      04-14-2013, 06:55 PM   #1
py0413
py0413's Avatar
Drives: Slow
Solid orange engine light came on
Good afternoon/evening folks,
I went for a 150km Sunday afternoon drive today. (Cruising speed, didn't push the car) On the way home, about 50km away, the orange engine light came on silently. I stopped at a gas station checking things up. Fuel door was tight and sealed. Checked with idrive and shows system all OK. The light remained on after restarting the car a couple of times. I read the owner's manual book and the only thing I could get was "emission Canadian mode", nothing else. Therefore, I proceed to call BMW assist and described to what happened. The rep said I could keep driving as long as it doesn't turn red and will visit a local BMW service center tomorrow for that error.
Is there a way to read out the error code like I could in the E9X? Makes me wonder what caused the light to come on, especially I didn't get any audio warning like I used to get in the other BMWs. 2 weeks ago when the car needed 1L of oil, I did get any audio warning along with a message showing on the display.
Any thoughts guys?
Must stop eating..............
      04-14-2013, 07:34 PM   #2
Pazzo009
Pazzo009's Avatar
1113
Drives: X5M,M3(46&36),812SF
Same thing happened to me today 30 seconds after starting the car. Fuel cap is tight too. Everything feels right. I'm annoyed because now I will probably have to waste time and go to the dealer. I should have never sold my scan tool.
      04-14-2013, 07:40 PM   #3
koxal
koxal's Avatar
Drives: 2015 LBB F85 X5M
2015 BMW X5M  [0.00]
2010 BMW M3  [0.00]
2013 BMW M5  [0.00]
so many problems with the f10 m5...
oil pump
fuel pump
brake squeaks
steering wheel vibration
drivetrain mulfaction
wind noise caused by mirrors
etc
etc etc...
      04-14-2013, 07:49 PM   #4
py0413
py0413's Avatar
Drives: Slow
So an hour later now, I went to the garage and started up the car, the CEL is gone
if I am buying a scan tool/reader, which brand/model would you guys recommend?
      04-14-2013, 07:49 PM   #5
Pazzo009
Pazzo009's Avatar
1113
oil pump
fuel pump
brake squeaks
etc
etc etc...
Don't forget rear suspension clunk. (I haven't experienced it, I just am aware.)
I love this car, but yes I am disappointed in some ways.
      04-14-2013, 07:51 PM   #6
Pazzo009
Pazzo009's Avatar
1113
I had a Peake research I was using on my E60. No complaints. I was just using it for a reset and scan for simple CEL.
      04-14-2013, 08:15 PM   #7
koxal
koxal's Avatar
2015 BMW X5M  [0.00]
2010 BMW M3  [0.00]
2013 BMW M5  [0.00]
yeap..! u r right.. i forgot to mention that with many others probably
      04-15-2013, 11:36 AM   #8
Sharpie12
Drives: 2013 F10 M5 SG/SO
happened to me a few weeks ago and my issue was that i was running too lean. Put in a fuel additive and filled up my gas, cleared the code and now im good.
2015 F10 M5 - AW/SO- Retired 2013 F10 M5 - SG/SO - Retired 2010 E60 M5 - Retired 2010 X6 50i - Retired
2006 E60 M5 - Retired 2004 E60 530i - Retired
      04-15-2013, 12:17 PM   #9
krown
krown's Avatar
29
Drives: 2017 Alpina B6
Sorry to hear that. Let us know what the issue was when you find out!
      04-15-2013, 12:51 PM   #10
singularity
Driver
singularity's Avatar
94
Drives: M5 (F10)
That light isn't about an engine issue but about emission system malfunction. I've had it during cold starts, together with a drivetrain warning few months ago and it wouldn't go away until BMW service updated software and that fixed it.
      04-15-2013, 02:15 PM   #11
reychen123
Drives: m5 f10
Had light on before, and it was something oxygen sensor not work. A problem I never heard of....
      04-15-2013, 04:49 PM   #12
Pazzo009
Pazzo009's Avatar
1113
Mine just randomly went off. Hmmm?
      04-15-2013, 05:35 PM   #13
py0413
py0413's Avatar
Drives: Slow
So to update this with everyone,
The light hasn't came back on after restarting the car yesterday afternoon. (Car was parked in the garage for roughly 1 hour after last seeing the light). Called dealer service department and they said they can't diagnose anything because the light is now off. Was told to go back to them if it ever happens again and of course, has to be within their regular business hour.
Another thing though, I have been driving on highway for quit a bit lately, cruising speed, 90-100km/h. I got some pretty impressive gas mileage. My last tank of gas went for a bit more than 650km and this refuel last night showed, I will get 775km/tank, probably won't happen but man this thing uses less gas than my 3.7L Acura TL.
      04-15-2013, 10:04 PM   #14
avlnch
Drives: 2013 Individual M5
Any thoughts guys?
How much gas was in your tank at the time you stopped at the gas station?
When you run the car low on gas, it's not very good for the fuel pump and components, and can yield a CEL (check engine light).
If you added fuel and the light went away after the car had time to reset, then you should be fine. This means it's not an O2 sensor or other emissions malfunction.. most likely it happened simply due to fueling up with an almost empty tank.
      04-15-2013, 11:07 PM   #15
py0413
py0413's Avatar
Drives: Slow
At the time when the light went on, I still had 1/2 tank of gas. I ran pretty low over the last 2 fill-ups. I wonder if that could be the cause. But definitely, when I had the CEL, the fuel tank had quite a bit of gas in it.
      04-16-2013, 04:40 AM   #16
johntomferg
PY0413,
Glad your issue appears to have passed for the moment. Singularity is right that if you see it again, you should ask your dealer to check with BMW for a software update with an emissions issue that causes the CEL to intermittently come on.
Hey KOXAL,
Better add to your list:
Emissions CELs sometimes clear themselves without a trip to the dealer
Gas Mileage too good
Wouldn't want to miss those on your complaint/issues list for when you repeat the list in a new thread.
      04-16-2013, 07:46 AM   #17
DrewM5
Drives: SG E60 M5
Sounds like BS. They should be able to plug you in and get a history of all faults, errors, etc. I think they are just being lazy.
      04-16-2013, 06:30 PM   #18
py0413
py0413's Avatar
Drives: Slow
I will be going to the dealer where my car was originally purchased, I will mention this CEL at check-in on Friday.
      04-16-2013, 11:41 PM   #19
avlnch
Your name and the issue your having is pretty ironic. Gave me a quick laugh.
P0413 is an engine error code that throws a CEL light.
So you know, all the Dealer will do is plug your car up and check the faults log. It's possible that they won't find anything (sometimes these just don't register for some reason). However it only takes under 20 minutes to check things out, so doesn't hurt to ask them to plug it in and take a look.
Let us know how you make out..
      04-17-2013, 01:55 PM   #20
py0413
py0413's Avatar
Drives: Slow
Oh nooo! That really is ironic lol. No wonder my E90 m3 had CEL came up quite often. Nothing really was wrong but the sensors decided to go wild.
I will talk to the SA on Friday and see what they can do about it. As for now, the car runs great.
      04-17-2013, 04:28 PM   #21
cmhsam
Drives: 2018 F90 M5
My car is getting new brakes and new driver side mirror. They also checked my fault code and said it has to do with the CAM SENSOR? They cant seem to resolve it so they needed to keep car for one more night. Hopefully will have an update tomorrow.
      04-17-2013, 04:48 PM   #22
skrambles297
Drives: M5 (Black Sapphire) F10
Out of curiosity, what's the issue with the driver side mirror?
______________________
Current Cars: M5 (F10) / Porsche 911 Turbo (997) / X5 40d Msport
Previous Cars: M5 (E60) / M3 (E46) / TVR Cerbera
