      05-14-2015, 10:42 AM   #1
285ferrari
Drives: 2018 M550
Loss of Power
Would installing exhaust result in any feeling of power loss? I had my Eisenmann exhaust installed this morning and the car does not seem to pull hard like before. Usually about 4k rpm the car pulls very hard up thru the powerband, today is seems sluggish, does not pull as it did before.
      05-14-2015, 02:58 PM   #2
285ferrari
Drives: 2018 M550
Possible that the computer needs to learn the "new" exhaust
      05-14-2015, 03:46 PM   #3
badblack550xi
badblack550xi's Avatar
Drives: F10 550i 2011 F90 2020 COMP
give it some time
2011 550i RWD 60-130 7.35
      05-14-2015, 04:02 PM   #4
285ferrari
Drives: 2018 M550
Originally Posted by badblack550xi View Post
give it some time
Hope that is all it is--Thanks
      05-14-2015, 06:37 PM   #5
MCarsFan
MCarsFan's Avatar
Drives: 2014 BMW M5 F10 CP
2014 BMW F10 M5  [10.00]
Take your car for a spin. I agree - I think the car is adjusting to the new exhaust. Good luck!
      05-14-2015, 07:25 PM   #6
A Frankfurt
Drives: German
Did you only install the rear muffler ?
      05-14-2015, 07:44 PM   #7
285ferrari
Drives: 2018 M550
Yes, both the rear mufflers, Eisenmann - - Drove it home from exhaust shop about 30 miles and have not driven it again today
      05-14-2015, 10:03 PM   #8
MCarsFan
MCarsFan's Avatar
Hope your worries are unfounded and everything 100%
      05-15-2015, 10:22 AM   #9
gmfive
gmfive's Avatar
Drives: 2014 F10 M5 AW
2014 M5  [0.00]
I had felt the same way after installing my E-Sport. It felt okay in a few days. Don't know what percentage was psychological vs the engine acclimatizing itself to it. My E-Sport has gotten louder over time, going uphill in 2nd sounds sweet.
2014 AW F10 M5, mostly stock
      05-16-2015, 03:47 AM   #10
lfelunden
lfelunden's Avatar
Germany
60
Drives: BMW M5 F10
No worries
For fast adaption, do some 3rd gear pulls to redline, then turn off the car, wait 30 min (ecus adapt). Then do it again, after a couple of times you WILL notice a big difference in power
      05-16-2015, 07:28 AM   #11
285ferrari
Drives: 2018 M550
Originally Posted by lfelunden View Post
No worries
Thanks, I will try that today
      05-16-2015, 11:40 PM   #12
M54ccibo
M54ccibo's Avatar
Drives: '16 GT4
Check to make sure the vacuum tubes to the exhaust valves are either sealed or connected properly.
Current: '16 GT4
Past ///Ms:
'10 E60 M5, Space Gray/Black
      05-17-2015, 06:17 PM   #13
lfelunden
lfelunden's Avatar
Germany
60
Drives: BMW M5 F10
Did it work out? Also, do you have any error codes maybe?
      05-18-2015, 06:49 AM   #14
285ferrari
Drives: 2018 M550
No error codes. Added a JB4 on Saturday morning have since put about 100 miles on car in last couple days. No change
      05-20-2015, 12:40 PM   #15
lfelunden
lfelunden's Avatar
Germany
60
Drives: BMW M5 F10
So your car is still "slow"?
      05-20-2015, 03:32 PM   #16
285ferrari
Drives: 2018 M550
It SUCKS!!! Best way to describe it feels like the turbos are not working at all. Very sluggish. Have gone a couple hundred miles since last week, did numerous 3rd gear pulls and nothing.
Not sure what to do at this point.
      05-20-2015, 04:46 PM   #17
JPMD
Drives: 2014 BMW M5
This is what I was thinking.
Was this checked?
      05-20-2015, 04:48 PM   #18
bobblehead
bobblehead's Avatar
Drives: warp speed
+1 . Perhaps, take it to another exhaust shop for them to double check that vacuum tubing.
      05-20-2015, 04:57 PM   #19
285ferrari
Drives: 2018 M550
Was this checked?
I don't think they can be connected on the Eisemann, so they must be sealed off? Does that make sense? If so, anyway for me to check that?
      05-20-2015, 05:01 PM   #20
M54ccibo
M54ccibo's Avatar
Drives: '16 GT4
If the exhaust was used there were a few early samples with valves. Not new any longer. But yes, if no valves they have to be sealed.
Current: '16 GT4
Past ///Ms:
      05-20-2015, 05:53 PM   #21
A Frankfurt
Drives: German
I've never experienced a vehicle loosing power by having to adapt itself from only replacing a rear muffler
Something is wrong.
If you installed a JB harness kit at the same time, make sure it is installed and setup correctly
      05-20-2015, 06:07 PM   #22
285ferrari
Drives: 2018 M550
Was this checked?
The shop "thought" they sealed them off, they were mistaken, I found the tubes opened. I sealed them off. Will take it for a drive tomorrow, hopefully that was the issue. Thanks for all the help everyone.
