      06-14-2015, 07:36 PM   #1
13M5F10
Hide! My wife's coming!
13M5F10's Avatar
OEM F10 Exhaust Valve Mod
Finally got around to doing this since I picked up my M5. It definitely improves the exhaust note at startup and cruising around. Will keep me satisfied until I get an exhaust system.
What I used
Flathead screwdriver
Band Clamps 1-13/16 to 2-3/4 Stainless Steel
While turned off, I wrapped the band clams around the actuator arm and its mount and started turning the screw. Once it the screw becomes harder to turn, I pushed the valve arm in to full open and screwed the clamp further until it was secured.
Here are the pictures. I'll post a video later.
      07-02-2015, 01:36 PM   #2
PeteM6
PeteM6's Avatar
33
Drives: 2015 M5 CP
Just did this to mine, sounds a bit better. Thanks for this.
      07-08-2015, 05:38 PM   #3
Thunder43
Thunder43's Avatar
10
Drives: 2013 F10 M5
Did this shortly after picking mine up after reading about it. Honestly, quite surprised how much better it sounded. Cold start grins guaranteed!
2013 M5 BSM/SS - BMS Stage 1, Turner Race Exhaust, 12mm spacers, KW HAS, Dinan sway bars, IND cosmetic package, LED kit, V12 coded
      07-14-2015, 09:59 AM   #4
13M5F10
13M5F10's Avatar
Just realized I never posted the pictures.. I ended up getting the Turner Muffler Delete so never got to get a video but here are some pictures. If you look at the solenoids, you will see that I have the band clamp around the actuator/arm.
      07-14-2015, 05:08 PM   #5
Thunder43
Thunder43's Avatar
10
Drives: 2013 F10 M5
How do you like the Turner Delete??
Do you find it much better/louder than stock with valve mod? Tone difference as well as volume? Been considering this also as an upgrade to running stock cans with open valves. Let's hear it!
      07-14-2015, 07:30 PM   #6
13M5F10
13M5F10's Avatar
I love it and it's ALOT louder outside than the stock exhaust. Inside the cabin it's not much louder than stock.
i PM'd you some videos.
      09-20-2015, 05:15 AM   #7
StevanM5
StevanM5's Avatar
19
Drives: M5 F10
Where does the vacuum solenoid seats?
Is there no way to cut dme signal and take an ignition plus with a switch to open and close valve manually?
      09-20-2015, 09:21 AM   #8
13M5F10
13M5F10's Avatar
There are several devices on the market that can allow you to manually control your exhaust.
JB4 from BMS
http://www.exhaustmeister.com/
I am not sure about your DME question as I do not have that experience but might be worth asking in tuning page.
I tucked the hose in the bumper above the muffler. The hose runs to the solenoid that is located in the trunk behind the carpeting. This is what I was told but I've never confirmed.
      10-15-2015, 09:15 PM   #9
Sultanalsaif6
Drives: BMW M5 2013
Hi . I was wondering if you are welling to sell your mufflers . Thank you
      10-16-2015, 06:25 AM   #10
13M5F10
13M5F10's Avatar
Sold mine already.
      10-16-2015, 10:18 PM   #11
Head
Head's Avatar
20
Drives: RRS Supercharged / 991 Turbo S
I have a set. But I live in New Zealand... hmmmmm.
Cheers Craig.
2015 White 991 Turbo S - Warp Factor 9!
2016 Yulong White Range Rover Sport 'Stealth Pack'
2015 Alpine White M5 'Competition Pack' - Gone
1971 Mercedes-Benz 280SE - Just love looking at it!
2012 Alpine White M5 - Gone
