      10-22-2012, 03:20 PM   #155
PatrickC23
PatrickC23's Avatar
2013 BMW ///M5  [0.00]
Originally Posted by Nate@IND View Post
We just got the first 3D Design F10 M5 rear exhaust system into North America today. The build quality and welds look amazing with aggressive 100mm round tips.
I think I missed it - but whats cost on the 3D exhaust?
2016 991.1 911 Carrera GTS
      10-22-2012, 03:25 PM   #156
Nate@IND
Nate@IND's Avatar
1617
The 3D system is $4487.00 and made in Japan.
      10-23-2012, 10:08 AM   #157
Nate@IND
Nate@IND's Avatar
1617
Eisenmann Race performance with 4x102mm Round tips + Eisenmann center pipes.
-Cold Start
-Revving
The following is installed during the video-
      10-24-2012, 02:55 PM   #158
the infamous...
Relapsed Bimmerpost Addict
the infamous...'s Avatar
best exh vid i've heard yet
"simple is clean" -The ///ModFather
      10-24-2012, 04:44 PM   #159
Nate@IND
Nate@IND's Avatar
1617
New 3D Exhaust video (Revving) video- (3D rear section only)
      10-26-2012, 06:32 PM   #160
M54ccibo
M54ccibo's Avatar
Drives: '16 GT4
I've got a question...
Looks like the OEM exhaust has heat shielding on the section near the differential/axles. The only full aftermarket systems which have something similar (better?) is wrapping on the Eisenmann and a small shield on the Akra.
Any idea if there is a heat issue in that section of the car? Seals where the axle meets the diff? Non-issue?
      10-27-2012, 06:39 PM   #161
Ak3249
Ak3249's Avatar
12
Drives: BMW F12 M6 Cab
Has anyone done straight pipes or a muffler delete yet?
      11-02-2012, 06:54 PM   #162
Nate@IND
Nate@IND's Avatar
1617
F10 M5 Supersprint sneak peek
      11-05-2012, 08:42 PM   #163
ImpetuousRacer
ImpetuousRacer's Avatar
2013 BMW M5  [0.00]
Anyone know who makes these exhaust tips...
      11-06-2012, 11:19 AM   #164
Nate@IND
Nate@IND's Avatar
1617
I could be wrong but that looks like an Innotech exhaust installed on the Black F10 M5. Checking now...
      11-06-2012, 07:02 PM   #165
Nate@IND
Nate@IND's Avatar
1617
New Eisenmann Race 4x102mm installed
      11-06-2012, 08:21 PM   #166
yiango13
Drives: F10 M5 F30 328xi
Great picture Nate! Got the Eisenmann race exhaust at ind yestertday! Bring the M5 to life!
      11-11-2012, 11:35 AM   #167
Nate@IND
Nate@IND's Avatar
1617
Thanks again!
      11-12-2012, 12:49 PM   #168
Aboody99
Qatar
Any news on Akrapovic Downpipes?
      11-13-2012, 04:45 PM   #169
Nate@IND
Nate@IND's Avatar
1617
No update yet BUT here is the new SS M5 photos
Dyno-
http://www.supersprint.com/en/prod-p...v8_2012__.aspx
      11-13-2012, 07:28 PM   #170
Used2be
Perennial PFC
Used2be's Avatar
Drives: F10 M5 SpaceGray/SO
I don't know enough about turbo exhaust to know if it makes a difference or not, but your pictures show an exhaust with almost NO kinks or squishes in the tubing for the whole run, great work!
Is the welded on, second separated layer of metal on the tubing around the differential as effective, or more effective than some asbestos exhaust wrap in that area for reducing the radiated heat?
If you eliminate, or run just a very minimal catalyst in the down pipe, is there any point to having the flapper valve in the one tube on each muffler?
      11-14-2012, 12:07 AM   #171
star21
star21's Avatar
Drives: F10 M5 en route
It looks like Hartge has a muffler (quad tips and rear section piping only) delete option for the rear section. I would think it'd be noticeably LOUD, especially when paired with non-resonated mid-piping.
      11-28-2012, 02:43 PM   #172
Nate@IND
Nate@IND's Avatar
1617
New Eisenmann Race 4x102mm video (Race performance + center pipes)
      11-28-2012, 03:46 PM   #173
bobblehead
bobblehead's Avatar
Drives: warp speed
Any such video for the Supersprint on the M5 ?
      12-02-2012, 04:33 PM   #174
BarryB
Drives: 30Jahre M5 plus a few more M's
Any info on hp#'s any of these? Had supersprint on both E39 and E60 M5's so would love to hear more, weight, hp gains and cost pls.
F10 30 Jahre M5/F80 30 Jahre M3
F82 M4 GTS/ E39 S3 M5
E36 M3 with S54 Swap/F22 M235 Dinan Stage 4
F85 X5M 3.5i/03 Cooper S (Maxi Tuned 50bhp)
60 Impala (43k orig mi)[b]
      12-02-2012, 07:46 PM   #175
star21
star21's Avatar
Nate@IND posted up the link for the Super Sprint exhaust (pictures/video, dyno graph, part numbers) which can be found again here: http://www.supersprint.com/en/prod-p...v8_2012__.aspx
I'm a bit surprised that replacing the downpipes, mid-pipe, and rear section only netted an increase of less than 8 HP and 25 ft/lb of torque. Kind of seems a bit low for so much of the exhaust system being replaced.
      12-03-2012, 11:59 AM   #176
Nate@IND
Nate@IND's Avatar
1617
That's showing true gains without a custom tune. In order to gain a good amount of power you must run a custom tune with the full exhaust setup.
