FORUMS
- 5
| 06-20-2012, 05:36 PM | #23 |
Shaunny.L
Drives: 320D Join Date: Sep 2010
I'm not quite sure about the fuller they use..is it a oiled one or dry?
Sorry for the question, might be a but stup1d?
let's Torque'
![]() K&N 57i intake, DTUK CRD-t , BE by Breyton 19', matte white interior, tune pedalbox, MD with 3' twin pipe...project half done |
| 06-20-2012, 05:39 PM | #24 | |
Bimmerpost Gold Supporting Vendor
Drives: 2011.5 Fire Orange E92 M3 Join Date: May 2012
Sean | Precision Sport Industries (PSI) | Sean@precision-sport.com | www.precision-sport.com | FACEBOOK | 407.617.0372 |
| 06-20-2012, 05:55 PM | #25 |
![]() Drives: Triple Black 2013 F10 M5 Join Date: Apr 2012
A. I would never pay over $500 bucks for any intake system for the F10 M5.
B. It's not a RAM Air system unless it has components that directly channel the air from outside into the intakes. I don't see any components that are of a scoop like design. C. Like somebody else said Dyno results are easy to post up. I would rather see a video showing 2 F10 M5's side by side, one with the new intake setup the other completely stock. If the car with the intake setup wins, they can have my money. Until then I am skeptical. |
| 06-20-2012, 06:15 PM | #26 |
The RAM AIR name comes from the (2) CF air scoops which are mounted on the inside of the front grills, these scoops channel air to the intake boxes.
I have highlighted them in RED below. ![]() Once more information and videos are released I will be sure and post them here ASAP, as I know many members would like to see "real world" results. This product was only just released officially on 6/14 in Japan.
| 06-20-2012, 07:49 PM | #27 | |
Everything's Bigger in Texas!
You're talking about ducted air into an air box and then into a forced induction engine. Quite simply, it's not ram air. Ram air would imply that you are pressurizing the intake into the engine over atmospheric. Simply, you're providing more air in the intake than the engine (which is nothing more than a fuel / air pump) can pull through at any given RPM and load. You're not doing that with forced induction. THe pressure in the intake manifold is a function of the turbo and the associated controls (ECU, waste gate, etc.) only. Not the intake. The only thing this intake (or any other intake on a forced induction engine) could possibly do is eliminate vacuum in the intake pre-turbo. That's it. Whether or not that's worth power depends on whether or not the vacuum in the intake prevents the turbo from making maximum boost at the target airflow for the given RPM / load. Vacuum in the intake is bad, but it's not guaranteed to restrict power. Cool intake, but those gains are hard to believe, even with an engine moving this much air. In order to make that much more power, the stock air filters must be VERY restrictive. Those little scoops are likely worth less than 5 inches of water in increased pressure inside the air box. Which is about 0.18 psi. I've tested similar systems on a manometer using two x 2" round ducts (high performance ducts such as used on race cars) fed by large oval scoops into the same air box. Max differential was approximately 8 inches of water of pressure. |
| 06-20-2012, 08:41 PM | #28 | |
The Dyno was from a Dynapack system in Japan. Once we receive the intake stateside, we can have some more tests done with a more familiar dyno system, such as a DYNOJET or a MUSTANG Dyno to alleviate any doubts or concerns.
| 06-21-2012, 05:00 PM | #32 |
![]() Drives: 08 e92 M3 6MT Join Date: Sep 2008
Fuck that
![]() 2008 AW/Blk 6MT, Akrapovic Evolution, Evosport Pulley, ESS Tune, Dinan Camber Plates, H&R Springs, Braille LWB, Other Track Goodies, TRMotorsport MT1 18s w/Michelin PSS and Hoosier R6 |
| 06-21-2012, 07:51 PM | #33 |
| 06-22-2012, 07:59 AM | #34 |
Very nice! Waiting to see more specs on this but Gruppe M makes some nice intakes with good gains.
Current Mods: GC Coilovers, Eibach Sways, RE RTABs/RSMs/RCAs, INTRAVEE II + Alpine KCA-420i, Black Roundels, ///MFEST Badges, Depo's, Screen protector for OEM 16:9 display, VCSL Bumper + Race Lip, CF Boot, CF Rear Diffusor, DIETZ TV in Motion, AP Headers, RT Cats, Oem exhaust + 80mm tips, Z8 Starter Button, Lamin-X, GM SMG Paddles, 0-60 Steering, OEM CSL interior, OEM CSL Intake, EVOLVE Tune, BBS CH's, 3K AE's & Low Beams, FX-R Proj
| 06-28-2012, 02:20 PM | #35 |
NEW PICS
| 06-28-2012, 05:10 PM | #37 |
GruppeM + Akrapovic will be the perfect combo!
| 06-29-2012, 01:50 AM | #38 | |
With the N54, you had to be pushing around 380wHP to have an intake help with power. .
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
| 06-29-2012, 02:20 AM | #39 |
If there is any gain, it's prob from the less restrictive air filter at the expense of letting in more crap into the engine. I doubt those fancy carbon has any real benefit.
Current Rides:
- Frozen Grey E92 M3 DCT w Perf Exhaust - Frozen Grey F10 M5 DCT |
| 06-29-2012, 02:27 PM | #40 | |
"restrictive filter" is marketing gimmicry. |
| 07-20-2012, 04:53 PM | #43 | |
I'll give someone $500 max, right now for an intake that is made out of non-carbon fiber that makes real gains in power. And I'm talking YouTube videos of F10 M5's with aftermarket intakes that beat stock M5's without them. By the way Dinan has confirmed it will be designing an intake system for the F10 M5. So I would hold your breath for that instead. ![]() |
| 07-22-2012, 11:45 AM | #44 |
Puuurty, but it seems that just about it. Oh yeah, and pricey.
My experience with GruppeM hasn't been all that great. Their E39 M5 application was greatly flawed as it was an open-air design and actually sucked hot air in. On the RS 4, caused CELs which no tuner could fix. On either car, their performance gains were never substantiated independently. Pretty and sexy as Kate Upton, but that's about it... A lot to pay for eye candy, which you rarely even see unless you drive with the hood open. LOL
2011 BMW E82 1///M: AW, ZPP, ZCV, HK, Sirius, Apps; Akra CF+Valve control, MadDad mids, K&N, Forge FMIC, P3gauge, EuroTails, Tint, CF Mirrors+Spoiler+Roof Wrap, 10mm H&Rs, IND grills+gills, xCDV, LUX AE
2008 Audi B7 RS 4: Sprint Blue, Exclusive Euro Recaro Interior, Premium+Titanium Package, EPL Tune, Stasis Ohlins MS coilovers, Milltek valved exhaust+DownPipes, Stoptech SS lines, Tint, ADR V1, Lidatek, Lamin-X, Rotiform SNA 19x10" wheels, 275/30/19 PSSs, Euro flat-bottom steering wheel, JHM SSK |
| Bookmarks |
