried on
although i was conscious these cars consume oil i still got upset as i recently changed oil and filter (2000 miles ago)
never happened to me before so i will be investigating with the help of my local BMW service partner just to make sure i am not risking anything
however it crossed my mind that 5W-40 could not be the best option for me
i have booked another oil change and requested a recalibration of the sensor just in case. i will ask them to use the OEM bmw oil spec and monitor the situation
      01-21-2023, 06:05 PM   #7
ECB
Drives: e39 M5, e46 M3,f10 M5, 997.1tt
I personally wouldn't worry about adding 1 liter every 2K miles. I have to add more than that.
      01-22-2023, 05:09 AM   #8
MarcF10
MarcF10's Avatar
2018 BMW X5  [0.00]
I hear you, but for me it is highly uncommon and even alarming to get the low oil warning.
I thought about horror stories, valve stem seals, piston rings, oil pumps etc..
In this instance think I might know what happened. My mechanic used a low quality oil - a cheap brand named Comma Oil - 5w 40.
I will try the Castrol Edge 0w-40 as per BMW manual and see what happens.
Apparently the 5w-40 is not the very best spec money can get for this car..
M5Rick60091.50
      01-22-2023, 05:53 AM   #9
Comma is for Vauxhalls and Fords def not for our M's, I only use Edge 0W40 knowing it will get to those tight gapped rod bearing spacings quick, 5W40 is thicker and takes longer to circulate from cold.
      01-22-2023, 08:51 AM   #10
MarcF10
MarcF10's Avatar
2018 BMW X5  [0.00]
You are absolutely spot on, sir. Will do exactly that and put my mind to rest.
Below you can see a snipet from the 2015 OEM user manual regarding oil (s)
M5Rick60091.50
      04-18-2023, 03:51 PM   #11
apoxa2
Drives: BMW M5 F10
The more miles you doing the most often will require oil top up. My suggestion is to change oil every 5k miles.
