Reply
      06-14-2011, 07:08 PM   #1
Drives: E90 M3
Exclamation 2012 BMW M5 (F10) - Wallpapers, Official Information, Specs, Reviews, and Videos
2012 BMW M5 (F10)
Size:  116.0 KBName:  bmwm5-2.jpg
Size:  113.6 KBName:  bmwm5-3.jpg
Vital Stats
  • BMW V8 Twin Scroll Twin Turbo
  • Displacement: 4,395cc
  • Weight, unladen (DIN/EU) - 1870kg / 1945kg (4,122lb / 4,286lb)
  • 560hp (at 6,000rpm) (E60 M5 reached max 507PS at 7750rpm)
  • 501 lb-ft torque (max torque at just 1500rpm) (vs E60 M5 which had max torque of 507Nm)
  • 7-speed DCT transmission (manual transmission also likely, based on recent photos)
  • Average fuel consumption: 9.9 litres/100 kilometres (28.5 mpg imperial / 23.5 US MPG)
  • 0-100km (0-62mph) in 4.4 seconds (E60 M5 took 4.7 seconds)
  • 0-200km (0-124mph)in 13 seconds
  • Top speed: 250kmh (155mph)
  • M-Drivers-Package will increase top speed from 250km/h to 305km/h (155mph to 189mph)
  • CO2 emissions: 232 g/km, exhaust standard: EU5.
  • Active M Differential
  • Tires shown are 265/35 ZR 20" front 295/30 ZR 20" rear (optional -- 265/40 ZR 19" front 295/35 ZR 19" rear standard)
PRESS RELEASE + Expand
Full Press Release: F10 M5 Press Release
Full Press Release #2: Detailed Media Information (Press Release #2)
At a glance
• Fifth generation of the world’s most successful high-performance saloon in the premium segment of the executive class; new BMW M5 is an exceptionally dynamic high-performance sports car with four doors and five seats; consistent further development of the vehicle concept initiated in 1984 with the first-generation BMW M5; compelling track potential combines with the comprehensive practicality of a luxurious business saloon; groundbreaking character headlined by significantly improved efficiency, supreme long-distance comfort, and innovative driver assistance systems and infotainment functions.
• World premiere of a newly developed BMW M high-performance engine: high-revving 4.4-litre V8 engine with M TwinPower Turbo package – consisting of Twin Scroll Twin Turbo technology, cross-bank exhaust manifold, High Precision Injection petrol direct injection and VALVETRONIC fully variable valve control; 412 kW/560 hp at 6,000 – 7,000 rpm, maximum torque: 680 Newton metres (502 lb-ft) from 1,500 rpm; lag-free power delivery, typical M car thrust.
• Significantly improved balance between performance and fuel consumption: acceleration 0–100 km/h (62 mph) in 4.4 seconds, 0–200 km/h (124 mph) in 13.0 seconds, top speed: 250 km/h / 155 mph (305 km/h / 190 mph with M Driver’s Package); average fuel consumption in EU test cycle: 9.9 litres/100 km (28.5 mpg imp / 23.7 US MPG); engine output 10 per cent up on predecessor model, maximum torque increased by 30 per cent, fuel consumption cut by more than 30 per cent; extensive Efficient Dynamics technology, including Auto Start-Stop function and Brake Energy Regeneration.
• Power transfer to the rear wheels via the seven-speed M Double Clutch Transmission Drivelogic; traction-optimised automatic gear selection; Launch Control; Low Speed Assistance; automatically activated parking mode; M-specific gear selector; M leather steering wheel with shift paddles.
• Hallmark M conceptual harmony produces superior performance characteristics with precise interplay of drive and chassis technology, aerodynamics and weight balance; power-to-weight ratio: 3.3 kg (approx. 7 lb)/hp; M-specific suspension (front and rear axle kinematics), M Servotronic steering, Dynamic Damper Control, DSC stability control system including M Dynamic Mode; bodyshell mounting using special panels; lightweight compound high-performance braking system.
• Outstandingly agile handling thanks to innovative rear axle differential with Active M Differential; electronically controlled multi-plate limited-slip differential enables fully variable distribution of drive between the rear wheels to optimise traction and stability in dynamic lane change manoeuvres and acceleration out of corners; degree of lock can be varied between 0 and 100 per cent according to the situation; fast, precise and pre-emptive responses thanks to constant data cross-checking between the Active M Differential and DSC stability control system, and monitoring of the accelerator pedal position, wheel speed and yaw rate.
• Two individually configured set-ups for the car can be called up using the new M Drive buttons on the steering wheel; range of programmable parameters unique in the segment: accelerator responses, M Servotronic responses, Drivelogic shift program, DSC mode, Dynamic Damper Control and information in the Head-Up Display.
• Characteristic body design with familiar M aesthetics reflecting the car’s extremely dynamic yet precisely controllable nature; specific design features contributing to performance characteristics; front apron with extremely large air intakes for the engine and brakes; athletically flared wheel arches to emphasise wide track; hallmark M “gills” with integrated indicator bars; aerodynamically optimised rear apron with diffuser between the right and left-hand pair of twin exhaust tailpipes; gurney-style rear spoiler on the boot lid; 19-inch M light-alloy wheels in exclusive double- spoke design.
• Unique combination of sports car cockpit and luxurious ambience for the interior; M-specific instrument cluster in black-panel technology; newly designed, leather-covered centre console; M sports seats; standard specification also includes: Merino leather upholstery with extended features, exclusive Aluminium Trace interior trim strips, BMW Individual roof liner in Anthracite, electrically operated steering column adjustment, four-zone automatic climate control and ambient light.
• Extensive range of driver assistance systems and mobility services from BMW ConnectedDrive unmatched by competitors in this segment and beyond: M-specific Head-Up Display (standard), Adaptive Headlights for standard xenon light, High-Beam Assistant, BMW Night Vision with pedestrian recognition, Lane Change Warning System, Lane Departure Warning System, Surround View, Speed Limit Info, internet usage, extended integration of smartphones and music players, real-time traffic information and apps for receiving Web Radio and using Facebook and Twitter.
• Almost all BMW 5 Series Saloon equipment options available, including Comfort Access, M multifunction seats, active seats, doors with Soft Close Automatic function, hands-free tailgate opening, electric glass roof, trailer coupling.
Original Concept M5
Link to original Concept M5 Thread: http://f10.5post.com/forums/showthread.php?t=511101
BMW M5 Wallpapers
BMW M5 Wallpapers
BMW M5 Twin Turbo V8
BMW M5 Interior
BMW M5 Monte Carlo Blue in Action
BMW M5 Exterior
BMW M5 Interior Exterior
BMW M5 Powertrain/Drivetrain
BMW M5 UK Release
Vital Stats
  • 501lb-ft torque (max torque at just 1500rpm) (vs E60 M5 which had max torque of 507Nm)
  • M-Drivers-Package will increase top speed from 250km/h to 305km/h (127mph to 189mph)
  • Tires are 265/35 ZR 20" front 295/30 ZR 20" rear
Differences between the F10 M5 S63Tu engine and X5/6 M S63 engine
S63Tü (F10 M5)*S63 (X5/6 M)
Engine
Configuration/No of cyls/valvesV / 8 / 4V / 8 / 4
Engine technologyM TwinPower Turbo technology with cross-bank exhaust manifold, twin-scroll turbocharging, direct petrol injection, (High Precision Injection), VALVETRONIC and Double-VanosM TwinPower Turbo with exhaust gas manifold connecting both rows of cylinders. Twin Scroll Twin Turbo technology. High Precision Injection. double-VANOS
Effective capacity4395 ccm4395 ccm
Bore88.3 mm88.3 mm
Stroke89.0 mm89.0 mm
Compression ratio10.0:19.3:1
Maximum Boost Pressure1.5 bar1.2 bar
Output560hp555hp
@5,750 – 7,000 rpm6,000 rpm
Torque501 lb-ft501 lb-ft
@1,500 – 5,750 rpm1,500 – 5,650 rpm
Redline7,200rpm7,000rpm
* Tü is German and stands for 'Technische Überholung' which translates to 'technical revision'
Two more innovations of the S63Tü:
- Innovative solenoid valve injectors in the new BMW M5 engine use multiple injections to achieve an extremely precise mixture preparation.
- VALVETRONIC
This is the biggest difference. As BMW puts it:
"Throughout each of its four previous generations, the heart of the BMW M5 has been its high-revving, high output-per-liter engine fed by individual throttle plates.
The new M5 engine introduces VALVETRONIC variable valve control system for the first time on a BMW M engine – effectively providing 16 individual throttles.
VALVETRONIC is BMW’s patented fully variable valve control system that eliminates the need for conventional throttles. Engine power is instead controlled directly by varying the amount of lift of the intake valves. Throttle losses in the gas cycle are minimized with this system, which has a positive impact on both the efficiency and torque. VALVETRONIC has also sharpened the responsiveness of this engine compared to the V10 engine it replaces.
Full Technical Specs
M5 Dyno Graph
Physical Dimensions
F10 M5 Reviews:
Advevo
Autoblog
Autobild (vs. M3, E60 M5, 1M, X6M, Panamera Turbo)
Autobild (vs. CTS-V, E63 AMG, Jaguar XFR)
Autocar
Autocar Video Review
Autocar Drift Test
Autocar (vs. E63 AMG & Jaguar XF-R)
Autoexpress
Automobile
Autoweek.nl (vs. Jaguar XKR-S)
Autozeitung (vs X6M)
BIMMERPOST
CAR Magazine
CAR Magazine [Long Term Tester Review]
CAR Magazine (vs E63 AMG and Jaguar XFR)
CAR (vs CLS63 AMG)
CLAR (Owner's Review)
CLAR (Owner's Review vs. E92 M3)
Chris Harris (Review with Nissan GT-R)
Driving Fun
European Car
EVO Magazine Chris Harris
EVO Magazine Chris Harris (Video Review)
Fifth Gear Video Review
Insideline
Ignition (Video Review)
Motor Trend
Motor Trend Performance Test Review
Road and Track (vs Cadillac CTS-V)
Sport Auto (vs Panamera Turbo S and E63 AMG PP)
Top Gear Online
Top Gear Magazine (vs. E63 AMG)
Totalcar
Want more information navigate the tabs below
Jason is offline   United_States
      06-14-2011, 07:15 PM   #2
Drives: E90 M3
Thank you SCOTT.
      06-14-2011, 07:30 PM   #3
uhn2000
Big K...
uhn2000's Avatar
Drives: F10 M5, Cayenne S
Just bada$$.. wow.. what a car! Pure ///M5..!
R8GT Spyder '12 / M5 '13 (MT)
uhn2000 is offline   Canada
      06-14-2011, 07:32 PM   #4
FrankiE90
FrankiE90's Avatar
Drives: 2011 E90 Space Gray™
Send a message via Skype™ to FrankiE90
very nice and classy
FrankiE90 AKA:.[The TANK] *CLICK THE SIG
2011 335 E90 MTECH 6MT • KW V3 • INJEN Intake • Berk 4" DP • Vanguard V2 exhaust • Procede V5 • Stoptech BBK • RPI Scoops • Karbonwerk CSL Trunk • LUX H8 • 19" BBS LM • 18" BBS GT4
FrankiE90 is offline   United_States
      06-14-2011, 07:32 PM   #5
GTFan712
Drives: 1995 AW M3
Liking that color. Can't wait to see all the other options.
GTFan712 is offline   Reply With Quote
      06-14-2011, 07:33 PM   #6
itzjonjon69
Evoms groupie!
Drives: B8 S4
Send a message via AIM to itzjonjon69
very nice!
2011 S4 Premium + | GIAC Stage 2 Software | Injen Intake | STaSIS Touring Exhaust | AWE Pulley | AWE Resonated Downpipes
1st GIAC Stage 2 S4 in Arizona
itzjonjon69 is offline   United_States
      06-14-2011, 07:33 PM   #7
TommyK
TommyK's Avatar
Drives: E90 335i LCI
2009 BMW 335i LCI  [0.00]
2006 E90 330i  [0.00]
Send a message via AIM to TommyK
looks awesome!!
TommyK is offline   United_States
      06-14-2011, 07:35 PM   #8
SchlauCow
SchlauCow's Avatar
Drives: Honda M6
Looks stunning! I'm not particularly fond of the wheels (think they should be more aggressive looking), but what a stunning car!
You will never be as complex as the strand of hair sitting on top of your head.
SchlauCow is offline   Reply With Quote
      06-14-2011, 07:36 PM   #9
Reedomn
Reedomn's Avatar
Drives: 1M
Game changer!!!
VO 1M
Sold- 2008 JZB/Fox E90 M3 6MT Launch car
Reedomn is offline   United_States
      06-14-2011, 07:37 PM   #10
MCMLXXXIX
wat
MCMLXXXIX's Avatar
Drives: a gr3at whit3 5hark
1 in red please. this looks so good
MCMLXXXIX is offline   Reply With Quote
      06-14-2011, 07:38 PM   #11
studntloan
(studntloan)
studntloan's Avatar
Drives: 4 doors 4 more whores
2011.75 E90 BMW M3  [0.00]
2011 bmw/ m3  [0.00]
sick
studntloan is offline   Reply With Quote
      06-14-2011, 07:40 PM   #12
switch311
switch311's Avatar
Drives: Lotus Exige
LOVING that blue it almost looks like a cross between LSB and Estoril. I want this in my garage stat
"Why take life so serious? No one gets out alive."
switch311 is offline   Reply With Quote
      06-14-2011, 07:42 PM   #13
Swangin818
68 Time Gold Medal Champion
Swangin818's Avatar
Drives: 10' E90 LCI 07' CL550
WE ARE NOT WORTHY!!!
Nvrmnd FUCK YEA we are!
2010 E90 328i (daily driver)
2007 Mercedes-Benz CL550 (weekend cruiser)
Swangin818 is offline   Armenia
      06-14-2011, 07:45 PM   #14
JulieDriving
Female driving enthusiast :P
JulieDriving's Avatar
Drives: Bimmer
Well done!
Present: 2013 M3 coupe (Azurite Black, Black, Piano Black)
Past: 2010 335i coupe (Monaco Blue, Cream Beige, Grey Poplar)
JulieDriving is offline   Reply With Quote
      06-14-2011, 07:47 PM   #15
crackberry
crackberry's Avatar
Drives: Porsche Carrera GTS (997.2)
So we lost NA engines for less than 50hp? Well, at least we got a healthy boast in torque.
crackberry is offline   United_States
      06-14-2011, 07:51 PM   #16
SilverII
Drives: '11 335IS
2011 BMW 335IS  [4.83]
so nice
SilverII is offline   United_States
      06-14-2011, 07:51 PM   #17
Mr Gunfun
Mr Gunfun's Avatar
Drives: 2012 Toyota Altezza F
Mr Gunfun is offline   No_Country
      06-14-2011, 07:51 PM   #18
someone
someone's Avatar
Drives: '08 E90 M3 & '11 X5 XDrive50i
I dunno. They seem to compliment so much better than the black wheels on the concept to me.
someone is offline   Reply With Quote
      06-14-2011, 07:52 PM   #19
M3fan
Drives: G35
Looks amazing, but am i the only one who thinks the rear end should of been more aggressive?
M3fan is offline   Reply With Quote
      06-14-2011, 07:53 PM   #20
Whostheboss
Whostheboss's Avatar
Drives: a 9incher
OK!
WHO'S THE BOSS
Whostheboss is offline   Reply With Quote
      06-14-2011, 07:53 PM   #21
21450
Drives: 95 M3, 99 323i
Looks like Monte Carlo Blue.
I want one
21450 is offline   United_States
      06-14-2011, 07:53 PM   #22
Jblack4083
Drives: E46 ///M3 JB/CB
Wow that color is NICE
Observations:
  • There's going to be a huge demand for blacked out side vents
  • The rear bumper and diffuser are JUST right
  • A black or carbon fiber rear diffuser would be a clean look for those into mods
  • Engine bay is monsterous
  • Mirrors still suck IMO
560Hp is nice. I wonder how this will stack up against the RS6. I bet Audi will do 580-590 HP.
Jblack4083 is offline   United_States
Reply
2012 m5 forum, 2012 m5 forums, 2012 m5 review, 2012 m5 reviews, 2013 m5 review, 2013 m5 reviews, bmw 2012 m5 review, bmw 2012 m5 reviews, bmw f10 m5 forum, bmw f10 m5 forums, bmw f10 m5 review, bmw f10 m5 reviews, bmw m5 forum, bmw m5 forums, bmw m5 review, bmw m5 reviews, bmw m5 video, bmw m5 videos, bmw m5 wallpaper, bmw m5 wallpapers, f10 e60 m5 compared, f10 e60 m5 comparison, f10 e60 m5 review, f10 m5 e60 m5 compared, f10 m5 e60 m5 comparison, f10 m5 e60 m5 review, f10 m5 forum, f10 m5 forums, f10 m5 info, f10 m5 review, f10 m5 reviews, f10 m5 specs, f10 m5 versus e60 m5, f10 m5 video, f10 m5 vs e60 m5, f10 m5 wallpapers, f10 versus e60 m5, f10 vs e60 m5, m5 review, m5 reviews, new m5 forums, new m5 review, new m5 reviews
Forum Jump
