01-05-2018, 12:48 PM | #1 |
1029
Rep 24,709
Drives: BMW E39 M5, F10 M5, F80 M3
N4SM Ultimate Exhaust Thread | Eisenmann | Meisterschaft | Akrapovic | iPE
Without a doubt a great way to increase performance and get the best sound for your F10 M5 is with an exhaust system. Need 4 Speed Motorsports is an authorized distributor for Eisenmann, Meisterschaft, Akrapovic, and iPE. We know how important your M5 is to you and we know you want to make an educated decision on an exhaust system. So we did some homework for you and are here to answer any question you may have to help you make the right decision on an exhaust. So without further ado, we present "The Ultimate Exhaust Thread" Need 4 Speed Motorsports Eisenmann Performance Exhaust for F10 M5 | Handmade in Germany "We have been a proud Eisenmann Master Dealer for the past 8 Years" About Eisenmann Exhaust Eisenmann's engineers are responsible for designing the OEM systems seen on Porsche and AMG cars, and use this experience to design the best performance exhaust systems in the world. Eisenmann's performance exhausts are built by hand from start to finish to create an old world craftsmanship simply not available with other exhaust manufacturers. Eisenmann Exhausts are available in 2 versions: Sport version: Louder tone and improved performance. Race version: Louder tone, higher performance and reduced weight. Available Exhaust System Tip Sizes: 4 x 120 x 77 Oval Tips or 4 x 90 or 4 x 102 Round Tips ------------------------------------------------------------------------------------------------------ Most Eisenmann Exhausts take 4-6 weeks to be custom built for your vehicle. Some popular BMW applications are usually in stock, please call us for inventory. ------------------------------------------------------------------------------------------------------ See Below to see which Exhaust system you like best for your M5: VIDEO of F10 M5 Here's a dyno sheet of a 2013 F10 M5 with the Eisenmann Race Exhaust! Meisterschaft GT Haus Stainless Steel & Titanium Aftermarket Exhaust | Super GT - Super Light GT - Touring - High Performance - GT - GT2 - GTC - GTS - Track Edition Meisterschaft Performance Exhaust Systems: Introducing the most advanced product line for premium euro vehicles: Master Piece - Meisterschaft. 1. Weight - Both Meisterschaft Touring and GT models are significantly lighter than the OEM unit to reduce unsprung weight. With the Meisterschat Ti Titanium units, you will be able to shed up to 75% of the weight from the OEM unit. 2. Performance - All of our Meisterschaft systems are designed and tuned to provide maximum performance gain without sacrificing the exotic exhaust note. The perfomance gain will be even greater when the Cat-back pipes are used in conjunction with the Meisterschaft muffler. 3. Build Quality - Welding technique and internal construction are handled with extreme care and also given more attention to details compared to other brands. Furthermore, higher grade glass wool pack has been used for Meisterschaft units which can withstand extreme temperatures. 4. Material - Only the highest grade T304 SUS (Meisterschaft - Reduced Backpressure and Power Gains): Meisterschaft Exhausts reduce engine heat and backpressure and improve exhaust scavenging from the combustion chamber. They also minimize the power robbing effects of the OEM system to restore torque and horsepower to the engine. Why is Backpressure Bad? Problem 1: Backpressure is a typical feature of an exhaust system. The backpressure on the exhaust flow can help to reduce sound, but at the same time, it limits engine power. This power reduction comes from an inefficient burn in the combustion chamber where spent exhaust gasses are backed-up into the combustion chamber and contaminate the next burn cycle. Problem 2: A second problem associated with backpressure is heat build-up. This occurs in the OEM style chamber muffler. Hot exhaust gasses are forced through louvers and into dead-end chambers. The heat builds up in the muffler and then backs itself up through the entire exhaust system to the exhaust manifold and engine. This heat retention causes damage to the muffler as well as the catalytic converter, the system tubing, the manifold and gaskets. Even ignition wires can burn up due to an overheated, inefficient exhaust system. How do Meisterschaft Exhausts Solve the Problems of Backpressure? Meisterschaft reduces the backpressure while maintaining a rich powerful performance tone. Annoying exhaust frequencies are carefully avoided by setting body natural frequency at upper range as well as dampened with a dense wall of acoustical absorbing material insdie the cannister. The straight-through design prevents excessive heat retention allowing the entire system to run cooler and last longer. BMW F10 M5 Options: Superlight GT Racing Performance - GTC EV Control - Superlight GT Titanium Racing Performance - GTC Titanium EV Control Meisterschaft Superlight GT 4x90 mm Tip Meisterschaft Superlight GT 4x102 mm Tip Meisterschaft GTC 4x90 mm Tip Hear it here! Dyno sheet showing the gains of the Meisterschaft SUS GTC Muffler system on an M6 over the stock exhaust. The perfomance gain are very similar to what would be gained on an M5. Akrapovic Aftermarket Evolution Titanium Exhaust After adding a full titanium Evolution system, you’ll never want to stop driving. The exhaust system is made of our proprietary titanium and consists of dual-outlet mufflers with exhaust valves, flow-optimized pipes, and a unique cast X-shaped part with resonators. The Evolution lowers the back pressure and gives the M5 more power without removing the catalytic converters. It increases responsiveness and offers a big difference in weight. Sound is improved too, with a deep sporty sound that grows to an aggressive roar when driven hard but still has no droning. It works well with the M5’s ANC system - just like the valve system, which is regulated through the M5’s settings. Complete the look with a set of four exquisite tailpipes in titanium or carbon fibre. Here is a Dyno sheet showing the gains of the Akrapovic Evolution Titanium Exhaust POWER GAIN 7.4kw at 5950 rpm WEIGHT REDUCTION 10.5kg TORQUE GAIN 17.0Nm at 5200 rpm Here's a sound clip to enjoy! IPE Innotech Aftermarket Performance Exhaust iPE (Innotech Performance Exhaust) is the world's leading manufacturer of sophisticated performance exhaust systems specially designed for super cars such as Lamborghini, Ferrari, Porsche, and many others. iPE was established by a team of dedicated engineers and professional designers; whom after many years of manufacturing cars exhaust systems, realized that there was a need for a more personalized and superior exhaust system for super cars. iPE pioneers with the Valvetronic exhaust system which provides an amazing exhaust sound emission while increasing the overall performance of super cars. iPE has the most distinctive dedication, competency in craftsmanship, advanced technology, product dependability, and a constant development and improvement of our products. iPE believes that all drivers have the right to upgrade their car with a signature style. Enjoy a better driving while experimenting a more exciting journey! Experience the difference! BMW F10 M5 IPE Innotech Aftermarket Performance Exhaust - Full Turboback System with Catless Downpipe, X-Pipe, and Valvetronic Mufflers How to Place Your Order Phone Domestic: Toll-Free 1-888 714-7467 Phone International: 1-818-547-5474 E-mail: steve@N4SM.com Website: www.N4SM.com Please do not hesitate to contact us should you have any questions. We have over 70 years of combined experience and 13 years of hands on experience in the automotive industry. Payment: We can process your payment right over the phone and online on our website. Bank Wire Transfer: We accept direct wire transfers to make it easy for you place order. Please contact us so that we can email you more information & instructions. Shipping: All orders are shipped via FedEx Domestic and International. If you are located in Hawaii, Alaska, or international, please e-mail, pm, or call us for the most competitive rates. Hours of Operation: Monday through Friday from 8:00 a.m. to 6:00 p.m. PST Saturday from 9:00 a.m. to 3:00 p.m. Pacific PST Our website is open 24 hours a day / 365 days a year! Contact Information: Phone: 1-888-714-7467 Toll-Free Email: steve@N4SM.com Website: www.N4SM.com If you have any questions or concerns, do not hesitate to contact us. We are here to help you Last edited by Need4Speed_Motorsports; 01-15-2018 at 12:29 PM.. |
01-08-2018, 12:26 PM | #2 |
1029
Rep 24,709
Good morning fellow enthusiasts! Let's start the week off with this F10 M5 iPE Exhaust Clip! For A Set Or If You May Have Any Questions Please Feel Free To Give Us A Call At (818) 547-5474 Or Email Us At Steve@n4sm.com For A Faster Response Click Here For Instant Chat With One Of Our Specialist! |
01-09-2018, 12:38 PM | #3 |
1029
Rep 24,709
Good morning fellow enthusiasts! Check out this M5 with the Eisenmann Exhaust system. Those oval tips look spectacular! To Order Yours Or If You May Have Any Questions Please Feel Free To Give Us A Call At (818) 547-5474 Or Email Us At Steve@n4sm.com For A Faster Response Click Here For Instant Chat With One Of Our Specialist! Last edited by Need4Speed_Motorsports; 01-09-2018 at 12:43 PM.. |
01-10-2018, 11:39 AM | #4 |
1029
Rep 24,709
HAPPY HUMP DAY FELLOW ENTHUSIASTS!!! Here's something funny to kick start your morning! For Deals On Exhaust Systems Or If You May Have Any Questions Please Feel Free To Give Us A Call At (818) 547-5474 Or Email Us At Steve@n4sm.com For A Faster Response Click Here For Instant Chat With One Of Our Specialist! |
01-12-2018, 11:42 AM | #5 |
1029
Rep 24,709
Good morning fellow enthusiasts! TGIF! Check out this Exhaust Clip of an F10 M5 with the Meisterschaft 4x102mm (Round Split) Super Light GT Racing Exhaust To Order Your Exhaust System Or If You May Have Any Questions Please Feel Free To Give Us A Call At (818) 547-5474 Or Email Us At Steve@n4sm.com For A Faster Response Click Here For Instant Chat With One Of Our Specialist! |
01-15-2018, 12:51 PM | #6 |
1029
Rep 24,709
Good morning fellow enthusiasts! Enjoy this sound clip of the Akrapovic Exhaust on an F10 M5! For An Exhaust System Or If You May Have Any Questions Please Feel Free To Give Us A Call At (818) 547-5474 Or Email Us At Steve@n4sm.com For A Faster Response Click Here For Instant Chat With One Of Our Specialist! |
01-16-2018, 12:45 PM | #7 |
1029
Rep 24,709
Good morning fellow enthusiasts! Enjoy this sound clip of the Eisenmann 4x102mm Race Exhaust on an F10 M5! For An Exhaust System Or If You May Have Any Questions Please Feel Free To Give Us A Call At (818) 547-5474 Or Email Us At Steve@n4sm.com For A Faster Response Click Here For Instant Chat With One Of Our Specialist! |
01-17-2018, 12:52 PM | #8 |
1029
Rep 24,709
Good morning fellow enthusiasts! Here's an F10 M5 Hamann with an Akrapovic Exhaust System. Its such a beauty! To Order Yours Or If You May Have Any Questions Please Feel Free To Give Us A Call At (818) 547-5474 Or Email Us At Steve@n4sm.com For A Faster Response Click Here For Instant Chat With One Of Our Specialist! |
01-18-2018, 03:33 PM | #9 |
1029
Rep 24,709
Good morning fellow enthusiasts! Look at this F10 M5 sporting iPE's Titanium Exhaust! To Order Yours Or If You May Have Any Questions Please Feel Free To Give Us A Call At (818) 547-5474 Or Email Us At Steve@n4sm.com For A Faster Response Click Here For Instant Chat With One Of Our Specialist! |
01-19-2018, 07:04 PM | #10 |
1029
Rep 24,709
What's up fellow enthusiasts! TGIF! Check out this F10 M5 sporting a Meisterschaft Exhaust System! To Order Yours Or If You May Have Any Questions Please Feel Free To Give Us A Call At (818) 547-5474 Or Email Us At Steve@n4sm.com For A Faster Response Click Here For Instant Chat With One Of Our Specialist! |
01-23-2018, 12:39 PM | #11 |
1029
Rep 24,709
What's up fellow enthusiasts! Check out this Akrapovic Exhaust Clip by ShifTech! To Order Or If You May Have Any Questions Please Feel Free To Give Us A Call At (818) 547-5474 Or Email Us At Steve@n4sm.com For A Faster Response Click Here For Instant Chat With One Of Our Specialist! |
01-24-2018, 06:07 PM | #12 |
1029
Rep 24,709
What's up fellow enthusiasts! Happy Hump Day! To Order An Exhaust System Or If You May Have Any Questions Please Feel Free To Give Us A Call At (818) 547-5474 Or Email Us At Steve@n4sm.com For A Faster Response Click Here For Instant Chat With One Of Our Specialist! |
01-30-2018, 12:43 PM | #13 |
1029
Rep 24,709
What's up fellow enthusiasts! Check out this Meisterschaft Exhaust Clip! To Order Yours Or If You May Have Any Questions Please Feel Free To Give Us A Call At (818) 547-5474 Or Email Us At Steve@n4sm.com For A Faster Response Click Here For Instant Chat With One Of Our Specialist! |
01-31-2018, 05:53 PM | #14 |
1029
Rep 24,709
What's up fellow enthusiasts! Check out this M5 sporting the Meisterschaft Exhaust! For A Set Or If You May Have Any Questions Please Feel Free To Give Us A Call At (818) 547-5474 Or Email Us At Steve@n4sm.com For A Faster Response Click Here For Instant Chat With One Of Our Specialist! |
02-05-2018, 03:21 PM | #15 |
1029
Rep 24,709
What's up fellow enthusiasts! Check Out This Tuned M5 Shooting Flames Out Of It's Akrapovic Exhaust! To Order Yours Or If You May Have Any Questions Please Feel Free To Give Us A Call At (818) 547-5474 Or Email Us At Steve@n4sm.com For A Faster Response Click Here For Instant Chat With One Of Our Specialist! |
02-08-2018, 12:31 PM | #16 |
1029
Rep 24,709
What's up fellow enthusiasts! Check out this F10 M5 with the iPE Innotexh Performance Exhaust! To Order Yours Or If You May Have Any Questions Please Feel Free To Give Us A Call At (818) 547-5474 Or Email Us At Steve@n4sm.com For A Faster Response Click Here For Instant Chat With One Of Our Specialist! |
02-19-2018, 12:50 PM | #17 |
1029
Rep 24,709
What's up fellow enthusiasts! Happy Monday! To Order An Exhaust System Or If You May Have Any Questions Please Feel Free To Give Us A Call At (818) 547-5474 Or Email Us At Steve@n4sm.com For A Faster Response Click Here For Instant Chat With One Of Our Specialist! Last edited by Need4Speed_Motorsports; 02-26-2018 at 11:30 AM.. |
02-26-2018, 11:30 AM | #18 |
1029
Rep 24,709
What's up fellow enthusiasts! Happy Monday! To Order An Exhaust System Or If You May Have Any Questions Please Feel Free To Give Us A Call At (818) 547-5474 Or Email Us At Steve@n4sm.com For A Faster Response Click Here For Instant Chat With One Of Our Specialist! |
02-27-2018, 01:40 PM | #19 |
1029
Rep 24,709
What's up fellow enthusiasts! Check out this F10 M5 with the Eisenmann Race Exhaust! To Order Yours Or If You May Have Any Questions Please Feel Free To Give Us A Call At (818) 547-5474 Or Email Us At Steve@n4sm.com For A Faster Response Click Here For Instant Chat With One Of Our Specialist! |
03-12-2018, 07:52 PM | #20 |
1029
Rep 24,709
What's up fellow enthusiasts! Enjoy this sound clip of the Akrapovic Exhaust on an F10 M5! For An Exhaust System Or If You May Have Any Questions Please Feel Free To Give Us A Call At (818) 547-5474 Or Email Us At Steve@n4sm.com For A Faster Response Click Here For Instant Chat With One Of Our Specialist! |
Tags |
akrapovic, eisenmann, ipe, meisterschaft, n4sm |
