      12-28-2017, 11:21 AM   #1
AWF10M5
Drives: f10 m5
Have added some videos of the noise.
(Cruising) U can hear the frequency change when i tap
(under load)
(Notice how it goes away in 5th)
This guy had same issue but he has a 6MT.
2013 M5 DCT with catless dp, grill intake and resonator delete
I have the same exact type of noise. It's there when accelerating.
Not sure if it's because of the very cold recently temperature been around 18-20 F.
It is NOT from engine. It seems to be under the gearbox. It sounds like a supercharger sometimes it's louder than before sometimes it's quieter but it's always present. Even when you let off the pedal the noise is there the frequency changes when you press the pedal.
For some reason in 5th gear noise is barely audible.
I did not have this noise before. The car is still pulling hard and DCT behaving fine. I just took the car on a 9 hour road trip and no problem
      12-29-2017, 12:23 AM   #2
AWF10M5
Drives: f10 m5
So I noticed when accelerating the whirring gets louder but once in 5th gear its gone, back in 6th, and 7th. It is in pretty much every gear but the 5th gear.
Car continues to pull strong, DCT is shifting great. I know some GTR have this type noise and they say its normal but this never was there before and GTR is different class of car.
any suggestions
      12-30-2017, 08:34 AM   #3
finlandm5f10
Drives: BMW M5 F10&Audi RS6 C7 2016
any suggestions
Do you check dct oil? I think you have leaking gasget. I think it might be
Megatronic gasket. Leak is so tiny that not leak when car is parked. Only drive you shold look under the car when gearbox is warm right after driveing.
Sorry bad english.
      12-30-2017, 09:14 AM   #4
AWF10M5
Drives: f10 m5
That piece is dry
Lot of member have this noise in dct and 6mt I guess I'll just live with it
      12-31-2017, 06:00 AM   #5
finlandm5f10
That piece is dry
Yes i think you can live with that. But noise isn’t normal. My frends m6 y 2014 makes exactly same noise and it is leaking gasget. But if your gasket area is dry that is good. Easy way that drive litle while whitout that plastic cover under gearbox. Then you can find if gasget leaks.
AWF10M5222.50
      12-31-2017, 06:01 AM   #6
finlandm5f10
Why your cel is on?
      12-31-2017, 01:54 PM   #7
AWF10M5
Drives: f10 m5
I had it checked just two month ago when I was at 49k mile. The big transmission pan itself was dry.
Now at 57k I think its possible it could be leaking as its a common issue on all BMW DCT. I am going to order the full kit and replace the transmission pan with upgraded gasket, perform full flush and also replace the mechatronic sleeve gasket.
Does you know if the DCT needs to be removed for the mechatronic gasket?
The CEL is on due to catless downpipe without a tune
      12-31-2017, 04:31 PM   #8
finlandm5f10
Yes. You have to remove dct for the mechatronic gasget. There is one other thing. You should test this 4 or 5 torx bolts. Not gasget bolts. This bolts biger than gasget bolts. Iwe seen few dct bolts are loosen.
      12-31-2017, 04:34 PM   #9
finlandm5f10
Is there any sense use catless downpipes without tune. Just ask. I think this drops torgue with lower rpms.
      12-31-2017, 05:19 PM   #10
AWF10M5
Drives: f10 m5
I did just for sound
Is it obvious the side gasket (mechatronic) is leaking once you pull the bottom tray off? I am hoping the side gasket is not leaking but if it is there anyway to replace without dropping the DCT?
      12-31-2017, 06:52 PM   #11
AWF10M5
Drives: f10 m5
Do u know which bolt you mean?
Can u please help me out thx
Is it this part number for the trans pan bolts ? Or are they different than the 14 trans pan bolts 28107842386
      12-31-2017, 07:39 PM   #12
AWF10M5
Drives: f10 m5
same type of whine im guessing from this guy 2
      01-01-2018, 02:20 AM   #13
AWF10M5
Drives: f10 m5
Just went for a drive was -5 F the nose is present even during coasting in any gear besides 5th goes away as soon as you switched to N.
NO LEAKING my mechanic change my interior there is a huge foam insulator that go under DCT shifter he forgot to put these foam piece on. thinking this is why im hearing noise now
      01-01-2018, 06:24 AM   #14
finlandm5f10
No. Sorry. You have to drop dct.
      01-01-2018, 06:28 AM   #15
finlandm5f10
I i mean thise big torx bolts bigger than trans pan bolts. If i wrote in finnish use translater.
Pultit eivät ole vaihdelaatikon pohjan pultit vaan alimpana vaihdelaatikoa olevat isot torx pultit. Näiden pulttien kiinnityskohdassa ei ole tiivistettä vaan tiivistemassa.
      01-01-2018, 06:29 AM   #16
finlandm5f10
Sorry you dont have ä näiden mean those.
      01-01-2018, 06:32 AM   #17
finlandm5f10
This guy have VERY bad transmission issue. Clutch is deffenetly bad and mechatronic seems to not working good.
      01-01-2018, 02:04 PM   #18
sonnenschein3000
Drives: 2015 M5 (F10 LCI)
By any chance, do you downshift harshly whilst slowing down (i.e. dropping it to first gear so the revs go up to like 5k RPM)?
      01-01-2018, 02:19 PM   #19
AWF10M5
Drives: f10 m5
All the time lol
      01-02-2018, 12:01 PM   #20
sonnenschein3000
All the time lol
This may well be why...
I've personally noticed in the past when I had a CL63 AMG (with AMG's MCT which is on a similar principle using clutches) that the whine got slightly worse and worse each time I drove it like that, and realised that I was being too harsh when driving it.
I never got round to getting it investigated but it wasn't very good for the car to do that. From then on, I use my brakes for braking (although it doesn't sound as good from outside!)
EDIT: Just so you know, my username has now changed to sonnenschein3000
      01-21-2018, 03:05 PM   #21
finlandm5f10
Did you found where that noice is?
      07-26-2019, 02:52 PM   #22
bunger78
Drives: 07 E90 335i
Anyone update on this whine?
I have the same issue, where I can hear it in 4th, 6th and 7th, but 5th is quiet.
I want to make sure this is an actual issue before I take it to the dealer.
Thanks!
