      02-10-2016, 05:52 AM   #1
drbru
Drives: f10 m5
M performance installation using BETALink
So..Ive put a few posts out there following my M performance spoiler getting stolen 12 hours after installation using 3M tape...
I did plenty of research beforehand to choose between using 3m tape and Betalink and initially went for the 3M option due to ease of installation...I didnt really find any mention when using 3m tape with regards to the risk of theft but through personal experience - its very easy to remove a spoiler by hand which has been installed using 3m tape...
So for round 2 I went down the BETAlink option and wished I had done it in the first place..So here is my DIY, apologies I didnt take any pics but hopefully the below will help and I should mention it was much easier than i thought and did not need a second pair of hands
1) Purchase M performance spoiler and BETAlink K1 adhesive kit
2) Use sandpaper that comes with adhesive kit to roughen up all contact surfaces on the underside of the spoiler
3) then clean with BETAclean which comes with the adhesive kit..Also thorough clean the surface of the bootlid with isopropanol and betaclean solution
4) time for test fit on the car... Position the spoiler appropriately and mark all edges either with masking tape or a pen to mark out the exact poisition of the spoiler as you dont want to fiddle with it once the BETAlink is on the spoiler itself
5) next step is to put the nozzle supplied with the adhseive kit on top of BETAlink tube and secure with some form of tape to stop the nozzle popping off.
6) I previously bought some 20 ml syringers...Directly pour as much betalink into the syringe as possible from the original tube as using the syringe makes things a lot easier to control when applying the betalink directly to spoiler
7) Apply to spoiler using syringe - apply liberally across the spoiler in all contacts areas but try to stay away from edges to minimise any seeping out of the betalink once on the car....
8) USing the previously marked up positions, mount straight onto boot lid - secure immediately with a few strips of painters/masking tape to free up your hands - (I only needed to secure at the corners and a couple of strips in the middle)
9) then using the BETAclean, go all around the spoiler and clean off any betalink that has seeped out - do this as quickly as possible as you dont want it to harden too much
10) once you are happy you have cleaned off all of the excessive, do a final fitment check and then tape the entire spoiler to the bootlid so that it cant move whilst the betalink is curing.. - be liberal with the tape and make sure the spoiler cant move especially at the edges.
11) The next bit is waiting - it was cold when I installed my spoiler (5 degress C) so I knew the curing time would be effected... - The instructions on the BETAlink adhesive state that it can be applied from 5 degrees up to 40 however BMW does not recommend installing under 18 degrees C.. BETA link instructions state however that under 23 degrees C, you must allow 6 hours curing before driving off...Either way I played it safe..I didnt remove the tape until 12 hours later and then didnt drive the car until 24 hours later...
When grasping the spoiler it has a much more solid feel now compared to the 3M tape and is definately more secure. I know some people prefer to use 3m tape as it can be removed but it can also be removed by thieves even though it may be suitable for normal driving...The way I saw it is that I dont want this spoiler to be stolen again and I appreciate that if someone tries to steal it again they will prob damage the spoiler and bootlid in the process however im not likely to want to remove the spoiler from the car myself so I am happy that it is now permanently fixed
Hope the above helps and hopes to displace any fears about using BETAlink - it really wasnt difficult and can easily be done without having to pay a dealer to do so
      03-24-2016, 07:47 AM   #2
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
thanks for the writeup! where did you purchase the betalink and pictures would have been cool for reference!
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~
Follow me on Instagram: lsturbointeg
      03-24-2016, 10:55 AM   #3
drbru
Drives: f10 m5
Sorry mate, completely forgot to take pics...Got the BEtalink from BMW but im sure it can be sourced elsewhere
      03-24-2016, 07:13 PM   #4
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT & E90M3
Thanks OP. I too learned that double sided tape isn't a good option, the edge keeps coming loose after a car wash. Most body shop will have adhesive similar to Betalink.
Otherwise, this place sells them cheapest.
http://www.getbmwparts.com/partlocat...catalogid=4462
      03-24-2016, 08:08 PM   #5
lsturbointeg
Thanks for the link!
      03-24-2016, 08:34 PM   #6
JNoSol
JNoSol's Avatar
Your dealer should have this in stock too. If you must use double sided tape, buy them from the automotive paint shop or the body shop. They have industrial grade double sided tape.
      03-26-2016, 11:59 AM   #7
13M5F10
Hide! My wife's coming!
13M5F10's Avatar
Got pics of the final product?
      04-04-2016, 04:08 PM   #8
lsturbointeg
do you know if it's not a good idea to use duck tape to hold everything down? i notice the painters tape doesn't hold well at all. i'll give the regular masking tape a try tho
      04-04-2016, 04:22 PM   #9
drbru
Drives: f10 m5
wouldn't use duck tape as you would have to deal with getting the adhesive residue left from that off as well...Masking tape worked well for me, just put absolutely loads on
      06-07-2016, 03:20 AM   #10
TurboLlew
TurboLlew's Avatar
South Africa
12
Drives: BMW M5 (F90) | Alfa Romeo 4C
Not sure if this helps the discussion, but the dealer used beta clean and beta link when installing mine. The tape they used is in the pics. Beta Link also results in it being a bit more flush with the surface than using tape.
In my excitement, I thought I'd save some time and remove the spoiler which was easy. The goo was another story. Beta Clean made short work of it and I felt pretty silly for not just waiting.
We let it set for 12 hours at about 20 degrees celcius before i even drove the car. They had tape that they use for installation of spoilers to hold it in place... it was stickier than painter's or masking tape but not as sticky as the tape used to seal boxes. Certainly not as strong as duct tape. Did the job.
No issues 3 months later.
Old vs. New
      06-07-2016, 03:41 AM   #11
lsturbointeg
thought i would add to this since i used this thread for help
i ended up using the black silicon adhesive to fill in the minor gaps:
and the final results:
      01-14-2018, 12:17 PM   #12
TheHouseWon
TheHouseWon's Avatar
644
Drives: 2013 M5
How do you remove the stock one--heat and pull? Using string/floss?
      01-15-2018, 05:18 AM   #13
BMW Collector
Drives: 535
Fishing wire a little heat will help. Do you have batelink kit?
