      09-20-2019, 10:04 PM   #1
BeachM5nster
Drives: '14 M5
the DTC mystery???
i, along with another member now, cannot disable traction control completely.
yes i know how to do it, the option to is not even in the idrive m mode setup menu either.
traction and MDM both work perfectly but it cant be disabled.
WHAT IS UP???
anyone?....
      09-20-2019, 10:06 PM   #2
BeachM5nster
Drives: '14 M5
let me add that i have my eyes on a nice virgin parking lot and i want to melt my tires off and i will film it. please help me do this lol
      09-21-2019, 06:24 AM   #3
Craze
Is urs manual?
      09-21-2019, 12:08 PM   #4
BeachM5nster
Drives: '14 M5
Originally Posted by Craze View Post
Is urs manual?
dct
      09-21-2019, 05:25 PM   #5
Craze
Id be going to bmw and showing them and asking for reprogramming
      09-22-2019, 07:45 AM   #6
BeachM5nster
Drives: '14 M5
already did. $200 reflash. it did nothing
      09-23-2019, 04:41 AM   #7
Craze
Have u read the manual? If its in there and its not available and youve gone to bmw then its their issue
Get them to lodge a puma case
      09-29-2019, 03:51 PM   #8
Dumpspec
Drives: @dumpspec
With the car on press the traction control button once to active it. You’ll see both MDM and traction sign on. Then press and hold traction button again and MDM will turn off and traction will be fully disabled
      09-29-2019, 08:22 PM   #9
BeachM5nster
Drives: '14 M5
LoL.. you guys are funny..
I KNOW how it SHOULD work
the big mystery is WHY it DOESNT work on my car, and im not alone,
but if trac is broken, it wouldnt function, nor MDM, but they do, perfectly, it just wont fully disable
      09-29-2019, 08:29 PM   #10
Dumpspec
Drives: @dumpspec
Opps mis read the original post haha. Only saw the first part.
      09-30-2019, 01:47 AM   #11
Dwaynos
Dwaynos's Avatar
Maybe the car thinks you're not capable with traction off. Only joking. So there are no codes stored in the ABS/DSC module?
      09-30-2019, 08:53 AM   #12
technician117
1990 BMW M5  [0.00]
2000 BMW M5  [0.00]
2013 BMW M5  [0.00]
I would hook up ISTA at this point and monitor what you can. Also the obvious scan of modules as well. Usually what happens when there is a malfunction is that systems turn off rather than get stuck on in case they aren't working properly. At least that's how it works in all previous gen cars.
      09-30-2019, 06:39 PM   #13
rickyf10
rickyf10's Avatar
Sounds more like a coding issue. Guess the one you did with 200 dollars is an driving-adapt reset.
      09-30-2019, 06:50 PM   #14
rickyf10
rickyf10's Avatar
Try this
set HU_NBT->3000 HMI->DSC_OFF to activ
      10-01-2019, 11:54 AM   #15
BeachM5nster
Drives: '14 M5
LoL. no, no codes. everything works. just cant cut the working off
      10-01-2019, 11:59 AM   #16
Dwaynos
Dwaynos's Avatar
I would definitely check the coding as mentioned above. Maybe its reset itself at some point. I had a similar thing happen to my door locks. I had to go in and code them back to how they were for no apparent reason.
      10-01-2019, 11:59 AM   #17
BeachM5nster
Drives: '14 M5
my exact thoughts! because i had a previous car that the dsc would get u killed as it killed all power at any tiny slip. horrible. HAD to have dsc off always
point is, dsc had a malfunction and it just stopped working and i was cool with it Because I didn't have to worry about forgetting to turn it off anymore. it was off
      10-01-2019, 12:01 PM   #18
BeachM5nster
Drives: '14 M5
cheers. yes thats what im betting. will find out thursday evening, i have a coding rendezvous scheduled
      10-01-2019, 12:01 PM   #19
BeachM5nster
Drives: '14 M5
sounds like some classic bmw(like i was told) lol. will find out thursday
      10-03-2019, 09:30 PM   #20
BeachM5nster
Drives: '14 M5
Try this
you were on the right track but not quite
      10-03-2019, 09:37 PM   #21
BeachM5nster
Drives: '14 M5
the mystery has been solved!!! my car was coded stock to not allow DSC to be disabled. who knows why but from the factory, took a few tries but Mike at BPM found the stupid codes.
but BIG PLUS:my car has never had launch control used,
and it wont
      10-06-2023, 07:21 AM   #22
JustinT
Drives: 2014 M5
I got the exact issue as you did, takes me couple weeks to figure out what to do, glad I fixed by contacting BPMsport and let Mike coding my car to enable the dsc off and update all my module software to the latest version, also did a comprehensively check my car for no other issues. To those who have the same issue, BPMsport is way to go.
