      07-19-2023, 04:41 PM   #1
ricardofors68
ricardofors68's Avatar
326
Drives: '15 F10 M5
Can you use 400mm rotors in the rear?
I see vendors on fleabay selling 400x36mm rotors for the rear. I pulled the string to see where it takes me and after giving my vin, they replied to me that it does fit. That's 1/2-inch difference, no? Rear rotors are 396x24mm. Wanted to know if this can be done or not. Thank you in advance.
'17 C7 Vette GS (bye) / '15 F31 328 ix (sold) / '08 E92 335i (sold)/ '08 E92 M3 (RIP)/'01 M5 (sold, sniff)/'07 M5 (sold)/ '15 M5
      08-15-2023, 05:42 PM   #2
rhyary
rhyary's Avatar
Drives: 2013 M3
Is this a CCB rotor?
      08-17-2023, 07:03 PM   #3
ricardofors68
326
Drives: '15 F10 M5
No
Blaxwil627.00
      08-19-2023, 04:22 AM   #4
Likely not, just stick with the 296's.
      08-27-2023, 07:54 PM   #5
ricardofors68
326
Drives: '15 F10 M5
Wondering as they are offered at FCP Euro and states as compatible for the F10 M5 rear.
      08-28-2023, 11:50 AM   #6
vafan13
Drives: Sakhir Orange F10 M5
Is it the SHW rears you're looking at? I see that on FCP (and elsewhere) it shows the rotor as 400x36, but that can't possibly be accurate. A 36mm wide rotor wouldn't even fit in between the caliper bracket. My assumption is SHW messed up in their inventory description and every reseller has just gone with that. If you look at the picture of the rotor it is clearly not 36mm thick.
m5rosco210.50
      08-28-2023, 08:25 PM   #7
ricardofors68
326
Drives: '15 F10 M5
It looks like is stamped as 400x36mm, but I like your theory.
      08-29-2023, 11:07 AM   #8
vafan13
What picture are you looking at? I just looked at two separate pictures of BRR48181 and it shows minimum thickness as 22.4mm, which is correct for the 396x24mm rear rotor.
