      03-13-2013, 04:32 PM   #1
PatrickC23
PatrickC23's Avatar
2013 BMW ///M5  [0.00]
Anyone hardwire a Passport 8500?
2016 991.1 911 Carrera GTS
      03-14-2013, 11:09 PM   #2
Grayblack
Grayblack's Avatar
182
Drives: E92 M3 and G07 X7
I hardwired my Escort Smartradar to the sunroof.
      03-15-2013, 08:53 AM   #3
thebishman
Drives: ‘24 iX M60
Can you identify the 12V ignition switched 'hot' wire you used?
TIA,
Bish
      03-15-2013, 09:49 AM   #4
PrecisionP
PrecisionP's Avatar
Drives: ATPC's
[QUOTE=thebishman;13643456]Can you identify the 12V ignition switched 'hot' wire you used?
TIA,
Bish[/QUOT
There is a guide on here for your vehicle on the hot and grounding wire to use. He used the wiring off of the sunroof motor if I rememeber correctly. I had to use my rear view mirror wiring. The overhead console wiring is a no go and will lead to a fault if disconnected in the M6.
      03-15-2013, 09:55 AM   #5
M54ccibo
M54ccibo's Avatar
Drives: '16 GT4
Hardwired my V1 using the sunroof. Tapped the green/brown wire forward of the sunroof motor. Grounded to one of the two sunroof bolts. That was a royal pain in the a$$...use a spade connector, so you don't have to completely remove the nut.
Google is your friend, do a search for "v1 hardwire F10" and you'll get the thread I used from one of the other forums.
Have fun!
Current: '16 GT4
Past ///Ms:
'10 E60 M5, Space Gray/Black
      04-23-2013, 04:52 AM   #6
hotobd
Drives: BWM X3
I've no idea.
      07-07-2013, 01:03 PM   #7
AlphaAlpineM6
AlphaAlpineM6's Avatar
anyone
2008 M3 Sedan + catless + Tune
2012 CLS63 AMG
2014 M6 Coupe + catless + KW V3
2015 Porsche GT3
, 2015 M3, all stock, 1/1 Space Grey
