04-09-2015, 05:31 AM | #1 |
Rep 1,805
Drives: 2014 BMW M5 F10 CP
Widest tires possible
Time to replace my rear tires. I am running a remap which has made it difficult to get the increased power down and I want to go as wide as possible on existing 343 rims to handle the power increase.
1. Can I run 305s in the back and 265s in the front or do I need to increase the front tires to 275s. 2. Does 305/30/20 rear, 275/35/20 front sound right? 3. Michelin PSS And Pirelli P zeros only available options to fit?
04-09-2015, 10:03 AM | #3 |
Rep 1,917
Go for aftermarket wheels. FWIW, I've seen a 345 on Morr wheels fit in back, and was still tucked inside the fender well. That's some serious rubber...
Matt
04-09-2015, 10:36 AM | #4 | |
Rep 6,067
and 305 is much better than 295. Significantly better traction...
04-09-2015, 03:29 PM | #5 |
Rep 739
I have 11 inch HREs on the rear. Fronts are 9 inches. How wide can I go in the back and what should the matching fronts then be?
04-09-2015, 06:46 PM | #6 |
Licensed Drug Dealer
742
Rep 2,269
You can do 315/30 or 305/30 rears and match them with 275/35 or 265/35 fronts. I'm in the same position (9" front and 11" rear). Once my 295/30 rears are toast, I'm gonna swap them for 305/30 and keep my 265/35 fronts.
04-10-2015, 09:18 AM | #7 |
Rep 739
Thx.
04-23-2015, 02:43 PM | #8 |
Rep 1,805
Just fitted Pirelli P Zeros 305/30/20s on my stock 343 M5 rims. Hope this works out as I was thinking of going for the Corsas..but they cost double..
msq12334.50 |
04-24-2015, 04:50 PM | #9 |
Rep 1,805
Just to say the 305s feel great! Excellent grip and handling feels great. Not sure why these tires weren't fit stock?
04-24-2015, 04:51 PM | #10 |
Rep 1,805
Great traction! Seemed to fit ok on 10" rim..
04-25-2015, 11:48 PM | #12 |
Rep 1,805
Yes - can get the power down a lot more easily and smoothly. Feel it's a better tire handling wise. I think $250 per tire wasn't too bad either.
04-26-2015, 01:21 AM | #13 |
Rep 6,067
Where did you get tires for $250? I got mine for $350 and since after 4k the tread left is less than 50% I need to get another set soon...
04-26-2015, 01:24 AM | #14 |
Rep 1,805
At my local tire store here in SLO. $250 per rear tire, $80 for alignment.
05-02-2015, 10:18 AM | #15 | |
Rep 110
Other than 305s...I'm also considering R888 315 on my stock 343 rims...Anxious to hear your thoughts ! |
05-02-2015, 10:42 AM | #16 |
Rep 1,805
No issues on 343 rims with 305/30/20 tires. Not sure if the M5 stock rim can take wider tire..
05-02-2015, 12:32 PM | #17 | |
Rep 110
05-02-2015, 03:05 PM | #18 |
Rep 1,805
On stock CP setup. No spacers.
05-02-2015, 06:22 PM | #19 |
742
Rep 2,269
It's not a matter of fitting or not, but more like a safety or performance issue I guess. Manufacturers give recommended values for a reason.
Hella flush guys have been running stretch tires for years but is it safe? Somewhat I'd say. If you go the other way and run too large, the tire might not perform as well as it should on a recommended wheel width. |
msq12334.50 |
05-02-2015, 06:32 PM | #20 | |
Rep 1,805
05-02-2015, 06:53 PM | #21 | |
Rep 1,805
05-03-2015, 02:47 AM | #22 | |
Rep 6,067
1. wear life. The wider tire means more contact and less wear life. I had my original 295 tires for about 14 months. Now after 6 months on 305, today I figured out the tread left is about 4/32". I need new tires in 1-2 months! 2. Cornering. As you mentioned (and I agree) the traction is significantly better, but in turns/cornering car is not as agile as it was on 295 which was predictable. 3. DD intention. M5/M6 are meant to be DD car and not track car. Not everybody wants to launch M5/M6 every day so they don't need 305 while 295 is better fit for daily driving. However, I take 305 over 295(due to traction improvement). I will go for another 305 again. unfortunately MPSS 315/30/20 is not available. If it was, I would go for it
msq12334.50 |
