04-19-2016, 11:26 PM | #1 |
Rep 1,300
M5/6 Jb4+BCM question
2013 Bmw M6+ JB4/BCM with Blue tooth reader
Resonator delete K&N air filters Just driving and out of nowhere car feels slow!!! I check the Bluetooth app and car boost is 9psi. Car feels sluggish so I shut it down and start it back up. I then try to connect back to the Bluetooth reader and nothing! Won't connect no matter what I do (Reinstall, disconnect/connect, unplug etc) In short, car is driving slower then stock with No check engine light and feels weird. What could issue be? |
04-19-2016, 11:28 PM | #2 | |
Hide! My wife's coming!
812
Rep 2,816
If that's not the issue I would remove the JB4 and revert back to stock. Just reconnect the stock connectors and test. Try direct with USB or remove the Bluetooth all together and see if things are restored. I've seen a faulty BT cause issues with the board
04-20-2016, 12:01 AM | #3 | ||
Rep 1,300
2nd gear only does 18psi and 3rd ear only 12 psi And 4th gear is just dead! This is same on any map I run it on. All else looks normal with car scanner showing no issues and under hoood all normal |
04-20-2016, 12:32 AM | #4 | |||
812
Rep 2,816
Have you switch to map 0? I would definitely revert back to stock and see if the issue is the JB4 or the car itself
04-20-2016, 12:33 AM | #5 | ||||
Rep 1,300
1-2 gear I have boost and power is decent but not full potential. 3rd gear is only 12 psi based on logs and feels slow as shit |
04-20-2016, 03:20 AM | #7 |
Rep 1,805
Drives: 2014 BMW M5 F10 CP
That was going to be the question I thought needed to be raised..I would check them..
04-20-2016, 09:35 AM | #8 |
1087
Rep 1,968
Post a map 4 log (3rd and 4th) and a Map 2 or 3 as well. Need to determine if you are losing boost or the DME is just not targeting.
04-20-2016, 09:51 AM | #9 | |
812
Rep 2,816
OP!!!! Check your valve hose lines. It's will cause the same symptoms. It's a simple fix if that's be case.
04-20-2016, 10:08 AM | #10 | ||
Rep 1,300
Weird thing is boost is 12psi and then at 6krpm it shoots to 20psi! Very very weird! Ran some logs.. Who can I send to look into it. I'm a Jb4 log Noob! |
04-20-2016, 11:46 AM | #12 |
Rep 2,062
OP, what app and Bluetooth reader are you using and post a link to your thread on BMS' forum so we can continue reading for the info.
04-20-2016, 02:20 PM | #13 | |
812
Rep 2,816
04-20-2016, 02:21 PM | #14 | ||
Rep 1,300
04-20-2016, 03:08 PM | #15 |
Rep 2,039
Anyone ever discuss replacing spark plugs and/or coils? How often should this be done?
Not totally unrelated as JB4 may cause more wear on these two items (among othet parts) than if left stock |
04-20-2016, 03:52 PM | #16 | |
812
Rep 2,816
Terry w/ BMS is very responsive. Or you can go direct to Jon at BMS (jon@burgertuning.com )
04-20-2016, 07:39 PM | #17 |
1087
Rep 1,968
I do it every 10K or more frequently if I use some additive. Haven't done coil yet but do an inspection when you swap the plugs and change if needed. Takes like 40 mins to do it so its a DIY.
04-20-2016, 11:57 PM | #18 | |
812
Rep 2,816
Thanks
04-21-2016, 12:52 PM | #19 | ||
Rep 1,300
Bad gas maybe? Also plugs are new and gapped |
04-21-2016, 01:13 PM | #20 | |
Rep 2,039
So the car pulls normal--were vacuum lines sealed?? |
04-21-2016, 01:33 PM | #21 | ||
Rep 1,300
04-22-2016, 04:46 PM | #22 |
IG @bmwF9xG80
3813
Rep 7,593
cool meeting u last night
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
