10-02-2019, 07:19 PM | #1 |
Rep 140
Ticking noise after motor shut down
I just noticed the weird sound coming from the engine right after shut down.
It's noticeable only when the hoods open Long time ago, I did find a code "no movement deteced on valvetronic motor" but it disappeared by itself later then. I'm not sure if they're related or not Here is the sound clip |
10-03-2019, 07:50 AM | #3 |
Rep 1,107
Definitely not normal. Does it stop just as the turbo coolant pump stops? I wonder if your pump is going bad, you should be able to hold your hand on the pump to feel it vibrating maybe it's coming from that.
10-04-2019, 09:01 AM | #5 |
Rep 606
Have you checked the fill level of the turbo coolant circuit? Maybe it's very low and not able to pump without cavitating air as well.
10-04-2019, 05:19 PM | #6 |
Rep 140
Update:
Been told by the dealer, it’s all fine. Pumps ok, fluid fill level ok. The sound is due to the thermal expansion inside the engine. Tho the noise to me still sounds weird |
10-04-2019, 05:57 PM | #7 |
Rep 1,107
That's BS that's not normal
10-04-2019, 07:07 PM | #8 |
Rep 99
Go to a different Dealer
Individual Amazonite Silver| B&O | KW V3 |Forgeline GA1R-Centerlocks | Forgeline Centerlock Conversion |K&N/Charcoal delete | AFE CF Scoops | RW Carbon Lip | IND-Style Front/Rear Markers | IND-Style Black side Grille/Rear M5 Emblem | LCI Front Grille | Dinan Sway bar | Powder Coated Cocaine White Calipers | ECS tuning Brake lines| Carbothech - Akebon0 | M-Performance CF Rear Center Diffuser | RPI GTM Exhaust | Suntek PPF |
10-04-2019, 07:58 PM | #9 |
Rep 140
10-04-2019, 08:08 PM | #10 |
Rep 1,107
Find the pump, then find the electrical connector or fuse. Get the car hot, pull back in the garage and unplug the pump or pull the fuse, then see if the noise stops.
10-04-2019, 08:15 PM | #11 | |
Rep 140
Is the pump located at #7? |
10-04-2019, 08:57 PM | #12 |
Rep 1,107
Here ya go
