      04-09-2023, 04:55 PM   #1
Danishp97
Drives: BMW F06 M6 GRAN COUPE
Data Log Bimmerlink
https://drive.google.com/file/d/1J6z...w?usp=drivesdk
Hi! Can anyone here give me an opinion on this log? I logged my stage 2 M6. Car drives fine, my concern is that this log shows misfire detection counter on cylinder 1 as 1 if you scroll down while on other cylinders its 0. Is this normal? Car has no codes as drives absolutely fine!
Also would anyone tell me if anything else looks off? Or is it perfect? Cheers!
      04-10-2023, 01:54 PM   #2
fstm5
fstm5's Avatar
146
Cant open that link on iPhone, but regarding misfire detection on BIMMERLINK, I fairly think it’s incorrect, and it’s detecting false misfires, I do tend to get misfire counts on my car as well when the car is not misfiring, and occasional misfire is understandable but my car does not misfire at all, so I’ve come to the conclusion that BIMMERLINK is just incorrect, also with the oil pressure gauge.
      04-10-2023, 02:05 PM   #3
Danishp97
Makes sense. My oil pressure for the entire log reads 0 psi
      04-10-2023, 02:09 PM   #4
fstm5
fstm5's Avatar
146
Mines shows 7, if we were at 0 or 7 psi our engines would be blown
90% of the things on BIMMERLINK are accurate but I feel like the things that aren’t, are gauges that the car doesn’t have a sensor to read.
      04-10-2023, 03:42 PM   #5
Danishp97
Thanks for the insight! Btw you can download the log on the iphone and open in numbers app which inbuilt. Incase you want to go through
fstm5145.50
      04-10-2023, 03:51 PM   #6
fstm5
fstm5's Avatar
146
Are your readings for boost etc bar or psi ?
      04-10-2023, 03:52 PM   #7
Danishp97
They’re bar
      04-10-2023, 03:53 PM   #8
fstm5
fstm5's Avatar
146
They’re bar
What stage 2 are you on?
      04-10-2023, 03:54 PM   #9
Danishp97
Etuners Greece custom map
      02-27-2024, 09:26 AM   #10
stunatu72
Drives: 2021 BMW M340i xDrive
So bimmerlink oil pressure PSI readings not to be counted on, ever? I see 15 psi when engine off regardless of when the reading its taken. At idle about 38-40, but also notice it spike to 100-110 psi when pushing the car. No warning lights in iDrive but I also don't know the oil pressure PSI range for a B58 engine. Any clue where I could find that?
