03-12-2014, 01:09 PM | #1 |
Rep 1,622
DINAN Front Control Arms
This just showed up on their site..
M5 front control arms that provides additional negative camber. http://dinancars.com/product/d160-00...ries&mid=1163/
03-12-2014, 02:32 PM | #2 | |
Perennial PFC
336
Rep 1,275
Interesting that a shorter upper control arm increases negative camber with body lean on turn in, good for track but with mostly everyday driving on the street, will that increase wear on the inside of the tire, much like too much negative static camber does? |
03-12-2014, 02:40 PM | #3 |
Rep 1,622
Yeah I think this is more of a track product.
03-12-2014, 02:47 PM | #4 |
Perennial PFC
336
Rep 1,275
I read good things about the KW V3 coilovers though, and wonder if these arms might be a perfect complement to that suspension mod? I hope someone else is brave enough to be the guinea pig!
Just noticed this post with the coming suspension coil-over kit for the F10 M5 from Dinan. I like the idea of retaining the stock electronic shock. http://f10.m5post.com/forums/showthread.php?t=957474 Last edited by Used2be; 03-12-2014 at 03:18 PM.. Reason: added text |
03-12-2014, 04:46 PM | #5 |
Rep 3,200
Not sure on the F10 M5's, but on my E70 X5M there are three oem control arms available since camber is fixed. Neutral (stock), +.5, and -.5. I'm using the -.5 ones with my KW's and am at -2.0 camber at the front now with the ride height I'm at. Maybe worth looking into for you folks at it's more camber than these, is an oem part, and less expensive.
If you guys are worried about tire wear don't be as toe kills your tires much quicker than camber. -2 is not going to hurt the tires by any significant amount as long as your toe is good. I would set toe at 0 personally for improved turning. |
03-12-2014, 05:08 PM | #6 |
Perennial PFC
336
Rep 1,275
Thanks for the info, I'll look into that for the M5. Makes sense for a non-adjustable system, have plus and minus arms to account for chassis damage after a crash.
03-12-2014, 06:29 PM | #7 | |
Rep 3,200
Here is a pic of the oem -.5 ones for the X5M for reference: |
