      07-08-2014, 02:44 PM   #1
Jeff73
Drives: M6 Cab
Dinan Stage 1
Anyone upgrade to the Dinan Stage 1 for their M5 F10? Thoughts?
I have an M6 F12 I'm and looking to upgrade.
Thanks
      07-08-2014, 05:23 PM   #2
Pazzo009
Pazzo009's Avatar
1110
Drives: X5M,M3(46&36),812SF
I'd stay away from Dinan. I had issues with my 335 flash and they did not stand by their product. They lost me as a customer
      07-08-2014, 05:49 PM   #3
Russkey
Russkey's Avatar
Drives: '12 BMW AW 550xi
2012 550xi  [10.00]
I would stay away from Dinan. I don't think their numbers are real. There's a lot of proof in this forum.
'15 Porsche Macan S / Black & Garnet Red / 20" RS Spyder Wheels / CF trim / Red Calipers / Black Rear Badge.
'12 AW 550xi / Dinan S2 / Arkym CF Spoiler / 3D Design Style Splitter / Eisenmann Race Exhaust / 20' HRE FF01 / ACS Springs / CF Grill / CF 3D Design Diffuser / Blue Calipers...
      07-08-2014, 06:01 PM   #4
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
If I'm not mistaken, member @wrsbmw has it on order! We are waiting to see how he evaluates it soon
      07-08-2014, 08:49 PM   #5
wrsbmw
wrsbmw's Avatar
108
Drives: 2018 Ferrari 488 Spider
BMW called to say that it's in and I can schedule the install. I will be doing some quarter runs on the way back from Orla tomorrow and that will conclude my pre tune testing. I am getting stage 2 with the cold air intake.
      07-08-2014, 09:20 PM   #6
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
Thanks for update! can't wait to see the result
      07-08-2014, 09:48 PM   #7
soooma
///MD
soooma's Avatar
Drives: M5 F90
I wouldn't do it
Had it on my 550i and I believe he uses BMW under rating to his benefit and tries to claim the difference !!
      07-08-2014, 10:16 PM   #8
Knight Commander
Originally Posted by soooma View Post
I wouldn't do it
I had it on my 550i and it made a dramatic difference. Maybe your installer was an amateur and didn't properly flash the ECU.
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450
      07-08-2014, 10:29 PM   #9
boots
Curve Thrasher
boots's Avatar
623
Time will tell after a couple guys test out their new toys!
      07-09-2014, 12:11 AM   #10
greentrbo95gst
greentrbo95gst's Avatar
1231
Drives: 21 M5 Comp
I spoke with couple SA's from two different dealerships and they both claimed that the warranty will be voided if the car shows up with any type of computer piggy back.
Dinan suggests you remove it before you take it in.......hint hint
      07-09-2014, 12:24 AM   #11
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
Are you sure? I thought Dinan has relationship with dealers and get them installed!!! They claim their products do not void warranty
      07-09-2014, 02:28 AM   #12
Spinny02
Spinny02's Avatar
This is known and thats why Dinan matches the factory one. No diff then if you showed up with the BMS tune.
The difference is that It's on Dinan once the d tronics piggy back is on the car. If it's a part that could be related to the tune then Dinan should take care of it. My local dealer is also the Dinan dealer so theoretically it should be easy to get the issue sorted. Either way they are going to fix it.
      07-09-2014, 12:49 PM   #13
David 12
David 12's Avatar
127
Drives: 2019 BMW X5 50i BSM, M Sport
I think one of the problems is that we are used to horsepower readings at the wheels, such as on a dynojet. At least that is how BMS reports the gains but Dinan uses the measurement at the crank. Also, unless i missed them, I can't find actual dyno charts on the Dinan website. I know assessing a tune isn't just as simple as max HP and torque gains but it can give you a general idea of the improvements.
I looked at some of the posts regarding Dinan tunes over at Bimmerfest and while some people are happy, there are quite a few people that are underwhelmed with their Dinan tune. Maybe they are expecting more because of the crank horsepower claims, incorrect installation, etc.
Just like anything else, do your homework before selecting a tune.
By the way, the local BMW dealer is an authorized Dinan installer so I am not sure how removing the tune will do you much good if the BMW dealer actually performed the install.
Dave
      07-09-2014, 01:06 PM   #14
greentrbo95gst
1231
Drives: 21 M5 Comp
Dealing with the dealer and bmw na claims department are two different things. 6 years ago bmw na sent out a manifest to all dealers stating they will no longer approve claims on Dinan equipped cars.
I've had aftermarket parts installed on the car by a dealership, but when you read the fine print on your invoice it states that you only receive warranty on labor and not on the car or part itself. Food for thought.
      07-09-2014, 08:01 PM   #15
Knight Commander
Whatever manifest you refer to couldn't have said what you wrote because that would be an illegal position for BMW to take.
      07-09-2014, 09:28 PM   #16
savela
savela's Avatar
Drives: 2015 X5M
True this.
They (car manufacturers) are obligated to prove that the aftermarket install directly caused whatever failure before they deny a claim - they can't blanket refuse warranty coverage. Dinan covers whatever failures are due directly to their product, I believe.
In short, if you have a BMW dealership that also is a Dinan dealership, you're covered. Can be a bit tricky if you're dealing with BMW and Dinan individually as BMW is more likely to point fingers.
2015 ///X5M
2014 ///M6 (traded)
2014 ///M5 (traded)
2011 550i (traded)
      07-09-2014, 10:31 PM   #17
greentrbo95gst
1231
Drives: 21 M5 Comp
Unless there are people here that own a BMW authorized center, none of us will ever know if this was true or not.
I received the information from a GM of dealership X and an owner of a dealership Y. Cant say I saw the actual letter or message.
Claims/warranty has every right to refuse a claim if a car has a part that was not part of the car's manufacturing process.
      07-10-2014, 12:17 AM   #18
Knight Commander
Yes in that case what you heard was probably hyperbole. The law is very clear on this. You can only deny warranty for parts whose reliability can be proven to be compromised by the aftermarket modifications. It cannot void the warranty on a blanket basis which is what your post implies. Their rights in this regard are quite limited contrary to your statement.
The validity of your warranty even in modified vehicles is assured by both the Moss-Magnusson Act and also recent policy statements and actions taken by the FTC.
      07-10-2014, 01:03 AM   #19
soooma
///MD
soooma's Avatar
Drives: M5 F90
I didn't mean to say it didn't make a difference bit hr claimed all the difference from 400 to 500 which is not true as car already made 440-450 or so as underrated, that's what I meant and come on torque 580!! 80 more than M5 Do you feel that?!!!!!
      07-10-2014, 09:28 AM   #20
Knight Commander
I always felt the 550i Dinan had more torque than the M5. Also felt it had a much better throttle map. M5 is faster because of hp and DCT.
      07-14-2014, 06:47 PM   #21
EuroKar
Your absolutely right.
Its unfortunate that there are dealerships out there that will still make customers believe that they are having their warranty voided.
I know someone that bought a modified E92 M3, car was serviced at BMW since day 1. Then new owner (female) brought car in and they threatened her with "voided warranty" scare. Regardless, they ate their words and never gave her a hard time again.
Anyone with service advisors telling you otherwise, your being lied to.
      09-04-2014, 10:48 AM   #22
Hawkeye1
Displaced Iowan
Hawkeye1's Avatar
Drives: 2018 M3 CP
Dinan Stage 1 Installed - Dyno and 1/4 Mile Tomorrow
Guys,
Had Dinan Stage 1 installed at a BMW dealership in the Dallas area yesterday. Took it out last night for a 'first impression'. Biggest difference for me, so far, is torque in the mid-range. Did an 'MDM and Mash It' from a standstill. The tires spun through first gear, but not badly. Second gear hit with a bang, followed immediately by a rapid fishtail to the left. (Fun, but it got my heart going...) It 'feels' faster, but it was already fast, so to be sure I'm going to Alamo in Arlington for a dyno run tomorrow. It's a Dynojet, and I know there are differing opinions regarding the accuracy of the various dynos, but it's available tomorrow and I want it done before the 3 day 'money back guarantee' from Dinan expires. I don't have a 'baseline', but I've seen stock M5 dynojet results elsewhere. I'll also head for the dragstrip tomorrow night. I was there two weeks ago in very similar weather conditions, so apples to apples comps should be possible. I'm most interested in trap speeds, since I run stock tires and am traction limited off the line. I'll post the results of both events. One question for the group: Is there such a thing as a 'Dyno Mode' on an F10? The dyno operator said he worried about the ECU shutting down the fun unless the car was set up correctly. (He specifically mentioned that some AMG products must be set up to dyno them, and he thought it applied to BMW also, but wasn't sure.) I'll take any input from the group, but need it soon... Thanks.
2011 Z4 35i Dinan Stage2 - Hers
2015 Golf R APR Stage 2 - Mine
2019 Tesla Model X Perf. w/ Ludicrous - Hers
2018 911 GT3 (Manual) - Mine
2013 911 S Cabriolet - Mostly mine
