Reply
      06-23-2011, 02:39 AM   #45
ron_jeremy
ron_jeremy's Avatar
Drives: E61 LCI Le mans
Originally Posted by wisesoul View Post
That's what they want you to think With higher boost/compression, don't be surprised if this is an underrated engine
+1
These numbers shows that BMW have been pretty modest about theyr output numbers of this new engine, it's a beast allright!
In fact, i'll declaire a prediction right now people, i'll bet my left nut this engine wins next years award as the engine of the year.
3 series: E30: 89 BMW 325i, E36: 92 BMW 325iC, 94 BMW 320iC, 96 BMW 320i Convertible, 94 BMW 320iaC, E46: 99 320ia, E90: 06 BMW 318i Le mans, E91: 07 BMW 318dt
5 series: E39: 97 BMW 520ia, 01 BMW 530Dat, E61: 09 520Dat
X: E83: 05 BMW X3 2.0d Sappihre black.
ron_jeremy is offline   Norway
      06-23-2011, 02:41 AM   #46
Nang Vann
Nang Vann's Avatar
Drives: E46 M3, R35 GT-R
looks awesome!!!
Moving on up!
Nang Vann is offline   Reply With Quote
      06-23-2011, 03:05 AM   #47
spiderz17
Not a BMW Insider
spiderz17's Avatar
Drives: E46M
"VALVETRONIC has also sharpened the responsiveness of this engine compared to the V10 engine it replaces."
Surprised no one has mentioned this yet. Seems like they're claiming this FI engine will be more responsive to throttle inputs than the NA engine it's replacing.
spiderz17 is offline   United_States
      06-23-2011, 03:21 AM   #48
conradb
Drives: 2011 E92 M3 (ZCP/DCT/ZCV)
I'm creaming myself at the thought of the F3x M3 engine that is coming after seeing what BMW is doing here. I MUST take this car for a test drive.
conradb is offline   United_States
      06-23-2011, 05:57 AM   #49
lasovan
Drives: bmw 320
Originally Posted by ACSE90 View Post
I am so sure the power is underrated.
+1
as usual for BMWs
lasovan is offline   Reply With Quote
      06-23-2011, 06:16 AM   #50
OBI_agent
D to the X to the B!
OBI_agent's Avatar
Drives: ABS,American bargain supercar
Originally Posted by sparoz View Post
Maximum HP doesn't describe the power curve. My suspicion is that the extra pressure is used to power the engine after max torque, ie maintaining power after the peak torque - probably giving an engine with less "cliff" drop compare to other turbo engines.
This....!!!!! Thank you.
22psi is just the peak.
PS, turbo engines are always underrated but anyway, 560hp ain't bad at all
11 corvette C6
OBI_agent is offline   United Arab Emirates
      06-23-2011, 06:52 AM   #51
bobbyd1961
Drives: 2009 M3 sedan LeMans Blue
Originally Posted by red-sauerkraut View Post
i CAN NOT WAIT TO DRIVE THIS BEAST
same dam engine. they should have kicked it up to 600+ hp to make a real difference. wont be getting M5
bobbyd1961 is offline   Reply With Quote
      06-23-2011, 07:09 AM   #52
bavarian19
bavarian19's Avatar
Drives: Car
Impressive!
bavarian19 is offline   United_States
      06-23-2011, 08:04 AM   #53
SHOWTIME
Drives: 2011 335i Coupe M-Sport
Yea I highly doubt it.
SHOWTIME is offline   United_States
      06-23-2011, 08:18 AM   #54
Needsdecaf
Everything's Bigger in Texas!
Drives: 2011 535i
Originally Posted by BBS View Post
Thats incorrect. Any pressure the turbo feeds in the inlets are positive. Meaning that are 1.5 bad above 1kpa atmospheric. So 1.5 bar is still 22psi above the normal 14.5psi
It's not incorrect. You're both right, but you're talking about two different things.
1.0 Bar is 14.5 psi, or normal atmospheric pressure. But "gauge" pressure measures what you are speaking of: pressure above the surrounding atmosphere. Boost pressures for engines are typically given in "gauge" pressure not "absolute". So you are correct in that the actual pressure in the intake tract is 2.5 bar, but "gauge" pressure is 1.5 bar.
Good reading here including a handy diagram, which I like:
http://www.engineeringtoolbox.com/pressure-d_587.html
By the way, not sure why everyone is so hung up about the bar thing. It's just another system of pressure measurement. Certainly people are familiar with converting N-M to ft-lbs for torque and kW to HP for power, no?
Needsdecaf is offline   Reply With Quote
      06-23-2011, 08:21 AM   #55
Needsdecaf
Drives: 2011 535i
Yeah, right. You won't get this car because it doesn't have 600 HP. Er, ok.
      06-23-2011, 08:37 AM   #56
Mr Gunfun
Mr Gunfun's Avatar
Drives: 2012 Toyota Altezza F
Good, keep the new M5 rare and exclusive
Mr Gunfun is offline   No_Country
      06-23-2011, 08:53 AM   #57
shaq diesel
Drives: 2011.75 Alpine White E90 M3
Originally Posted by muskamatt View Post
I don't understand why BMW would underrate this engine. IMO that only made sense in the N54 considering some of the times that it made (0-60 etc. etc. stuff that an average consumer would base their opinion off of i.e. not suspension, high revving v8 etc. etc. so please don't start this war) because it had to make sure the M3's times all around were better (see Boxster, vs Cayman, vs 911 discussions).
The M5 has no upper vehicle to make sure it does not out perform. Why underrate? From a marketing/sales perspective it makes no sense. This car will need some marketing/sales push so this doesn't make any sense to me.
Also, I am still not sure about this bar $hit but if the stock motor is pushing 22 psi like people have said then how does this thing not have turbo lag? Will tuners be pushing 30+ psi? Doesn't that seem ridiculous?
It's economies of scale.
If this engine architecture turns out to have great real-world reliability, all they'll have to do in 3-5 years is bump up the boost/tuning to keep up with the competition. If they can just play that game to keep in the HP wars that means they'll get a lot of years out of this basic engine architecture, which means a lot of design/construction savings down the road. It also means they'll have that much longer to design and test its eventual replacement.
A much better path financially than building the motor at peak power now and having to completely redesign in to 3-5 years to keep up with the competition.
shaq diesel is offline   United_States
      06-23-2011, 09:06 AM   #58
Q4P
Q4P's Avatar
Drives: Too Much
Something's not right with the numbers, if the engine is truly running at 22 pounds, then it should be making a lot more power. The N54 which is only a straight six with much tinier turbos puts down like 440 at 17 lol.
Q4P is offline   United_States
      06-23-2011, 09:10 AM   #59
dcafs
Drives:
I know.....
That is why I originally stated that 1.5 bar might only equate to 8 psi.
BMW specified on page 1 that their 1.5 bar measurement was absolute pressure (which includes atmospheric), not gauge.
Gauge pressure is signified by a ‘g’ after the pressure unit e.g. 30 psi g, this indicates that the pressure measured is the total pressure minus atmospheric pressure.
Absolute includes atmospheric pressure, so you have to subtract 14.7 psi from the 22.
Given that the N54 platform only pushes 9 psi, I would be surprised if BMW came out with an engine that pushes 22 psi stock.
dcafs is offline   Reply With Quote
      06-23-2011, 09:12 AM   #60
mkoesel
Moderator
Drives: IB/PS M-DCT E93 M3
Originally Posted by amirz1000 View Post
Say hello to the 2014 F3X M3 engine. Oh minus 2 cylinders and about 100hp of course
And rearranged from a V to an I layout.
And an 84mm to (at most) 86mm bore.
And a 90mm stroke.
And, hopefully, a higher (7500RPM+) redline.
Other than that though, yep, absolutely identical.
2008 Interlagos Blue E93 M3 - M-DCT
2011 Salsa Red Jetta TDI Sportwagen - DSG
mkoesel is offline   United_States
      06-23-2011, 09:28 AM   #61
kardboard
N54 or bust
kardboard's Avatar
Drives: 2010 135i, 2004 WRX
2010 135i  [3.00]
2004 WRX  [4.00]
Originally Posted by stingray23 View Post
22psi and only 560HP?
When you turbo a Vette' don't they only push like 8 psi??
What's at play here, any clue? The size of the turbos?
2010 135i: Crimson Red with Black interior.
2004 WRX: World Rally Blue. My track toy.
kardboard is offline   United_States
      06-23-2011, 10:24 AM   #62
cstavaru
cstavaru's Avatar
Drives: 2009 335i M Sport Sedan 6MT
That's incorrect. They clearly state "absolute pressure". So it's not 22psi relative to atmospheric pressure, but absolute psi. So substract 14.7 which means 7.3psi relative pressure. Which makes sense for a lag-free motor with small turbos producing this kind of power from a 4.4l engine.
cstavaru is offline   Reply With Quote
      06-23-2011, 10:25 AM   #63
JasonCSU
Drives: '08 135i, '03 WRX
2003 Subaru WRX  [0.00]
1988 BMW 325is  [0.00]
2008 BMW 135i  [0.00]
Originally Posted by MikeyComputers View Post
will those turbo's fit in the n54?
No, because they are twin scroll turbos. However, the N55 does use one twin scroll turbo, so in theory, you could bolt one of those turbos onto that engine.
Delivered in Munich, broken in on the Nurburgring.
JasonCSU is online now   United_States
      06-23-2011, 11:08 AM   #64
Dodge2Dub
Drives: E90 M3; Ducati
Dear BMW,
Thank you for thinking about my future insurance costs when you published the wheel horsepower of my next car, the M5, instead of the crank horsepower.
Yours truly,
The BMW Community
E90 M3: Some cool stuff...more to come
Ducati S2R 1K: Bucket full of mods
Dodge2Dub is offline   Reply With Quote
      06-23-2011, 11:43 AM   #65
dcafs
Drives:
EXACTLY
      06-23-2011, 11:48 AM   #66
Dodge2Dub
So, in standard forced induction car talk, is this 7.3psi or 22psi when comparing to other FI platforms?
Reply
Forum Jump
