02-09-2017, 05:05 PM | #1 |
1087
Rep 1,968
Differential Mount Cracked
Folks - the inevitable happened. My differential mount cracked with a large *thud* last night rendering me stranded on the wonderful 405 freeway at 9pm. Tow truck inevitably came by 11pm during which time I met TWO CHP officers, TWO unfortunate homeless souls and ONE BMW Tuner who happened to stop by and lend a hand (guess who...)
The obvious question... what was I doing when it broke? Answer... ding ding ding... NOTHING! I was just cruising, shifted into 4th and BANG! Anyways, car is getting repaired but this issue is like the plague and needs to be fixed. So, I will investigate and figure out a solution. It may be simple as a plate, stronger bolts... whatever it is. |
02-09-2017, 07:30 PM | #4 | |
Perennial PFC
336
Rep 1,274
If possible, could you show us pictures of the removed broken part? That might give us a good reference to look for initial cracking before failure. You guys with the high horsepower are playing with fire. So sorry for the hassle! |
02-10-2017, 06:08 AM | #6 |
Perennial PFC
336
Rep 1,274
Sorry, it was Puerto Rico, bad memory! I'd think making a jig and welding up some plates for a whole new structure would be more practical than a complete forged piece. Or, strategically placed supporting gussets welded on to the stock piece. Still, not a simple project, but if it's going to be a consistently weak point that fails for those of you with higher HP, it needs to be done.
02-10-2017, 07:23 AM | #7 | |
Rep 231
Drives: F90 M5 LCI - Aventurine Red
F90 M5 LCI - Aventurine Red/Smoked White-E39 M5 - Modified ESS Supercharger Kit -E34 M5 1995 - Arctic Silver / Black Leather-
E30 M3 1987 - Diamond Black Metallic / Black Leather-996 Turbo - Lapis Blue/Savannah-VW Rallye Golf |
02-10-2017, 08:24 AM | #8 |
Rep 573
he would of said, you know i can make your car fast and reliable, we will give you warranty, our power delivery is so smooth that you wont be braking parts, all that for 9999.99, but thats not all, if you order now i will include 2 stickers and one license plate frame : happyanim:
22 X3m
10 e90 335i 610whp 13 M5, 11.0@131 Fabworx DP,Precision Tune 650whp+ 11 E92 335xi 12.5@113MPH,362whp/438wtq GONE http://www.youtube.com/c/jairomvp Instagram:Jairomvp |
Bostons_Finest_147.00 |
02-11-2017, 12:48 AM | #9 |
1087
Rep 1,968
Well this got ugly quick:
Driveshaft sheared off Diff mounts broken (obviously) Fuel tank heat shield broken Some bolts stuck here and there ?!? $$$$$$ |
apexlocator243.00 |
02-11-2017, 07:34 AM | #12 |
Rep 843
02-11-2017, 08:04 AM | #13 | |
Perennial PFC
336
Rep 1,274
Would making the large diameter bore more stable allow the part to survive? Would changing the style of bushing from this flexible rubber to a more rigid material help? Or, would that just change the failure point? Would the added rigidity only make things worse? And perhaps bring a lot of road noise into the passenger area? Throwing thoughts out there for the more knowledgable types to chew on. It will be informative if Allmotor's failure was the same. Is there any structural damage to the differential itself? |
02-11-2017, 12:44 PM | #15 |
Rep 55
Wow sorry to hear Ram, esp the collateral damage the came along with it. Hopefully someone can figure out a stronger mount to stop this from happening again.
2014 BMW M5 - JB4+BCM, BootMod3, SSP Spec-R Clutches, Gutted Stock Downpipes, K&N Drop Ins (SOLD)
2002 Porsche 996TT - EVOSpec 9000 RPM 4.0ltr w/ Xona Rotor 95-67s ... Controlled by Syvecs |
02-11-2017, 02:09 PM | #16 |
Rep 881
You are a pioneer. What are you running, 850wtq? I guess you've found the limit for stock driveshaft and diff mount. I'm guessing this damage happened slowly over time, and then a simple shift pushed it over. The limit may actually be lower wtq. Even though I have zero plans to go into 800s, I wonder how long 700+wtq can last....
2014 "AW/SO"me M5
02-12-2017, 02:52 PM | #20 |
Rep 715
We used to use Billetflow for differential braces on our old 03-04 Cobras. He has a full CNC shop and makes solid products.
If we got him the differential mount he may be able to design and mill them with enough interest at a reasonable cost. http://www.billetflow.com/irs_brace.htm
Redrckt135429.50 |
02-12-2017, 03:14 PM | #21 |
1087
Rep 1,968
Nice find - I need to see what else broke and then decide. Need to upgrade multiple weak points unless there is large gap between what breaks first and the next in line.
02-13-2017, 11:48 AM | #22 |
3387
Rep 7,541
It was me, of course!
It was really sketchy pulling over there - very narrow.... and I was worried my Mercedes SUV wouldn't get back up to speed to merge in time
