Reply
      06-23-2011, 12:09 PM   #67
grimlock
Drives: F10 528i
The addition of Valvetronic is more important than what PSI its running at or stated/'actual' HP.. since the latter is all conjecture and wishful thinking.
Valvetronic reduces lag like on the N55 vs N54 ..
Otherwise its the same old X6M/550i engine.. the 550i engine already has valvetronic does it not? so its an 'M' version of the same engine, or a next-gen X6M engine if that ones didn't have Valevtronic.
grimlock is offline   Reply With Quote
      06-23-2011, 12:19 PM   #68
Q4P
Q4P's Avatar
Drives: Too Much
Originally Posted by cstavaru View Post
That's incorrect. They clearly state "absolute pressure". So it's not 22psi relative to atmospheric pressure, but absolute psi. So substract 14.7 which means 7.3psi relative pressure. Which makes sense for a lag-free motor with small turbos producing this kind of power from a 4.4l engine.
This makes a lot more sense, I have no idea how you could boost a V8 engine 22 pounds... lol
Q4P is offline   United_States
      06-23-2011, 12:23 PM   #69
marcielago
marcielago's Avatar
Drives: SG F10 550i MS, CB E39 M5
I'm more interested in finding out a comparison between the S63tu and the N63.
F10 550i M-sport: Space Grey/Oyster Black
E39 M5 : Carbon Black/Caramel
E39 520i : Titanium Silver/Beige (Sold)
marcielago is offline   United Arab Emirates
      06-23-2011, 12:36 PM   #70
dcafs
Drives:
Originally Posted by Dodge2Dub View Post
So, in standard forced induction car talk, is this 7.3psi or 22psi when comparing to other FI platforms?
It means that the turbos are putting out 7-8 psi as seen on a boost gauge...which is in line with what BMW has been doing on the N54 platform.
Small twin turbos with low inertial mass that spool up quickly and are intended to complement the engine's own volumetric efficiency with a moderate amount of boost.......not ram 22 psi of forced induction as the primary way of developing power.
dcafs is offline   Reply With Quote
      06-23-2011, 12:39 PM   #71
dcafs
Drives:
Boosting it to 22 psi is not a problem. The problem is how 22 psi would feel in daily driving.
It probably wouldn't be a smooth linear power delivery.
Although we car enthusiasts would love the power.....the average joe consumer might feel that the car is too edgy and difficult to moderate power safely.
      06-23-2011, 12:40 PM   #72
twenzel
twenzel's Avatar
Drives: 07 GT3 | 10 GTI
+1
7.3 PSI in terms how people normally discuss boost levels on this forum, but there is probably an over boost button like the 335is and 1M.
If this motor was under 22PSI in normal terms, we'd be looking at least 700HP given the displacement.
twenzel is offline   Reply With Quote
      06-23-2011, 12:47 PM   #73
mkoesel
Moderator
Drives: IB/PS M-DCT E93 M3
No, it does not. This is the first turbocharged V8 from BMW with Valvetronic. I suspect that they will indeed use Valvetronic for the N63's successor, however (or perhaps even in a revised N63 in the next couple years).
2008 Interlagos Blue E93 M3 - M-DCT
2011 Salsa Red Jetta TDI Sportwagen - DSG
mkoesel is online now   United_States
      06-23-2011, 12:47 PM   #74
Q4P
Q4P's Avatar
Drives: Too Much
Really? I thought only a 4 cyliner engine could run that much boost (i know evos do this no problem), as I understand it the less cylinders and displacement the more boost you can run due to compression differences and so forth, are there any examples of vehicles running that much boost with a V8?
In addition, I think someone above mentioned at 22 PSI this engine would put down 700, I tend to think it would be a lot more if it was possible?
      06-23-2011, 01:07 PM   #75
dcafs
Drives:
You own a 335, so you probably know that there are a number of tuned N54's that have posted boost pressures of 19-20 psi with stock turbos on six cylinders
But your point is taken.....you would need to move a lot more air with 8 cylinders than with four.
Which just reinforces that the twin turbo eight in this press release is probably pushing 7-8 psi -as it would take larger turbos to pressurize an eight cylinder engine up to 22 psi and introduce more lag and a rubber band like power delivery.
      06-23-2011, 01:10 PM   #76
grimlock
Drives: F10 528i
Thats a pretty big difference then. It should 'feel' quite different from both the N63 and S63..? Valvetronic is quite a physical difference, you'd wonder why they don't play it up more, unless the difference in use is not large. A test drive would answer that!
      06-23-2011, 01:37 PM   #77
Eccentric
Eccentric's Avatar
Drives: Interlagos Z4 M Coupe
Originally Posted by BMWPower06 View Post
lol I all of a sudden think that BMW is extremely underrating this engine...
Its got almost 5 more PSI of boost than the normal S63 engine and a higher compression ratio. I wouldn't be surprised if this engine is actually closer to 600hp
This man is correct. The S63Tu is in fact an underrated engine. Ask your local dealer for more info about it. The 560bhp is actually closer to the WHP figure than the actual BHP
WE ARE!!!!!!
Eccentric is offline   Reply With Quote
      06-23-2011, 02:39 PM   #78
BMWinNorthdakota
Drives: 2007 bmw 335i e90
So uh... actual figures are at.. 615ish..?? (stab in the dark)
BMWinNorthdakota is offline   Reply With Quote
      06-23-2011, 02:41 PM   #79
Wolf
Wolf's Avatar
Drives: on hold
I have a question.... what pressure range does a gasoline engine have? what psi will cause misfire?
Originally Posted by bimmerjph View Post
Originally Posted by SCOTT26 View Post
BMW have tapped into this by mirroring typical BMW dynamics and steering communication within the new UKL cars.
You mean massive body roll, a steering system that is not connected to the front wheels, and the engine note played through the speaker system?!?!?!?!
Wolf is offline   Reply With Quote
      06-23-2011, 02:56 PM   #80
burrito007
Drives: e46 M3
you guys also need to realize that this engine is probably not boosting til redline. it is probably pulling boost like the 335s did. tuning it so boost doesnt taper off will give huge HP gains.
burrito007 is offline   Reply With Quote
      06-23-2011, 03:58 PM   #81
SHOWTIME
Drives: 2011 335i Coupe M-Sport
Damn I wish I knew all this shit u guys are talkin about
SHOWTIME is offline   United_States
      06-23-2011, 04:23 PM   #82
moody320d
moody320d's Avatar
Drives: 09 M3 Coupe Silverstone II
Originally Posted by wisesoul View Post
That is how much boost the turbo is displacing in the cylinders. More compressed air=more power. That's the easiest way I could put it
Oh kay! thanks for that
moody320d is offline   United Kingdom
      06-23-2011, 08:06 PM   #83
CAPSGOD
Drives: Diesel Son
I'm not sure I understand the bit about the differential. Is it an e-diff like in the regular 5-series or an electronically controlled mechanical unit?
CAPSGOD is offline   Reply With Quote
      06-23-2011, 08:15 PM   #84
southlight
Moderator / European Editor
southlight's Avatar
It's an electronically controlled mechanical unit.
Best regards,
south
southlight is offline   Reply With Quote
      06-23-2011, 08:28 PM   #85
Kinzer S13GT
Avid enthusiast... is to put lightly!!
Drives: Black Coupe
This S3tu engine is running 4 separate reverse flow exhaust manifolds for the 2 (twin scroll) turbos. (and yes the turbos could be used on an n54 given it was equipped with the right manifold/s, they are already working on the next n54 twin/twin scroll replacement) Using a HDE/DI fuel injection system, with solenoid controlled, multi-hole injector nozzles now, (homogenized mixture control) allows them to run much higher boost pressures, and compression ratios, based on the fact that their system completely atomizes the fuel in the combustion chamber @ up to 200bar before even being ignited. A higher compression ratio alone, will reduce the perceived "lag" on throttle. Direct injection removes the "lag" between the time it took for fuel to inject into the intake port, travel passed the valves, into the chamber, and finally introduced to the combustion process. Not to mention that fuel was never completely vaporized, and it would "stick" to the valves, and the chamber. Cutting down efficiency. Fuel Evaporation allows a cooler more dense air charge. Every 10 degrees drop in temps is a 1% increase in Hp. Homogenized control, meaning the mixture is evenly distributed throughout the combustion chamber. This is valvetronic III. These motors are brushless, and they are hidden below the head cover, and oil cooled. The air speed in and out of the chamber is even more tightly controlled. Everything in and on this engine is computer controlled, not just monitored. Even the oil pump flow rate is computer controlled. This cylinder head design, is superior to the 1st gen S63. And the engine as a whole, is worlds apart from the outgoing S85. (not to say its a poorly designed engine, lol! BMW PTG can make 800+hp on a naturally aspirated S85 ) This engine is just doing so much more to move more air, and more (or less) fuel, to make power twice as efficiently as that engine. Actually as far as volumetric efficiency is concerned, its probably running at an average of 75-85% of its max potential volumetric efficiency. Depending on conditions. Whereas the S85 was sitting around 40-60%! BMW builds the most ridiculous engines, then dials their output down to 5' before selling it to us civilians! Their capabilities are always underrated!
Kinzer S13GT is offline   Reply With Quote
      06-23-2011, 08:32 PM   #86
bobbyd1961
Drives: 2009 M3 sedan LeMans Blue
Originally Posted by Needsdecaf View Post
Yeah, right. You won't get this car because it doesn't have 600 HP. Er, ok.
yes true and im not thrilled about the looks either. My M3 sedan looks better than that except for maybe the exhaust. so years in the making and they come out with an engine equal to the e 63 amg? it is dissapointing at least to me.
bobbyd1961 is offline   Reply With Quote
      06-23-2011, 08:36 PM   #87
bobbyd1961
i just looked at the pictures at the nurburgring 24 it looks great and i like the blue. just wish they really separated themselves from mercedes and even the ctsv. and should have cracked the 4 second 0 to 60 mark. but for looks it defininately gets a
      06-23-2011, 09:45 PM   #88
eMvy
eMvy's Avatar
Drives: 11' AW e92 M3, 13' AW F25 X3
Boost is one variable which in of itself doesn't define the outcome. Quality in the engine build/internals, ems tuning, compression ratio...ability for systems to obtain the best stoichiometric ratio is whats key.
eMvy is offline   United_States
Reply
Forum Jump
