      05-08-2012, 01:54 PM   #1
singularity
Driver
singularity's Avatar
53
Drives: M5 (F10)
Question Known F10 M5 issues, problems and solutions
Here's a list of known problems and solutions by owners, hope it's helpful for current and future M5 F10 buyers.
  1. Problem: Clunking / loose noise from rear on bad roads
    Reason: Confirmed factory defect spring coils.
    Solution: BMW releasing replacement spring coils in December 2012
    Reported by: singularity
  2. Problem: Wind rattle/fan rattle sound when car is under throttle
    Reason: Loose pipe clip on induction system
    Reported by: burns all, singularity
  3. Problem: Brakes pedal becomes very soft after a few minutes of stress driving. Beware of increased brake distance.
    Reason: Bad factory brakes. Choose ceramic brakes or don't race for longer than a few minutes.
  4. Problem: "Drivetrain error. Maximum power not available"
    Reason: Legacy flaw in fuel pressure sensor / high pressure fuel pump.
    Solution: Possibly fixed on cars produced after February 2012.
    Reported by: phish_100, singularity
  5. Problem: Brake system failure/Tyre pressure sensor failure/Driving Stability Control failure
    Reason: Brake pad sensor failure
Sorry for my bad english, gonne edit topic as more people report solutions. Hope it helps.
      05-08-2012, 05:13 PM   #2
AlpWhite11
Drives: 335i
Send a message via Yahoo to AlpWhite11
Good list. Thanks. Any recalls or TSB/SIB bulletins published on any of these? Hope the US cars will have these cured already when they are built in July.
      05-08-2012, 05:18 PM   #3
singularity
Driver
53
Drives: M5 (F10)
No idea, I just made them up from my own and other owners' experience on forum boards.
      05-08-2012, 05:29 PM   #4
E90Fleet
South Africa
1068
Originally Posted by singularity View Post
[*]Problem: "Drivetrain error. Maximum power not available"
Fuel rail was changed from February 2012 production, possibly solving issue
      05-08-2012, 05:54 PM   #5
jphughan
jphughan's Avatar
Drives: '16 Cayman GT4
A soft brake pedal after a few minutes of hard driving implicates the brake FLUID, not the pads or rotors. Inadequate pads or rotors (in which case carbon ceramic would be the fix) would be indicated by increased stopping distance at maximum braking pressure after a while compared to a baseline stopping distance at maximum pressure -- but that's impossible to confirm if the brake fluid boils first, because that reduces maximum possible pressure that can be transmitted to the pads at all, in which case increased stopping distance could be caused solely by the reduced pressure being transmitted to the pads, not necessarily the pads and rotors being overheated.
I'd be curious to know what would happen just swapping some Castrol SRF in there. If you do that and THEN you get brake fade, then that's the point where you either need carbon ceramic or an aftermarket BBK. But if the fluid is boiling first, then considering upgraded fluid is a pretty cheap and quick fix, I'd be interested to see how the brakes hold up after that upgrade is in place.
Gone but not forgotten:
'11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015)
      05-08-2012, 06:22 PM   #6
singularity
Driver
53
Drives: M5 (F10)
Originally Posted by jphughan View Post
A soft brake pedal after a few minutes of hard driving implicates the brake FLUID, not the pads or rotors. Inadequate pads or rotors (in which case carbon ceramic would be the fix) would be indicated by increased stopping distance at maximum braking pressure after a while compared to a baseline stopping distance at maximum pressure -- but that's impossible to confirm if the brake fluid boils first, because boiled brake fluid lowers the amount of pressure that can be transmitted to the pads in the first place, in which case increased stopping distance could be caused solely by the reduced pressure being transmitted to the pads, not necessarily the pads and rotors being overheated.
I replaced brake pads because they burned and started squeaking quite early, but still had 90% beef on them. They were mildly squeaking when braking at about 25 km/h and high-pitch heavy screeching sound when braking from 5 km/h to 0 km/h and even when turning off the car.
About brake fluid for heavy driving, I'll see about changing brake fluid and definitely report results once I do. Will probably take a couple of weeks though. Thanks for the recommendation.
      05-08-2012, 06:24 PM   #7
singularity
Driver
53
Drives: M5 (F10)
Updated the topic, thanks.
      05-09-2012, 02:07 AM   #8
Flying M
Flying M's Avatar
Drives: F10 M5 '12
Yesterday left mine for a 2000km service. Service noticed an oil leak - had to add 1l at 2000 and when I brought car for a service with 2500km it required to 3/4l to be added again.
Now driving a loaner car 320i
      02-14-2013, 05:46 PM   #9
krispykreme
Drives: e90 328i
My fuel pump and pressure sensor both failed. So the issues has not been addressed by BMW.
-13 F10 M5 6MT (Amazonite Silver)
      08-28-2013, 05:22 PM   #10
camalbes1
Drives: 2012 F10 M5 Black Saphire
Well, I have a 2012 M5 Black Sapphire with Eisenman exhaust system, the car is a beast but I have always complained that it consumes too much oil and the noise over irregular pavement in the rear suspension is annoying. But about a month ago, with 18,000 km in the odo, the car gave me a warning that it was low on coolant, I check and indeed it was low so I proceeded to fill it. About a week later the car started sounding weird and it posted a message that said that the engine had limited power so I took the car back to BMW and they found out that the hoses that supply coolant to the inter-coolers for the turbos were leaking. They proceeded to change them (don't understand how a US$ 100,000.00 + car can have such a design flaw) the head mechanic informed me that the hoses failed because they endured very high temperatures and that in his opinion it was a design flaw. I had the car for 48 hours when the A/C stopped working, it felt that it was missing some gas; they confirmed that the a/c system needed refrigerant and proceeded to fill it up. A week after that the car started asking for more coolant so now we are waiting for new hoses from the factory (2 weeks) and the A/C stopped working again.
I have become very disappointed with this car, I have owned 5 911's and I don't think I'll ever by another BMW (this is my 3rd and last); when I compare this car even to a Maserati QP that i owned in 2007 (which never gave me problems) and with the Porches I have owned I think this car is sub-par quality wise.
I just hope I don't get any more trouble so that I can safely get rid of it come May of next year, I can't fathom spending this amount of money on a car and having to send the car for repairs in less than two years of ownership, I seriously think BMW rushed this car into the market.
      08-29-2013, 12:21 AM   #11
greentrbo95gst
greentrbo95gst's Avatar
324
Drives: 2013 Azurite Black M5
My car is a 4/2013 build and none of the problems described occur. Maybe I got lucky with this one.
Current: 13 M5 (Gone); 02 M5, 14 X5, 06 M3, 05 M3, 15 I3, 67 Camaro RS SS
      08-29-2013, 09:34 PM   #12
Alpine300zhp
Drives: M4/M3
It pays not to be an early adopter.
      08-29-2013, 10:43 PM   #13
greentrbo95gst
324
I should have knocked on wood before I said it....
      08-31-2013, 09:39 AM   #14
mstmng
Drives: M5 F10
i was pushing my car really hard last night and guess what i got on a screen today in the morning when i started the car
i turned off the engine and ignition, started again and it went away
shall i not be bothered with checking it as long as it its just a pressure sensor?
      09-14-2013, 02:28 PM   #15
crazy08
Drives: 2013 M5
2013 BMW M5  [5.00]
Took mine in a few days ago for this. Took the two days to figure it out even though I showed them this post. They are ordering new spring coils and bump stops. I'm guessing bump stops are bushings?
'13 M5 Imperial Blue
Sold: '11 M3 IB / Fox Red
Sold: '05 M3 Mystic Blue / Cinnamon
      09-14-2013, 05:25 PM   #16
h4nh
h4nh's Avatar
Drives: 09 SC E90 M3 / 13 F10 M5
2009 E90 M3 (superc ...  [5.00]
2013 M5  [0.00]
wheel bearings click! for those that replaced these, did the problem come back?
      09-14-2013, 05:43 PM   #17
Neil McRae
BMW Motorsport
Neil McRae's Avatar
Drives: BMW ///M4 F82 / BMW ///M5 F10
2014 BMW M5 CP  [4.25]
2015 BMW M4  [5.00]
Send a message via MSN to Neil McRae
drivetrain error fixed by software update.
brakes not an issue for me, learn how to drive on a track!
Neil J. //McRae -- Alive and Kicking -- neil at DOMINO.ORG --///M ARMY
M5 DCT CP Alpine White -- M135i Alpine White -- M4 DCT Alpine White
      09-14-2013, 11:48 PM   #18
04S
04S's Avatar
I am pretty sure it is more than that. I posted the entire list of parts they replaced on mine to solve the same issue. Lit is both front and rear, even though the noise comes from the rear. If you search you will be able to find the parts list I posted.
On order: F80 M3 ZCP
Current: Singapore Gray 2012 M5, AW M135i, AW X5 40d
Gone: 11 other BMWs ....
      09-15-2013, 07:16 AM   #19
bobblehead
bobblehead's Avatar
Drives: warp speed
Just had mine repaired two weeks ago and today, I heard couple of clicks during the max wheel turning in the parking lot, other than that, I feel it's just matter of time before I have to go back and have it re-done.
      09-15-2013, 05:01 PM   #20
h4nh
h4nh's Avatar
2013 M5  [0.00]
damn. That's not even worth driving to the dealership to drop it off. lol
      09-15-2013, 05:20 PM   #21
JOHNBMWM5
JOHNBMWM5's Avatar
Drives: 2018 540i M/Sport MPerformance
Have LCI and "Never heard of any of it".
Car runs a treat.
2018 540i M Sport "M" Performance kit..
      09-15-2013, 10:07 PM   #22
singularity
Driver
53
Drives: M5 (F10)
You must be driving in glammy Forza 4 green-line tracks and controlled environments, try real and regular street races in a brutal reality and see your 2 ton bath tub soften up fast before AMGs, Porsches and even metrosexual maseratis. Breaks in this car are an issue for those who push it to the limits, which =/= "spirited driving" on designed curves in a "how to drive to avoid a brake fade" fashion. Brake fade is alien to E60 and E63, which in turn don't have a fraction of the brake fade problem that F10 is suffering from - on exact same situations, parallel street racing in numerous occasions so please keep irrelevant track talk for proper track cars pursuing track times.
