      06-22-2018, 01:04 PM   #1
iknowchih
Drives: 2014 F10 M5 ZCP
Please help! Akrapovic Exhaust metal rattling noise
Heres a clip of the problem. (Sorry the video is turned sideways.)
Ive did some research on the forums and figured out it might be the old gasket that i used for the akra exhaust but I also saw some members saying the flaps on the muffler went bad from a bmw dealership and they had to replace the whole system...
I was wondering if anyone else came across this issue with this exhaust system and found a solution.. I will look into replacing the gasket hoping that it'll fix the problem.
Thanks in advance!
      06-22-2018, 02:26 PM   #2
rsuhandy
rsuhandy's Avatar
Drives: F06 M6;E92 M3;E85 Z4M; 958 SEH
Thanks in advance!
My suggestion would be to physically wire the flaps open.
If the noise stops then you have found your problem.
If it persists then it is something else.
      06-22-2018, 02:46 PM   #3
iknowchih
I used my friend's ExhaustMeister to keep the valves open but I still hear the metal rattling sound around 1200 to 1900 rpm...
      06-22-2018, 04:01 PM   #4
aann
Drives: f13 M6 2016
Thanks in advance!
First start with replacing the gaskets it should stop the rattling noise which i think its the wastegate rattle .
      06-22-2018, 04:39 PM   #5
iknowchih
Okay! I just ordered the parts. Will update after install! Thanks
akrapovic, mperformanceexhaust
