      05-13-2015, 01:12 PM   #1
Zubek
Zubek's Avatar
49
5mm spacers
Hi there,
I put BBS wheels on my M5 and it seems like the back offset is not what I was expecting (ET is 35). Thinking of adding 5mm spacer but all of 5mm spacers on the market are missing the centre flange. I was recommended not putting items without the flange especially it's a very powerful car. Wouldn't feel comfortable with this solution anyway.
Will try with proper 10mm spacers but believe they might by too wide for this wheel.
Any suggestions ?
      05-13-2015, 05:25 PM   #2
v3n0m
Drives: 2013 MCB M5
Below 10mm there won't be a lip. See here for explanation on flat spacers:
http://www.turnermotorsport.com/t-wheel-spacers.aspx
Generally a bad idea to use flat spacers since it means the bolt won't have as much of a contact area when tightened (i.e. it won't screw in as far).
      05-17-2015, 01:57 AM   #3
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
http://f10.m5post.com/forums/showthread.php?t=1117435
